Previous in Forum: 2006 Toyota Tacoma Drivetrain Vibration   Next in Forum: The Science Behind Windshield Wiper Failure
10 comments
Good Answers: 123
Not Another Cavalier
01/17/2015 1:24 AM
I have a problem with my 2005 Ford Crown Victoria. I can not get the rear door open on the driver's side. Can anyone help?
Bob
Re: Not another Cavalier.
01/17/2015 3:45 AM
Here ya go:
[Pic of Jaws of Life failed to insert]
01/17/2015 8:11 AM
This might get you headed in the right direction.
http://www.idmsvcs.com/2vmod/reardoorrods/index.html
Good Answers: 123
01/17/2015 7:19 PM
Very good informative link. Thanks.
Bob
01/17/2015 9:13 AM
Sure, bring it over here!
01/17/2015 11:22 AM
Have to ask. Is the passenger side door OK?
It's not the police interceptor model?
01/17/2015 11:34 AM
You have to remove the door panel, as best you can, and reach in and manually manipulate the door release mechanism....here's a video that probably won't help at all...but shows the fix...
https://www.youtube.com/watch?v=xYjd4DPEk10
Good Answers: 123
Re: Not Another Cavalier
01/17/2015 7:18 PM
Thanks to all who replied. It turns out I had the same problem as the car in Nigh's post.
The only difference was mine was filled with parts of an old cast iron bath tub.
Bob
01/17/2015 7:27 PM
Legally, that classifies as an Act of God.
01/18/2015 8:08 AM
Were they marked something like:-
"KRIS/SQUIRREL WAS HERE!"?
01/18/2015 11:06 AM
If it is anything like the doors on my Explorer, then there is a spring inside that goes from the handle to a lift bar connected to the latch that has broken. I "fixed" two of my doors just by removing the inner panel, finding the binding post on the linkage, and stretching a silicone rubber band from the handle linkage to the binding post. It's quick and reliable. The spring was only removing the slack and lifting the linkage weight and the rubber band tension is enough.
You may have to yank on the inner handle strongly enough to force the door open from the inside first to get the panel off, but after that it's a 30min job good for several years.
Register to Reply 10 comments
Andy Germany (1); bob c (2); Deefburger (1); kramarat (1); lyn (1); SolarEagle (1); Tom_Consulting (1); Tornado (2)
