Previous in Forum: Chemical Composition   Next in Forum: Miniature W-32 Engine is Mind Blowing
25 comments
Query - General Finishing and Surface Treatments Applied to Gauges
02/10/2015 2:01 PM
What are the general finishing and surface treatments applied to gauges and why?
3B!!!
Re: qUERY
02/10/2015 2:09 PM
Well, most gauges of shotguns are blued steel, intended to be a rust inhibitor.
Is there perhaps another meaning of gauge that you or your instructor are interested in?
Re: qUERY
02/11/2015 4:11 AM
He is proned to limit gauges especially Gauge Block
3B!!!
Re: qUERY
02/11/2015 8:39 AM
On gauge blocks and limit gauges, corrosion would most certainly render them inaccurate, eh?
Exactitude... in measurement as in communication. Perhaps polish both of these tools for better, more reliable results.
Re: qUERY
02/10/2015 2:21 PM
What an excellent sentence to type into an internet search engine, such as Google. Do let the forum know the outcome.
Re: qUERY
02/11/2015 4:10 AM
Google too has got limitations :(
Still havent found the right answer. :(
3B!!!
Re: qUERY
02/11/2015 11:01 AM
You get the right answer by finding it yourself.
Expecting others to furnish your answers to you is a sure sign of a failure waiting to happen.
Re: qUERY
02/11/2015 1:47 PM
Got it ;)
3B!!!
Re: Query - General Finishing and Surface Treatments Applied to Gauges
02/10/2015 3:35 PM
From your own profile.....
I want to polish myself and always be remembered in good books .
You need to at least perform your own basic research first before asking us. Bad habits now will result in bad habits latter on in your career and pictures of us in those books instead.
02/11/2015 10:53 AM
Thanks for awaking me ;)
3B!!!
02/10/2015 5:01 PM
Pressure gauges.
Marking gauges.
Feeler gauges.
Wire gauges.
Track gauges.
Temperature gauges.
Thickness gauges.
Nope. I just don't get it.
Good moaning!
02/10/2015 5:04 PM
I'm a big fan of WD-40. Works with many to most gauges.
02/10/2015 5:10 PM
OK. There's some in the shed. I'll get it and try it out.
Good moaning!
02/11/2015 1:13 AM
Oh boy, oh boy I like "feeler gauges" sounds emo to me.
"When I thought I exceeded to be wise but wisdom was far from me" -King Solomon
02/11/2015 10:54 AM
Sorry man ;)
Limit gauges is the subject ;)
3B!!!
02/10/2015 5:15 PM
Surely a student of BSC Industrial Engineering at Punjab University, Lahore Pakistan can operate a search engine.
I believe that you can because you found this obscure web site, populated by very intelligent people, most of whom got that way by doing their own homework.
As has already been explained "gauges" has dozens of meanings.
Johansson gauges can be finished to a tolerance of ±0.05 μm.
These are created by grinding and lapping.
So, go back to the books and find out what grinding and lapping are.
Extra credit will be given if you can describe "wringing" as well.
02/11/2015 10:58 AM
Lolz indeed i have done my research man.
Just wanted to consult the best from the world.
Hope you didnt mind
3B!!!
Good Answers: 16
02/10/2015 10:34 PM
More information required.
Are we discussing screw gauges or sheet metal gauges?
BAB.
Make it so.
02/11/2015 10:54 AM
Limit gauges
3B!!!
Good Answers: 16
02/11/2015 9:38 PM
What sort of limit gauges?
These come in lots of different flavours depending on what you want to limit.
BAB
Make it so.
Good Answers: 203
02/10/2015 11:41 PM
Are you asking about railroad track gauge? In the US it is 4' 8-1/2", 1,435mm. In India they use four different gauges: 1,676 mm (5 ft 6 in) Broad Gauge; 1,000 mm (3 ft 3-3/8 in) Metre Gauge; 762 mm (2 ft 6 in) Narrow Gauge; and 610 mm (2 ft) also Narrow Gauge.
No, there is no direct railroad lines from the US to India. That negates the need for the US gauge in India.
Good Luck, Old Salt
02/11/2015 10:56 AM
Thanks..
3B!!!
02/11/2015 12:23 AM
The finer the prettier the more money. Anything else?
02/11/2015 10:13 AM
Probably anodized. Especially if the Gauge housing is aluminum.
Good Answers: 19
02/11/2015 9:30 PM
Wringing.....................that's a term/exercise I haven't used in forever.
And no I ain't gonna tell him what it means..................................yet!
02/11/2015 10:22 PM
I worked with old school model makers 40 years ago and was amazed when one of them showed me how to use Jo blocks, and pin gauges.
Register to Reply 25 comments
babar bilal (8); BlueAussieBoy (2); Crabtree (2); Doorman (2); jack of all trades (2); Janissaries (1); Kulas (1); lyn (3); old salt (1); PWSlack (1); Tornado (1); Wrench twirler (1)
