Previous in Forum: What is This?   Next in Forum: Warning Bells for Bears?
53 comments
Is a Watt a Watt?
02/06/2015 9:10 AM
If a battery outputs 2 volts and 10 amps yielding 20 watts, is it the same power as a 10 volt and 2 amps? Sounds simple but are there application limitations?
Pathfinder Tags: battery power watt
Re: Is a watt a watt?
02/06/2015 9:13 AM
The power is the same. The loads releasing this identical power are different.
02/06/2015 10:17 AM
Thanks! So a 20 watt bulb would see no difference?
02/06/2015 10:54 AM
What can differ is the lumens per watt, or brightness....then there's the temperature of the light...
http://www.seesmartled.com/kb/choosing_color_temperature/
...then you have radiance and illuminance...
http://www.theledlight.com/lumens.html
02/10/2015 8:29 AM
So why is it the 5700K bulbs are described as "cool", while the much lower temperature, 2700K are considered "warm"? Confuses the heck out of me every time I go to buy an LED light bulb.
02/10/2015 10:04 AM
In interior lighting and in photography, strangely enough, hotter color temperature light is more "blue" and is considered "cool" whereas lower color temperature light is typically more rich in red tone, and is considered "warm". Don't ask me how that got started, it is just what I remember from hanging around with a brother-in-law who just happended to be a great professional photographer in industrial photography, advertising stills, etc.
02/10/2015 10:20 AM
So, basically, the non-scientific types set up the "cool" / "warm" thing based on mood, not reality. I don't trust the various manufacturers to get it right (wrong), so I still check the K rating for the color I want - not the description. Unfortunately, I explained the reality versus description thing to my wife, who has a nursing degree, and now I have to verify which bulb it is we need every time. She's totally confused. She never met Kelvin, and doesn't care to.
02/10/2015 10:43 AM
Yes, Lord Kelvin would probably not be the central topic in Chemistry for Nurses 101. If you think that is bad, my wife is a penny-pinching retired LMSW, and not only do I have to pay attention to the wattage bulb, but also need to watch the color rating, and how the bulb is feeling about being purchased, and also if the bulb has plans for post-release, i.e. living quarters, income level, etc.
Tell your wife if a patient comes in with a temperature of 310.15 °K, to please not panic, as that is precisely 37 °C and is also 98.6 °F. I hope I don't also get you in trouble with my suggestions.
02/10/2015 10:58 AM
Won't even try to tell her - My wife just says about all this - "Why do we need three temperature scales? Isn't one enough?" I doubt she'll ever past Fahrenheit.
02/10/2015 10:54 AM
What you are looking at is the clash of two cultures, artists and engineers.
When looking at the color palette, reds and oranges are considered 'warm' colors, blues and greens are considered 'cool' colors, and yellows and purples are considered 'neutral' colors. When describing lights, a 'warm glow' is always used to describe the reds and orange-yellows of a campfire, while a 'cold glare' would describe the blueish-tinted illumination from a flourescent(1) bulb or the bluish-white light reflected off a snowdrift. These meanings are pure emotion, which is why 'warm' lighting relaxes us (our inner caveman feels like it is relaxing by the campfire) and 'cool' lighting puts us on edge (and why we generally dislike the 'cold, sterile' environment of an examination room). When engineers began describing light, they described it using a tungsten fillament as the reference, naming the light after the heat of the fillament, which is why it is referred to as 'color temperature,' ANY piece of tungstin, in fact any material at all, will glow at the the same color when raised to the same temperature(2).
So because of that culture clash, we have the appearant paradox that 'cooler' temperature's produce 'warmer' colors.
Notes:
1) Yes, I have trouble spelling that word, no, I'm not going to keep fixing it.
2) Assuming the material can reach that temperature without self-destructing.
02/10/2015 11:01 AM
I agree with your (1) - tough bugger isn't it?
Basically as I said - non-scientific set the rules and they are pretty much a "mood" thing.
02/10/2015 12:21 PM
Remember, the 'rules' were set up before we even had any real technology. "Fire warm, Ice cold. Sleep next to campfire, wake up refreshed and ready to hunt for food. Sleep in snow drift, not wake up again."
And thus we learned to associate reds and oranges with warmth and safety and blues and whites with cold and death.
Of course there are always exceptions"
"Now, don't inhale until the tip glows..."
-Harold, the Blind man, from Young Frankenstein, right after lighting the Creature's thumb instead of the cigar the Creature was holding. (The look Peter Boyle, as the Creature, gives the camera right before howling in pain is priceless.)
(Self-marking as OT because we're getting so far off track I think we wandering onto another railroad's property by now.)
Anonymous Poster #2
02/11/2015 2:48 AM
Psycho .. since wrongly red is thought to be hot and green/blue to be cool. Human by nature is contradictory.
02/11/2015 8:49 AM
Says the anonymous lizzard man from outer space being held captive deep within the mountain of Archuletta Mesa AFB.
Engineering Fields - Control Engineering - Newby Member Long Time User Engineering Fields - Instrumentation Engineering - New Member
02/06/2015 11:00 AM
A 20 W bulb has a resistance associated with its construction and use.
The current draw for the bulb (and its subsequent power draw) is thus dependent on the voltage applied to it.
02/06/2015 12:04 PM
Actually, a light bulb is a bad example. The resistance of the bulb increases dramatically from when it is cold to when it is at full brightness, which is why they burn out more often when first turned on.
Back to your question. The battery supplies voltage. The load determines the current, which can be calculated as Current = Voltage / Resistance. So you would have to have different loads (different resistance) to compare the 10 volt supply and 2 volt supply.
Good Answers: 918
02/06/2015 12:25 PM
Yes, it would change!
The formula for power is P = V • I
P = Power in Watts
V = Voltage in Volts
I = Current in Amps
If you take a 60 Watt light bulb and apply the rated voltage of 120 VAC it will draw I=W/V or 60W/120V = 0.5 Amps, which is 60 Watts of power.
If you drop the Voltage to 60 Volts into that same bulb it will draw less current and produce less power.
We can solve that question with another famous equation, Ohm's Law: I = V/R, where R = Resistance in Ohms.
If the first case of 60 Watts from 120 Volts is true, then the resistance is R = V/I = 120VAC/.5A = 240Ω (Ohms).
Assuming the resistance in our ideal light bulb does not change (it really does, but for simplicity we say it doesn't), then at 60 VAC applied to our 240 Ω bulb we have 60VAC/240Ω = .25 Amps.
Now we can easily calculate the actual power produced from the bulb as: P = 60VAC • .25A = 15 Watts.
Notice the power (in Watts) is not the same at.
02/14/2015 12:48 PM
In incandescent lighting, wattage is power usage, not power produced.
02/06/2015 12:39 PM
No, if you use the same load with different voltages then you produce different power outputs. If you use different loads with different voltages you can produce the same power output. This assumes that the loads are linear. There are very cleverly designed non-linear loads that will produce the same power with different voltages. A simple filament based light bulb is not such a clever device. A 20 watt LED or florescent bulb might be a clever non-linear device.
Good Answers: 137
02/06/2015 2:47 PM
There's no such thing as "a" 20-watt bulb. A 10 volt 20 watt bulb has higher resistance than a 2 volt 20 watt bulb. It's not hard to work out the resistance of each, from the formulas others have posted.
02/11/2015 8:54 AM
Well, yes, I see your point, but when it is stamped right on the damned thing, sort of hard to identify it as other than a "20W bulb". You and I may know the difference, but not everyone even needs to know the difference. Yes, if you want a resistor to go in series with a low input impedance AC induction single phase shaded pole motor, you cannot substitute a light bulb for the up potential load, as you might may never draw enough current to spin the motor, however if you eliminate this part of the circuit, you just trip breakers. Therefore, do not remove the motor from 1500 W heater it was built into. It is not designed to operate outside that defined circuit.
That is part of the fun: declare what the circuit is supposed to be and the produce it, and test to see if it operates as declared.
Good Answers: 137
02/11/2015 9:38 AM
I'm not sure I see yours ! Where do the motor and heater come from?
I was just replying to OP's #4. But bulbs are (or should be) stamped with the voltage as well as wattage. If the user doesn't give it the right volts it won't give the right watts.
02/11/2015 9:47 AM
My stupidity lesson came from taking apart a space heater, and attempting to scavenge the fan motor from the circuit by wiring it direct to attemperate a testing enclosure I needed. After tripping the circuit breaker on the wall I couple of times, I next tried various light bulbs, but alas none were highest enough power rating to provide the needed current for that motor, as it only has about 10 loops on the core.
Just because it is a motor, does not mean it is or was ever intended to be directly coupled to a power source as its own independent circuit.
Anonymous Poster #2
02/11/2015 2:18 AM
It would see.. it would burn off. the voltage is applied (pressure) and current is the result (flow). the circuit is the pipe line. When you put 20 V, the current of 1 A means you have 20 ohms. When you put 2 V pressure, the current will be only 0.1 A. So same bulb doesn't work in the two cases marinating the V & I as you wish, to have the same power output. In a system, V,I,P are dependent variables, and the system configuration will define how much maximum voltage (through insulation) or current (conductor cross-section) can be applied.
The system defines the impedances (active and reactive components), Z
Then based on
V = IZ
P= V.I. = I2R = V2/R
You don't have any control, and only one you can. So with the different applications 20W bulb doesn't remain 20W It generates less light (Voltage reduced) or burns off (current forced).
Re: Is a Watt a Watt?
02/06/2015 10:05 AM
P = V * A , or
P = A * V
It's not complicated.
02/06/2015 10:12 AM
IS the same my friend! power is power.
02/06/2015 3:22 PM
WHAT!?
02/09/2015 9:27 AM
Oh please, that Watt/What joke is so old it has no power left.
02/10/2015 8:11 AM
You still laughed.
02/10/2015 10:32 AM
Did I? Or did I respond with a counter-pun?
If you really want to see what's watt, you need to reduce your resistance to current events and amp up your sense of humor. You'd be amazed at what a little reversal of bias can do to transform your very way of thinking, you could even feel like your mind could volt over the moon.
(Ugh, I just don't seem to have the capacitance for extended jokes today. If I were working the Borscht Belt, this act would have tanked in the middle of the circuit.)
02/10/2015 10:35 AM
You sound like an old punster friend of mine from Champaign-Urbana. If your first name is Alex, just nod, rather pun twice.
02/10/2015 12:04 PM
I am not your old friend Alex, although I have the feeling I would enjoy meeting him.
03/03/2015 11:40 AM
I just stumbled across this thread again, and I'm looking at my pun-post, re-reading it with older, wiser eyes (so to speak). I can't help feeling that my last pun completely failed, that I stretched too far to work 'tank circuit' in there, and nobody could see what I was setting up.
Was that last pun Dead on Arrival? If so, I apologize.
Good Answers: 92
02/06/2015 5:14 PM
Yes a power output of 20 watts is the same, regardless of how you arrived at that. And yes, what you can do with that 20 watts depends upon the application- the voltage has to be suitable for the desired usage .
02/06/2015 9:25 PM
No, a watt is an HP, Joule/sec, Newton meter per second
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
02/06/2015 10:32 PM
Those are all units of power but there is an important scaling factor difference.
It is just like the difference between being paid two hundred dollars, two hundred pennies, two hundred yen and two hundred lire. They are all units of money but they all have different values.
02/07/2015 9:05 AM
I know how you got your ihs name. Coz your at the first level of defense, Lol.
Good Answers: 137
02/07/2015 4:38 AM
2 out of 3 correct. Must try harder!
02/07/2015 9:03 AM
May be next time perfect, when i get to reflect on receptacles and orifices hahaha;)
02/06/2015 10:54 PM
20 watts is 20 watts however produced. If 20 watts is turned to heat with 100 % efficiency then the work done to produce that heat is 20 watts. The work done by 2 amps at 10 volts will be the same as the work done by 20 amps at one volt, the time taken will be different. Careful when you pass 20 amps at one volt through a conductor. Remember W= I squared R so resistance will be 05 ohms at one volt. You will have sparks. At 2 amps 10 volts the resistance will be .5 ohms. The work that both sources can do will be the same. If the supply is AC then one must use RMS values.
02/06/2015 11:43 PM
(Taking the question seriously) An analogy using water might be revealing. Imagine lifting a gallon of water through 10 feet every minute - that's a fixed work rate (equivalent to Watts). You might use a small pipe with high flow velocity or a big pipe with low flow velocity. They both achieve the same work rate but have different characteristics which have to be chosen to suit the equipment used.
02/07/2015 6:15 AM
good comparison
Good Answers: 58
02/07/2015 8:42 AM
In the steady state, your descriptions produce identical results. However, there are transients involved in turning loads on and off. These important classes of loads (such as welding) are game changers as they involve dynamic loads and impedance matching. These classes of loads follow different rules, and not necessarily ohms law.
02/07/2015 10:29 AM
For the unwary novice perhaps yes '...These classes of loads follow different rules, and not necessarily ohms law..'
but for the purist, every electrical circuit obeys ohms law - there are no exceptions.
Good Answers: 27
02/07/2015 10:10 AM
The power capacity for both will be the same 20 watts but not interchangeable!
The battery that can supply the 2 volts-10 Amps will be a Different type as compared to the 10 volts -2 Amps battery...
The load to be connected will be your application's limiting factor...
vsar
02/07/2015 12:20 PM
No the bulb will not light at 2 volts and 10 amps if it is designed to work at 10 volts and 2 amps. If it does light it will be a very dim glow. To understand power (watts) you need to understand OHMS Law first. Think of a pipe and water running through it. The larger the pipe, the more water can run through it. The water is the current (I in ohms law) The pressure or force that is pushing the water through the pipe is representative of Voltage (E or Electromotive force) in Ohms law. If you convert say a 4 inch diameter pipe into a 1 inch diameter pipe, there is less water flowing. This restriction becomes the resistance in Ohms law. This is the explanation I use when instructing people desiring to become amateur (ham) radio operators.
I used to have a cute cartoon that pictured the relationship, but unfortunately can't find it right now.
Therefore E=I x R if E equals voltage
I = current
R= Resistance
02/07/2015 1:34 PM
Fundamentally you are correct, that P=I*V (P= power, I= current, V= voltage) for a simple DC circuit. This is only true if the load (resistance value) is changed from the 2 V situation to the 10 V situation. If it assumed that no change in temperature takes place in the load (i.e. heat is removed), then when V=2, I=10, and R has to be V/I = 0.2 Ω . But when V is changed , V=10, I=2, and R is now V/I= 5 Ω.
If one assumes a tungsten drawn wire filament inside an enclosed light bulb, the situation is not the one where heat is being removed (until the filament reaches a radiative steady state, or melts).
Thus, further suppose this filament is 0.2 Ω at 20°C. Let's attempt to estimate some things about this filament: Tungsten drawn wire has a resistivity of 5.6 X 10-6 Ω-cm.
If the filament has a cross-sectional area of (this is just an assumption) 0.0025 cm2 (0.0564 cm diameter), then the resistance value would be 0.00224 Ω/cm. The filament length required is 89.29 cm, which is a bit too long to be "practical".
Alright we reverse our tracks, and now we define maximum filament length as 5 cm. What will be the required diameter of the filament? We have 0.2Ω/5 cm = 0.04Ω/cm length resistance. 5.6X10-6/0.04 = 0.00014cm2. This wire diameter is now 0.1335 mm.
Our 0.2Ω filament will dissipate 20 W (adaibatically at first) when 2 V is applied. According to data on tungsten drawn wire, the temperature coefficient (β) is 0.0045 ,which is given as per degree, thus it represents a fractional change in value of resistance for every change of 1 degree, be definition.
For the same source to output 10 V @ 2A, and 2V @10A, we should attempt to solve for the Thevenin source output resistance. If we assume (for the moment) that this resistance is small compared to 5 Ω, then Voc~10V, and Rth~(10-2)/10=0.8Ω, so the assumption is pretty good in this limit. Then effectively the same power supply can provide the needed current over the range of resistance values of the filament during this experiment.
So what happens to the filament? Since it is being warmed adiabatically, we can estimate its temperature when the resistance reaches the 2 A point, namely 5Ω, approximately. The resistance ratio is 5/0.2 = 25. 25/0.0045 = 5555 °C change above 20 C! Since tungsten melts at 3400 °C, we see that the filament should melt. But we did not allow for radiation power. The filament can dissipate some of the applied power by radiation (that is what makes it a light bulb), but then the resistance would never reach 5Ω!
Now you should be able to see why it would be impossible to fulfill both load conditions with the same filament, if the filament is in fact tungsten. We impose a new condition: namely that the filament at 5Ω is (1) in thermal radiative equilibrium, and (2) is dissipating 20 W by combination of resistive heating and radiating power. We further assume a second boundary value that the filament must be 0.2Ω at 20°C.
For a black-body radiator with 1.0 emissivity, and 0.1 cm2 area, the temperature for 20 W total power of radiated light is 2163.9°C. Our filament now is defined such that it must change temperature by a total of 2143.9 °C from cold start up at "room" temperature. The temperature coefficient is now defined as well: 5/(0.2*2143.9)=0.011661/°C There is no metal listed with that high of a temperature coefficient.
I have used an alternative calculation method of employing the temp. coeff., but the values will come out pretty close as a first approximation.
02/07/2015 2:25 PM
A very good analysis of a low voltage filament light bulb. Kudos.
However, it appears from the nature of the question from the OP that Ohm's Law is a new concept. Your "spot on" analysis is so far over their head they probably cannot see the landing gear, let alone buy a ticket for this plane ride.
02/13/2015 7:56 AM
Hahaha, there is actually 3 idiots giving you GA in here. You seemingly sounds right though. The worst thing is you dont start right, clueless- Dearth Vader How is your Voltage and current dictate your resistance on the circuit. Ohms law is a reversible equation, however in reality. It can not be, to any system I follows with mostly on circuit load or resistance and supplied voltage. V could be anytime equals to I*R but, reality is current is a follower to Resistance. At your tungsten filament anology, isothermal process, using 10V and 5 Volts, R is fixed on what ever voltage you might have as long as its wattage is good it will work. There are cases were you have a current supply though how you may force to supply certain current on the circuit, system resistance is not dependent on it. Resistance is intrinsic in the material or any system resisting current flow. How do you define resistance then?
02/13/2015 9:05 AM
No, a fixed resistance impedance is actually a very rare device. In fact I do not know of any fixed resistance devices at all. Take the simple 470 ohm 1/4 watt resistor as an example. In many applications this component will vary its resistance such a small amount with nominal operating temperatures that many would consider this a permanent fixed value device. However, apply the common industrial controls voltage of 24 V across this component and the resistance value will change quickly.
I will leave it to the student to figure out the simple mathematics why.
PS. It is wiser to try and figure out why three people felt an answer merited a GA tag than to call them idiots because you do not understand.
Good Answers: 225
02/07/2015 8:58 PM
Geez... You guys really know how to take a simple question and turn it into a major event.
The OP has probably buried his head in the sand by now.
The question had nothing to do with lamp filaments or any other type of load.
The simple answer to the actual question is that in either example given, the same wattage will apply and it will do the same amount of work.
It may not achieve the same result in any specific load, but that is another exercise.
02/07/2015 10:17 PM
Where have I heard this before?
02/09/2015 9:12 AM
To our original poster, as you read through all of these you can easily see the difference in the amount of actual work electricity can do as illustrated in words. Here you will find examples of voltage, amperage, and of course resistance. ;-)!
02/10/2015 8:10 AM
I think it would be fair to say that we have expended a considerable number of watt-hours on this by now.
Register to Reply 53 comments
adreasler (6); Anonymous Hero (1); Anonymous Poster (3); BDThompson (2); Codemaster (3); delreer (1); friday38 (1); horace40 (1); James Stewart (9); JNB (1); Kulas (4); Munster (1); NeilA (1); Phys (4); prof peanut (2); rashavarek (1); redfred (6); Rixter (1); SolarEagle (1); spades (1); vsar (1); welderman (1); WonTon1 (1)
