Previous in Forum: Come On Nukies ... Here's the One You've Been Wanting   Next in Forum: Revalidation of Reliability System
59 comments
Welding Aluminium
01/24/2015 1:30 AM
I am working on an aluminium project, most of the welds will be corner welds not requiring filler rod. The material will be 2 - 3mm thick.
I intend to purchase a TIG welder for domestic supply and would like to learn from the mistakes of others. Suggestions of models would be appreciated and things to watch out for.
I have a MIG welder which I have used previously with some success, but the idea of fusing the corners would be more use on this project.
For gas I would like to use disposable bottles similar to the picture, so as to not to increase my bottle rental bill
Thanks Tony
The nice thing about Standards is there are so many to choose from.
Pathfinder Tags: welding aluminium
User-tagged by 1 user
Good Answers: 50
Re: Welding Aluminium
01/24/2015 7:43 AM
If your looking for some real good youtube video on technique,
welding tips and tricks
Sorry, I don't know your issues with gas bottle rental or title. Here in USA, every state regulates these different, in Iowa, you can rent by the month, or purchase a title to a bottle, and then exchange as needed. This has been my option for Argon, Oxygen, and Acetylene. The title to large bottles are US$250 each. I have not purchased a fill argon bottle in years so I can't quote a price, but I thought it was $40 last time (12 years or so).
The problem I see with your disposable bottle is the pressure can't be anywhere near the 2-3KPSI of the high pressure bottle, and I have no clue how many feet of weld you can do with what must be in the ~150PSI filled bottle. It will depend on how much TIG flow rate, and I've learned that more is better then less. I've overheated a few ceramic TIG cups, that may not be an issue with short duration welds. I try to be frugal too, as argon is not cheap.
Good luck, as the videos make this look simple, and aluminum goes from solid to liquid in a blink, then you touch it with the filler rod, and have a big hole to fill.
ignator -
01/24/2015 8:31 AM
Thank you ignator
I've learned a bit from the link.
We don't appear to be able to own cylinders here, only rent them and I spend considerably more on cylinder rental than gas.
Tony
Good Answers: 50
01/24/2015 9:44 AM
There are states here that will not let you own a bottle (if you want to have it filled with high pressure gas). So I understand not renting.
That was my very short experience (high cost of rental) when I purchased a Miller sycrowave 250 from one of the local welding supplies. I thought I purchased an argon bottle title, which after the first month, a rental fee appeared, that was returned. But that shop has never received another penny of my money, as the sales guy knew what I wanted, and I never saw a rental agreement in the purchase. Later there was a class action law suit against them for exceeding bottle rent fees. The lawyers sent me paperwork to recover $1.20 which they took most of. Funny things to remember.
ignator -
Good Answers: 141
01/24/2015 11:31 AM
The problem with welding aluminium is the start of the weld. Aluminium, especially some older one, tends to build up a oxide layer on the outside which is difficult to break through with your TIG system. It has to do with a lack of electrical (surface) conductivity.
Best welding devices have a HF chopper that is superposed on the regular output to just crack that layer.
Welding aluminium needs also quite some power to heat the spot (locally),since it is a very good heat conductor and easily directs your heat to other places of the material.
The tip of your torch is important too, since the life time depends on it. Welding aluminium by tig needs to go pretty fast and controlled, since otherwise your material becomes liquid and collapses.
An aluminium weld also needs to come to strength again in time. The weld remains weak, sometimes for a couple of days, depending on the composition.
You can also remove the oxide layer by mechanical means (file, sanding)
Plenty of room here
Good Answers: 88
01/24/2015 10:16 PM
I'd go for a low cost HF start (important, to avoid tungsten contamination), AC TIG (cleaning action of partly reversing current is essential for welding aluminium), and would also avoid combination machines like TIG+plasma etc. The newer IGBT technology is advertised as more reliable than Mosfet, but the truth is it can only tolerate a bit worse designs and implementations, so is not critical on its own. I occasionally use a cheap Chinese Mosfet 200a AC TIG, more than 5 years now, no probs. The only luxury I "miss" is variable AC frequency, that slightly changes arc concentration, everything else, pre-post gas flow, current ramp up-down, variable frequency pulsed current with adjustable peaks and valleys, variable AC ratio for adjusting cleaning effect on welding aluminium, etc, etc, all else is there. Now, if you want real, not just CLAIMED, professional reliability, prices START at tree times over that solution, and still most if not all of their parts are of the same origin. S.M.
Good Answers: 92
01/24/2015 10:30 PM
What you need is an AC TIG (DC is not suitable for welding aluminum; the reversing polarity helps burn off the oxidation layer as well as stirring the puddle) with a decent balance control and GOOD fine amperage adjustment. Aluminum requires more heat than equivalent Carbon or stainless Steel, but is very easy to melt through- especially fairly thin stuff.
You also need a water cooled torch for any sort of regular use, as the AC puts more heat on the electrode.
I have a Miller Dynasty DX 200- a fantastic inverter unit that can be carried around, run pulse or different waveforms etc. Inverters are more efficient, smaller and lighter than traditional units and often have input voltage flexibility, but cost more.
My recommendation is Lincoln, Esab, Miller or one of the Thermal air products- note these manufacturers may include other brands, such as Hobart for Miller. Better warranty and servicibility. Get more amperage than you think you need for the day you need to weld 8 mm stock! The Miller syncrowaves are a very common handyman unit.
01/24/2015 10:49 PM
I have used the Dillon Welding torch and it works great on aluminum, There is some techniques to adhere to but very simple. I have not fusion welded with it on aluminum but all you need is some parent material cut in strips for filler rod. Flux is necessary and clean area to be welded with stainless steel brush.. Check it out for yourself..
7
Good Answers: 225
01/25/2015 12:02 AM
A couple of tips that I would offer:-
1. Absolutely clean weld surfaces are critical for good penetration. Any surface contamination will cause you problems (and leaks if it is a tank). I prefer light grinding of the weld surfaces in preference to wire brushing.
2. Use the correct tungsten electrode, so called universal ones don't work nearly as well. Go for either pure Tungsten or Zirconiated Tungsten in preference to the 2% Thoriated ones.
3. Don't sharpen the electrodes to a point, this works fine with DC steel TIG, but AC is much hotter and the pointed electrode will quickly collapse. Just start it blunt and it will form a neat little ball that works fine. The arc will wander if the tip is poorly shaped.
4. I use a 1/8" electrode for most jobs up to around 1/4" thick.
5. You say corner welds - Inside fillet welds will certainly need filler, and outside welds may require the addition of filler from time to time as the weld progresses. Whilst you can use cut bits of material for the filler, it's easier to use purchased filler rods as they are normally nice and clean to start with.
6. If the 2 pieces to be welded are of differing thickness, then keep the arc predominantly on the thicker section. It's best to position the thicker bit uppermost on the workbench so that material flows from that into the weld puddle.
7. For outside corner welding keep the tip of the electrode just clear of the front of the nozzle and use a tight circular motion to form the puddle.
8. Use long arm gloves and long sleeve shirt, radiation burns from AC TIG are very painful.
I use a BOC refillable bottle, I agree that rental charges are pretty steep, but I use it enough to justify the cost. Disposable bottles are dearer in that instance.
As for machines - I use a Tomahawk 200 amp unit that I purchased on Ebay Australia for about $300 a few years ago, came with foot pedal, regulator, handpieces, leads and hoses for both TIG and MMA welding etc. It has performed faultlessly on many welds on both AC for Al and DC for SS, I don't use it for MMA as I have separate MMI and MIG machines for that.
Here's a couple of pics of my unit. The second one gives a bit of a view of the dial settings that I use for GP Al welding.
Hope this helped.
01/25/2015 2:15 AM
Hi all
Obviously contamination is a huge issue, I see flux is available, any comments?
Thank you for the time and effort replying to my post, I have learned a lot and hopefully others in my position can benefit also.
Spades - I couldn't find your exact model, probably superseded.
roy hammy - couldn't find a Dillon torch, but I have heard of them.
HiTekRedNek - couldn't find a glass brush.
Tony
Good Answers: 225
01/25/2015 3:47 AM
"Obviously contamination is a huge issue, I see flux is available, any comments?"
Fluxes are primarily used for gas welding and can be beneficial for TIG if welding different alloys as it does allow a degree of compatibility between the alloys, but it does nothing to remove other contaminants.
The purpose of the flux is to remove the oxide and then prevent it from reforming before the weld has cooled sufficiently to prevent contamination, it does this by dissolving and floating the oxide to the top of the weld pool, but heavier contaminants such as dust etc. will remain in the puddle and be fused into the joint, thus corrupting it.
One of the advantages of AC TIG welding is that the electrode positive half cycle strips the oxide from the material whilst the electrode negative half cycle is what provides the heat for penetration, therefore, provided you have good clean material and proper settings on your machine, fluxes are unnecessary for normal work, but freedom from other contaminants is still critical.
Apart from being quite expensive, Aluminium fluxes are hygroscopic and will deteriorate rapidly, they are also quite corrosive and need to be thoroughly cleaned from the finished weld.
Good Answers: 225
01/25/2015 3:55 AM
"couldn't find a Dillon torch, but I have heard of them"
If you really want one, try under the name "Cobra torches" as they purchased the company some years ago. I don't remember them having any dealers in Australia but that may have changed.
01/25/2015 7:57 AM
The glass brush is made for jewelers as a burnishing tool.
It is probably not what you imagined,it resembles a ball point pen more than a brush.
Amazon has them under the part# 7616SB.
It is packed with glass fibers,they advance as they are worn out,by turning the end like a mechanical pencil.
SE 7616SB Fiberglass Scratch Brush, Pen Type
01/27/2015 12:07 AM
Spade what kind of cracker box welder from China is that you have?
I never could see reason why anyone would buy a piece of disposable equipment like that, can you even get parts for it? A true professional or hobbyist such as yourself would invest in something like a Lincoln Idea Arc 300 / 300 TIG . I guess maybe it is just too American. Just expanding your horizon pal.
Good luck with it.
Good Answers: 225
01/27/2015 1:02 AM
Never let the facts spoil a good story eh.
Lincoln have manufacturing facilities worldwide including in China. Very few of their products are now made in the US and of those, many of the component parts will be made overseas.
I had a Lincoln Idealarc in the 90s, and that was made in Canada.Their MIG and TIG welders for US consumption are now made in Mexico, those for the Australian market are produced in Asia.
Not too American at all are they?
What makes you think that any of those made in Mexico will be any better than the Asian ones? They're all ISO certified, so quality will be similar.
I just checked my purchase date on that Tomahawk welder and it was June 2004, so that's over 10 years of good service from a Chinese product that was less than a quarter of the price of a Lincoln branded unit that may well have come out of the same factory in China.
May not be able to get parts for it now, but would buy another in a heartbeat, and when a control board goes in a Lincoln or any other inverter welder, you're going to feel the pain on your wallet.
Incidentally, Lincoln now market their Plasma cutters under the Tomahawk brand - maybe mine is a defacto Lincoln after all.
01/27/2015 7:31 AM
Pretty good spin you have their ole pal. It reeks of ... well you get the point and does very little for my morning coffee .
Myself as an owner of a formidable manufacturing company it never crossed my mind to buy disposable ....as we are still using some equipment we bought from local suppliers over 25 years ago and yes we get parts and no they are not cost prohibitive. I could safely say I have purchased or leased 100's of weld machines, and so much experience with this alone, to speak from a very professional awareness. When you talk quality and other factoids, I developed some of the record setting pressure, and water depth deployment of pipeline equipment by design, engineering and manufacture and along with what have become API practices, I pioneered these in the first modular subsea system built... not the second but the first. I believe "I am as the company owner" still in Wikipedia for the largest System Integration Test by a manufacturer with the Atlantis subsea oilfield which I designed and manufactured, to the highest quality standards available on this planet.... btw American standards. So I need very little to help about defining quality.....especially when it comes to cheap admittingly disposable welding equipment, or other as to that factor, and especially when it is arrives via a sales rep carrying a knockoff tool pleading to buy using an American Indian Symbol of Toil, as a choice for its moniker made in China....Goes to show just how dependent the world again relies totally on America and getting something for free, I assume, the technology of course came from where?... from the home of the brave and free .....America
Good Answers: 70
01/27/2015 10:15 PM
What, are you trying to piss people off or are you just that arrogant? Or is it you suffer from an inferiority complex? I'm surprised your still in business with your attitude. I find your an embarrassment to America and the American people.
You are the exact opposite of what we the people of the United States stand for.
This is a world wide forum, so who gives a $hit what you think you are.
Good Answers: 225
01/28/2015 2:57 PM
Well I'm both amused and bemused.
Amused at the self indulgent egotistical rantings of a poster who should be seen as a thorough embarrassment by his compatriots, and bemused that his post has been allowed to stand while the only fellow countryman who objected strongly enough to his diarrhetic outburst to say so has been voted down.
Certainly doesn't help the national identity.
If ever there was a need for a "Like/dislike button" - this was one.
01/28/2015 10:39 PM
There have been much time devoted to providing excellent answers and I'm very grateful where ever in the world they come from.
I've ordered some Muggy Weld and will report back with my experience.
Tony
Good Answers: 225
01/28/2015 10:51 PM
Good on you Tony, I will await your report as I too am interested in what that stuff can do.
Some years ago I tried the one where they show repairing a drink can in the ad and I have to say that was about all it was good for.
01/28/2015 11:14 PM
Back in the early eighties, I purchased Lumiweld aluminum 'welding' rods. I used it to repair a buggered up threaded hole in the head of my CB750. Sounds very much like the Alloy 5 of the Muggyweld product.
(Something about a screw extractor that broke off trying to remove a broken stud, then clumsy attempts to remove the broken screw adapter, etc. )
I used a Coleman camp stove to heat up the whole head, then used a MAP torch in the area of the repair. It took a bit of work but I managed to fill the nasty hole, drilled and re-tapped the hole. Worked great. The bike is still running today in the hands of my oldest brother. You do have to 'stir' the molten puddle with a stainless wire or rod to get the stuff into solution with the base metal.
Of course, now that I am smarter and older, or is it smarter because I am older, I would have just drilled out the broken stud and put in a heli-coil, but when I was 19, I was stupid wasn't familiar with the nasty side of screw extractors.
Good Answers: 225
01/29/2015 12:01 AM
My attempt was at repairing holes corroded in an Aluminium alloy fuel tank of a Partner chain saw that had been left sitting with fuel in it for some considerable time.
TIG was too heavy and was burning holes in it.
The solder type stuff was hard to get to attach and then fell off in pieces at the slightest knock.
There was a suspicion that the tank was magnesium alloy which would have explained the lack of adhesion, but a vinegar test proved this not to be the case.
Ended up using JB weld and a couple of pieces of tin to fill the holes and the saw lasted for many more years after that.
Gave me a whole new respect for JB weld.
01/29/2015 2:36 PM
Yours is not the first time I have heard of JB Weld to the rescue when all else fails. At that point what do you have to lose?
Like with many things, preparation of the surfaces BEFORE you make the 'repair' is almost always the most important aspect of the job.
01/29/2015 3:49 PM
Dead right!! I liked your post.
You need to be almost "Hygienically" clean when gluing for example.....
I always use what we call in the UK "Meths" for such work, the US calls it "Denatured alcohol" I believe...
It makes any "gluing" of parts "stick" many times better., simply when both parts are well cleaned first. Meths is also cheap!!
While visiting our "then" manufacturing facility in Palm bay" in 1983, I saw how the gluing of certain metal parts only achieved a bond maybe 2 out of 3 times at best.
So I looked at the process documents the "gluer" was using and no mention was made of cleaning before gluing. The parts had just come out of the machine shop and had dried on cutting oil!!
So I talked to the manager.
The "Gluer" came to me the next day after the process docs were amended and told me that he was now achieving 100%!! Boy was he HAPPY!! He never ever had another failure....
"Cleanliness is next to Godliness" I am told.....
01/29/2015 1:09 PM
Lovely post! Thanks for sharing!!
Good Answers: 70
01/29/2015 12:41 AM
No it doesn't help with our national identity. I sure as hell not going to let this A$$hole represent us American's with his opinions. Most of us "American's" are not self centered and obnoxious as he presented us Americans as.
And being this is a World wide forum,and as an American, I didn't want to let this behavior go unchecked.
I'm surprised that the Admin. left his post standing too. I'm just glad Tony got some really good advice from everyone else.
G'day to you all.
Dan
01/29/2015 1:06 PM
How right you are!!
01/29/2015 5:40 PM
Agreed! Never argue with a pig.He will drag you down into the mud.
And remember:Pigs love mud.
To judge every American by the rantings of an
egotistical,dogmatic,obnioxius,philosophunculistic, socially rude,crude and
unacceptable cretin with a Narcissistic Personality Disorder would be unfair to the
intelligent,kind,generous,tolerant,and altruistic majority of American citizens.
(Politicians and lawyers excepted. )(they are the same everywhere)!
01/31/2015 3:43 PM
Love it!
LOL!!!
Stay well my friend.....
01/29/2015 10:28 AM
I would waste my time answering you, but will just enjoy my coffee instead !
01/25/2015 12:14 AM
The best advice I can give that has not been previously mentioned is in regards to cleaning.
Metal brushes will leave molecular contamination in the aluminum,even stainless steel brushes.
Grinders can leave debri also.Even a Scotchbrite pad can leave contamination behind.
Use a glass bristle brush instead.
Any glass that is left will simply melt and not contaminate the joint.
And remembr,certain types of aluminum are not weldable.
Here is a link: http://www.thefabricator.com/video/pwtv-aluminum-welding-principles-part1
Good luck.
Good Answers: 92
01/25/2015 7:44 AM
I use aluminum oxide sandpaper and discs- yes it is still a contaminant, but specifically what the arc is designed to remove. You can clean with acetone afterwards for a beautiful joint (but don't weld right away!!)
6
01/25/2015 9:13 AM
There is a product that allows you to braze aluminum with the same strength as
welding,but without all the hassle.
It is not the kind you see on tv brazing a soda can.
It is much better.
It will even work on the non-weldable 7xxx series aluminum.
Check out this link,you may be surprised.
http://muggyweld.com/aluminum-welding
01/25/2015 10:26 AM
I am surprised, looks good, may be a cheap option as I have oxy gear. It's available in Melbourne, Australia too. Thanks Tony
Good Answers: 225
01/25/2015 3:36 PM
That product may be sufficient for your needs, but just remember that it is not welding the 2 pieces together as there is no fusion of the metals, it is really a soldering or brazing technique and, despite the claims, will not be as strong as a proper weld.
01/25/2015 4:07 PM
How can you be so sure? Just watching a video?
I was VERY impressed with that metal, it looked really good.....
Furthermore, even if you are right, increasing the area of "soldering" should bring back the strength/stability required.....eg. a minor redesign, MAYBE!
Good Answers: 225
01/25/2015 5:15 PM
How can I be so sure of what Andy?
I'll take my points one at a time.
1. That it may suit his needs? - I can't be sure of that, it may well do so.
2. That it's not welding - I have watched numerous of their videos over time, and they inform you on at least one of them that the process is a form of brazing and that it does not alter the base metal. They also say, and it is quite obvious, that it does not achieve a high enough temperature to melt the base metal, therefore it is not welding.
3. That it's not as strong a weld. - On one of their videos they state a strength of 30,000 PSI, that's considerably less than the minimum claimed for TIG welding of Al alloys.
I'm not arguing that the product does not have its uses, but it is in no way welding.
Google the terms "Weld" or "Welding" for a correct definition.
01/25/2015 5:59 PM
Brazing is considered to occur above 800 degrees F.
Below 800 degrees is considered soldering.
Brazing is not the answer to all cases in joining aluminum,but neither is welding.
Some aluminum types cannot be welded,and others suffer cracking during and after welding.
In a lot of cases,brazing is sufficient and actually better,as in the case of some of the 7xxx types because the heat is lower.
I am sure there are critical situations where the full strength of welding is needed,but in most DIY projects,brazing is adequate.
Good Answers: 225
01/26/2015 12:46 AM
"Brazing is considered to occur above 800 degrees F.
Below 800 degrees is considered soldering."
According to my old texts, Brazing temperatures are considered to be in the range from 1100°F to 1600°F, but in either case we must class that product as a solder as the #1 has a melting point of just 350°F and the #5 at 600°F.
#5 is just a bit higher than the melting point of soft solder but lower than that of hard solder.
Silver solder, which is really a Silver braze, generally melts at temperatures above 1200°F.
Aluminium does not begin to melt or fuse until temperatures in excess of 1200°F are attained.
01/26/2015 3:00 PM
Here is a link to the current accepted( by ESAB) temperatures for brazing vs soldering:
http://www.esabna.com/euweb/oxy_handbook/589oxy19_1.htm
I am sure these temps vary from country to country and company to company.
You are correct in the fact that the temperatures of the Muggy Weld is below brazing temperatures for aluminum,no matter which standard you use.
Aluminum melts at 1221F or 660.3C and does not change color as it is heated.
I have only known one welder that could fusion weld aluminum with oxycetelyne.He would set his mixture very rich and allow soot to build up on the base metal.
Then he would re adjust for normal flame,and when the soot burned off, he knew he was on the fringe of melting the base metal.
I have tried it,but it is very delicate balance,and my results have been spotty at best.
A non-contact temperature meter or a Tempil crayon is best to use now when using true brazing on aluminum.
I have has good succes with Allstate 31 Aluminum Brazing rods,using Allstate 31 flux.
Allstate 31 requires almost 1200 degrees to melt. (about 1100F,If I remember correctly,but it has been a while.) Still, it is kind of touchy.
One instant it all looks good,next instant it's a hole..
If I did it every day,I would get better,but I would rather not get that good at it.
01/26/2015 5:44 PM
I had a friend who flame welded the bodywork or a certain car formula in the 60s that he himself drove, he even used aluminium cut offs as a filler. He was really good. Before even fiber glass was in common everyday usage for one offs.... Alu was also cheaper and less work!!
They looked like small CanAm cars if I remember correctly....
I even saw him flame weld a magnesium bell housing that had been cracked. We all stood around with fire extinguishers, to save the surroundings as we knew that stopping the magnesium burning would be impossible! But it was off the car at least!!
I have never heard of or seen that being done before or since!!
01/26/2015 8:17 PM
To extinguish magnesium,you need a type M fire extinguisher.
It is basically graphite,which steals the heat from the fire and drops the temp below burning temp.
I threw an old VW block on a brush fire,and the aluminum slowly dripped out,then the magnesium ignited.
All that was left when the pile burned out was a puddle of aluminum and a puddle of steel (Crankshat,cam,etc).
01/26/2015 10:06 PM
The secret to this is to use a reducing flame; i.e., extra acetylene to scavenge all available oxygen. Aluminum arc-welding rods are decent filling material; the flux coating also helps.
01/26/2015 3:10 PM
Great comment!
01/25/2015 11:31 PM
Again, thank you all for the time spent answering.
I appreciate the difference between welding and brazing.
This prototype project frame is more about rigidity and lightness than strength. It consists of round tube through holes in rectangular section, attaching stiffening plates to rectangular section and joining corners of folded 2mm sheet.
If the joints are 25% of welded strength, that will be adequate. I can buy a starter kit for $90 and design around its limitations.
If a total novice such as myself can use it.....
Keep tuned to this thread.
Tony
01/26/2015 3:07 PM
I learnt welding, brazing etc., from professionals in the early 60s. I know how and the terminology, though its only been a hobby for the last 10 years or so!
I agree its not welding, but it looks like its strong enough for most jobs. It seems easy to use and if only a propane gas bottle and a torch are needed, its cheap tools as well.....GREAT!!
I had expected that you would come back, and tell me you had used this product and that it failed where welding would be fine.
But you didn't, you haven't used it either, so you only have an opinion, nothing more than what I have!!!
Really funny.....Don't ever try leaning out of any windows!!
I will try and get hold of some of this metal if I need to fabricate something quickly, just to get a feel for how useful it really is.
Then I can post facts instead of opinion, and I will try to be positive when doing it!!
Have a great day.....
01/26/2015 4:52 PM
I did lean out of a car window one time.Got a ticket for mooning!
I've used the Muggy Low temp on radiators,but not their other products on the sheet or cast or pot metal,which is a different temp alloy.
The Allstate 31 is a higher temp,higher strength true brazing alloy.
Everyting has it's purpose.
Muggy Weld update
02/04/2015 1:37 AM
Hi all
In the picture you will see the disasters in lessening order of severity, left to right. The tube is 32mm OD and the plate 3mm.
  1. Couldn't control the heat
  2. Better heat control
  3. Covered in acetylene soot which I used it as a heat indicator, I thought this would contaminate the joint, but it didn't
  4. Changed nozzle to a 12.
I need a carborising flame, with a larger nozzle and less intensity. I removed all the soot either side of the junction and finally concentrated on the junction, made sure the flux was right around the join and dipping the rod constantly.
I estimate the joins would be about $2 each, the kit was A$100 including postage. The kit I used was the Super Alloy 5, it is also available at a lower temperature Super Alloy 1, which I may do the sums to see if that is suitable.
Again, thank you HiTekRedNek for alerting me to it.
Tony
Re: Muggy Weld update
02/04/2015 10:30 AM
You are welcome.
Glad I could help.
02/04/2015 11:19 AM
Nice job. It looks like you got the hang of it. Numbers 3 and 4 are quite respectable. I also appreciate all those that posted their tips and experience. This is one blog that will stay in my "subscription" permanently for future reference because I like so many of the contributions. And since I work in the aerospace industry I have access to craftsmen/artisans down on the shop floor that do absolutely beautiful work. I will forever be in awe at their finely honed skills. I am a weekend hacker zapper and can put together a motorcycle trailer using some channel iron and a stick welder, but that's probably as far as I will ever take it.
Cheers !
Good Answers: 92
02/05/2015 12:48 PM
Thanks for keeping us updated, Tony!
Just wondered what the filler rods are? Reason for asking is that I've got a handful of Gas welding rods sitting around from before I got the MiG and TIG units, they're aluminum sticks with a flux core and wondered if it was like that.
02/05/2015 8:54 PM
Hi JNB
No, it consists of a 35dia x 55 high container of white powder flux they suggest you refrigerate (that went down well with my wife!), I assume to reduce the humidity and 7 off, 3/32" x 18" rods, plain metal.
How did the fluxed rods go!
Tony
01/25/2015 10:21 AM
Unfortunately aluminum welding is one of the more difficult processes to start with, and do correctly, but once you establish the parameters of your equipment on "practice" materials, getting input voltages , gas flow, etc. correct, not an issue that can not be overcome as many hobbyist do not use a written weld procedure (as I do not see where you have an active procedure noted to set the parameters, consumables and variables with). Do not be discouraged, you can do this.
One of the most difficult accomplishments is to see visual changes when the material is going in and out of transformation at the weld pool once you get the "shaking pudding " part accomplished this process becomes much easier , faster and better.
I do not recommend argon as the exact gas , however it will suffice but will trap gas in the weld pool (puddle), thus having micro inclusions of gas molecules, yes it will leak and yes it will easily fatigue. The gas needs to be a Helium / Argon mix this will get rid of this issue whether using TIG or MIG. It will also help appearance of welds due to the trailing effect of solidification, of course this is recognizable after much practice. I am not sure about the disposable bottles but I believe it is available, myself I use commercial amounts anywho.
I generally use aluminum filler wire to do the start off ....period with TIG only (Mig you must always have filler as it is the electrode...) I recommend wire availability for fuse-able material whether at starts, lapping for fused seams or other and keep it available to feed as the weld progresses, getting fuse-able overlap on exterior corners is easily done also, with interior junctions etc. it is a different story.
Practice makes perfect, so don't give up and good luck !
01/25/2015 6:49 PM
I tell you what, this is some interesting discussion and just wanted to comment about this .
This was a great information, like many guys I did my first al weld on my flat bottom..jon boat prolly 25+ years ago and I brazed it with the first al rod made for that, and I was shocked at the quality then and what has come about since. When I read the post today I realized how things change and how we all forget sometimes others have great ideas, and God bless America for all the good people who will sit down and offer someone quality advice, take the time out of their day just to help..I am truly thankful and impressed.
Good Answers: 225
01/25/2015 7:01 PM
"God bless America for all the good people who will sit down and offer someone quality advice, take the time out of their day just to help"
You gotta be kidding me, much of the info on this thread has come from places far removed from the US.
You need to broaden your horizons a little.
01/25/2015 7:18 PM
How are things in Port McQuarrie,, I have a friend in Nelson Bay NSW.. cheers.
Good Answers: 225
01/25/2015 8:19 PM
It's a little like I would expect heaven to be, not that I will ever find out for sure.
Love your country too, been into Canada 5 times, mostly the West coast and only the very bottom of Ontario.
01/25/2015 8:28 PM
My Nelson Bay friend lived in Ontario for 20 years then decided the cold was not to his liking. Went back to OZ and I visited in 90. We call Hamilton our home.. here in Ontario.. cheers & Blessings.
01/26/2015 10:34 AM
The main thing to watch out for is to watch out for cracks. Aluminum welds are not that strong and break really easy. It doesn't handle the same as it does welding mild or stainless steel. If what ever you are welding is going to bear any stress, then you might want to make sure there is some reinforcement. Also, have a bit of filler rod handy just in case.
01/26/2015 12:15 PM
Naw... I am pretty sure it is just God Bless America. should we include the other horizons the USA is always helping ? Sorry, that I did not.
I was being polite and supporting the contributors such as Hytech.... who has really outstanding qualified post here all the time, and because my interpretation was that there was some contention seemingly over his very factually correct post .... I just hated getting to personal, quickly.... oh well.
Register to Reply 59 comments
Andy Germany (8); Brave Sir Robin (3); Cecil (6); dj95401 (2); dvmdsc (1); HiTekRedNek (9); ignator (2); Janissaries (1); JNB (3); roy hammy (3); SimpleMind (1); spades (12); Tonymech (7); Tornado (1)
