In the USA we have a large ABB VFD DC drive running 600hp motor on a piece of equipment. The e-stop circuit on this piece of equipment will caused the drive to perform a fast stop when the e-stop is pushed, this motor is ramped down to a stop zero rpms and then it power down disable the output to the motor. My question is there a requirement to have a line contactor to remove power to the drive? Has to code changed since the equipment was installed 20 years ago? My problem with removing line power while the motor is turning it will then coast to a stopping instead of braking to a stop, I do not consider this safer for the production personnel. Can someone point out where in the code books that I can find an answer to this problem. I'm open to suggestions.
Thanks
