Previous in Forum: How to Vary Load for Calculating Fault in DPL Script   Next in Forum: Stainless Steel Shaft of Blower Assy
Star Delta Winding Motor
01/23/2015 1:39 AM
what type of stator winding used in star -delta starting motor.
Pathfinder Tags: motor winding
Re: motor
01/23/2015 1:42 AM
A gazillion loops of varnished copper wire, usually.
Re: motor
01/23/2015 1:51 AM
Sometimes left winded but usually to the right until you turn the darn thing around!
And star same as delta while in total disrespect of the before said the delta is the same as the star one. But only the stator as the rotor winding could go North or South only.
What does your book say?
Re: motor
01/23/2015 3:03 AM
What you could do, Mildred, is list the options and let the others here cross some out for you.
Good moaning!
Re: Star Delta Winding Motor
01/23/2015 9:21 AM
Usually the type specified by the manufacturer.
01/23/2015 2:53 PM
Since all of your prior questions display a complete lack of elementary electrical knowledge, let's start simply.
Is the motor in the northern, or southern, hemisphere?
Will it rotate counterclockwise or clockwise?
Will it be oriented with the stator shaft parallel, or perpendicular, to the equator?
01/24/2015 11:29 AM
As far as I remember, the fields will always be in sets of 3. Either one set = 3 fields, 2 sets = 6 fields. I am personally unaware of more fields, but eminently possible.....
The fields are then connected as star or delta by the starter as required. As far as I remember, starting in Star to reduce the starting current and then switching over to Delta for higher torque.
As far as I am ware, the only speed difference will be with regard to the slip %....unless the starter can switch say six fields in some strange manner to SLOW the motor down, but that is simply a guess from me, there are many others here who will know far better than I.
Register to Reply 6 comments
Andy Germany (1); Crabtree (1); IdeaSmith (1); lyn (1); redfred (1); Tornado (1)
