Previous in Forum: Difference Between ASTM A193 B8M CL.2 & ASTM A320 B8M?   Next in Forum: What Does The Term MTB/HR Represent In LPG Flow Reading
11 comments
Steam Consumption
02/16/2015 8:00 AM
For a single stage Steam Turbine driven Centrifugal pumps, we have found at site that the steam consumption is almost 1.4 to 1.5 times higher than the guaranted figure.
Pump was performance tested at vendor works and the shaft power is correct.
Inlet steam and outlet steam pressure values are also correct. Also, based on Inlet and Outlet Pr./Temp. condition and relevant Enthalpy and Guaranteed Power value, the calculated steam mass flow rate is matching with the Steam flow rate guaranteed by Vendor.
Turbine is back pressure type.
expecting expect opinions.
Re: Steam consumption
02/16/2015 8:20 AM
What was the vendor's opinion when you called them?
02/16/2015 9:01 AM
Call the vendor.
Expect to give him some useful information. He can't read your mind either.
02/16/2015 9:39 AM
I expect you to stop posting as ANON, fat chance of that too
Good Answers: 140
02/16/2015 9:57 AM
You must be using light water instead of normal water. Light water has less power to it when used as feed water in a boiler. Try using heavy water.
Seriously... call the OEM.
02/16/2015 10:24 AM
Dear Friend,
Pl. inform the following.
1. Does the Turbine has the Curtis Wheel.? For single stage Turbine, it is a must. If not the Heat Drop across the Turbine Blade will be less and hence more Steam Consumption.
2. Shaft Power is different from actual power required since Pump Efficiency is involved.
3. Please furnish the name plate details of the Pump and Turbine.
Possible cause could be the steam may not fully pass through the Turbine Rotor. Pl. check the same.
DHAYANANDHAN.S
02/17/2015 11:50 PM
Your point no. 3 couldd be a reason but, How this can happen in single stage Impulse turbine ??
Potential max. power of selected Turbine is 1.5 times higher than the Guaranteed Power.
Steam consumption is also 1.4 to 1.5 times higher than guaranteed Power.
Both are inline. But, Pump is running at Guaranteed Capacity.
Is the Nos. Steam Nozzles as well as the angle of steam Nozzles to Rotor Blade can create the problem of high steam consumption ??
Is the Selected Turbine Model of Higher rating than the required can create such issue ??
share your opinion.
Good Answers: 11
02/16/2015 11:24 AM
Might be
1) instrumentation problem--check calibration
2) your calculation
3) efficiency of your turbine has been degraded.
02/17/2015 11:42 PM
As it is a single stage Turbine - between bearing type , in case if the Rotor of Turbine (Impulse turbine) installed in wrong direction is that can create the problem of high steam consumption ?
Turbine can rotate in same direction of rotation as required but, the losss of steam (not passing the Rotor) shall be more.
I think this shall also be checked.
Share your opinion.
Re: Steam Consumption
02/18/2015 1:54 PM
You did not state what you are pumping.
If the fluid being pumped is more dense than water, there is the extra steam consumption requirement. Last time I checked pump power requirement is not quite linear with respect to density of the fluid.
02/18/2015 10:27 PM
Its BFW Pump.
Parameters related to Pump Operating condition are found ok.
02/19/2015 10:07 AM
If the temperature of the BFW is elevalted (after passing through feed-water heaters), there may be a compressive penalty, but I am not aware of that as long as the incoming pressure of the water and output pressures are accounted for along with the slight changes in specific volume of the fluid being pumped.
If errors are present in the measurement of steam parameters driving this turbine driven BFP, you need to understand this could make apparent steam consumption higher than "design", or if you have over-estimated the steam T,P, of course the consumption figure will be higher than the projection of use.
Anonymous Poster (3); dhayanandhan (1); Fredski (1); James Stewart (2); lyn (1); North of 60 (1); Noudge79 (1); Tom_Consulting (1)
