Previous in Forum: JIS 5K/10K Rating   Next in Forum: Query - General Finishing and Surface Treatments Applied to Gauges
Chemical Composition
02/10/2015 1:04 PM
Dear All,
I need some information about chemical composition of IS 2062. As in this standard only maximum values are there. can i know how much is minimum values also. and in the example the values which i have given if accepted can this material be used in transmission line towers.
(example: carbon 0.18%, manganese (Mn) 0.40% is this material is accepted or rejected as per IS 2062. But, mechanical properties are passed.)
please help me for this information. as i need urgently these values.
CR4 Admin - email address removed
Re: chemical composition
02/10/2015 2:28 PM
After using an internet search engine to find out, do let the forum know the outcome.
Re: Chemical Composition
02/10/2015 2:57 PM
This is pretty exhaustive for chemical composition:
http://www.marylandmetrics.com/tech/chempropi.htm
I do not know about the standards you are referring to for material in transmission line towers, you will have to refer to local codes and laws.
If you need more info about +/- % of chemical composition you could call a supplier and they can get that information to you from the mill.
02/10/2015 5:04 PM
Urgent? I thought that was what the telephone was for. Try ringing a few suppliers.
Good moaning!
02/10/2015 5:49 PM
Please, oh please, oh please, oh please, oh please tell us that you are not building transmission line towers.
If you are, can you tell the forum who the customer is??????
Good Answers: 103
02/11/2015 12:52 AM
The values are given as the target values. For the limits refer clause 8.2 . And note that since these are structural, the ceq has to be adhered to. And lastly if you try to go too far away from the target value, even within the tolerance band, you might not be able to satisfy the mechanicals, including impact which is as I remember mandatory now.
Good Answers: 103
02/11/2015 1:04 AM
But remember in the end you need the mechanical properties of the material (limits specified) and the weldability (Ceq). The steel you mentioned on thumb-rule calculation doesn't look to be able to achieve the mechanicals, unless alloying elements are added up, which would then impact the impact properties.
Crabtree (1); lyn (1); Massey (1); PWSlack (1); sb (2)
