Previous in Forum: Galvanic Corrosion   Next in Forum: Device 87 Operation
Control Loops
02/20/2015 1:19 AM
Hi Guys,
I have a doubt here. My view is that if we have input and model, then it is possible to predict the output of any system. I dont know whether this understanding is correct. I work with PV, SP and OP data of processes and I am able to collect the data only for particular amount of time. For ex, i have PV SP data for 1000 data length, i have got the model of the system using this 1000 data points. I also have to do some analysis based on this data, in which my algorithm requires 5000 data points. My question is I have model of the system and SP (input which i will give) , so is it possible to get the PV (output) of the system? If yes, please explain. If i get the answer for this question, then i have some more qustions.
Re: Control loops
02/20/2015 5:30 AM
Yes, it is. Recommended reading: "Process systems analysis and control", by Coughanowr and Koppel, any edition.
Re: Control loops
02/20/2015 5:51 AM
Thanks Sir.Let me put the steps that i have followed for calculating/finding the output. From the model, i will be getting the numerator, denominator of the system. Using inverse laplace transform, I will get the time domain relation between my SP and PV. This approach is hope so fine. Please know your comments.
And I have a another doubt also. When we work with the real time systems, performance will vary for different regions. So if we model the system in a region and if we use the same model for predicting/estimating the output in some other region, will it give better results?
Re: Control loops
02/20/2015 6:23 AM
A1: sounds reasonable.
A2: most real-world systems are non-linear. It is up to the Engineer to select gain, integral and derivative to give the best overall combination given the process conditions. Some will require "fastest response to disturbance", whereas others will require "no overshoot"; the control terms are different for these two extremes of response.
Re: Control loops
02/20/2015 6:05 AM
If it's a linear system, yes. Nonlinear systems can be a bit chaotic!
http://en.wikipedia.org/wiki/Chaos_theory
Good Answers: 25
Re: Control loops
02/20/2015 11:50 PM
ALL systems are, more or less, non-linear; that is why equipment has calibration procedures and adjustments. The trick in any situation is to select the correct equipment and adjust it so that it does what is wanted. These are just about the only reasons that engineers are still in demand.
Re: Control loops
02/20/2015 6:58 AM
Thanks for the reply.
If non linear, wat are the methods available for my query? Experts please help
Good Answers: 122
Re: Control loops
02/20/2015 10:28 AM
Modeling is a good way to develop a default set of parameters for startup however you must "loop-tune" the system instrumentation in the field application to offset process and environmental dynamics present at each location.
Register to Reply 7 comments
Ed Watts (1); PWSlack (2); Rixter (1); sakthipriya (2); SHOCKHISCAN (1)
