Previous in Forum: Oceans of Energy   Next in Forum: Material Selection Diagram
9 comments
Polymethyl Methacrylate
02/06/2015 10:18 AM
Hello!
I am wondering if there is an additive I can use to maintain the Polymethyl Methacrylate either on liquid form or gel form between the range of temperatures -45 to 300 F.. I need this becayse reaserch chows that this compound on liquid form allows for high efficient light transfer (like a optical cable). but I ma trying to transfer about 100K lumens 25 ft.
Thank you very much.
Pathfinder Tags: Methacrylate
Re: Polymethyl Methacrylate
02/06/2015 10:51 AM
There are other clear materials that could be used, such as clear silicone rubber, that will maintain flexibility over a much wider range than PMMA. The difference between them, for attentuation over a distance of only 25 feet, is pretty low.
Why not use a fiber optic cable? Or a bundle of them? If you are transferring this light over a larger area than the cross-section of a fiber optic cable, why not use a tube with a mirror-like finish on it's interior? Such as a SolaTube: http://www.solatube.com/
02/06/2015 11:21 AM
The solar tube was very interesting, but this application required a medium that is flexible. This is going on a light tower whose height will vary all the time.
02/06/2015 11:55 AM
Maybe you could use the Solatube to conduct the light part of the distance, including a section of telescoping tubing that can be lengthened/shortened as needed. Then use a flexible conduit for the remaining distance.
02/06/2015 6:43 PM
PMMA is a liquid monomer. Kept pure, it should not polymerize.
02/07/2015 10:29 AM
At one point long ago when I worked with DuPont's nylon production facilities, my office mate worked on the PMMA facilities. I don't know what the additive was that was used in the intermediate for transportation to our facility (in rail-cars), but it had to be removed before polymerization.
02/07/2015 1:16 PM
No dummy, that's MMA. Get your facts straight!
02/06/2015 11:56 PM
oh, the sun is even closer around here, more like a poppycock
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
02/07/2015 9:04 AM
Poly(methyl methacrylate) (PMMA) is a transparent thermoplastic often used as a lightweight or shatter-resistant alternative to soda-lime glass.
Read more on Wikipedia
CR4 Admin - direct copy/paste of Wikipedia page removed
02/07/2015 10:00 AM
Oh boy, oh boy, this is cut and paste from the book.
Register to Reply 9 comments
delreer (1); Dr. Harry (1); Kulas (2); lyn (2); Usbport (2); ZakariaSalim10 (1)
