Previous in Blog: Houses in the Valley: CR4 Challenge (08/18/09)   Next in Blog: Flat Mirror: CR4 Newsletter Challenge (09/01/09)
Triangle With Rectangle Insert: CR4 Challenge (08/25/09)
Posted August 23, 2009 5:01 PM
Given a rectangle CFKE of any given sizes of 1 to 10, and located in a right angle triangle ABC, such that the hypotenuse AB touches the corner of the rectangle at E. Show how to construct a triangle ABC using only a compass and straight edge, no measuring instrument to be used. The hypotenuse length being any combination of sizes taken from the rectangle, the chosen length for the hypotenuse AB being greater than the length that would be a right angle with the rectangle diagonal CE, and referring to the construct, show how to calculate angle CAB, such that using the formula (FE/Sine A ) + (EK/ Cos A) = AB, show that AB is correct to within three decimal places.
Special thanks to jdretired who supplied this week's challenge.
And the Answer is....
We will present two solutions to this problem. There may be more solutions given the fact that this is a geometric construction problem.
SOLUTION 1:
Step 1. The solution concept outlines a number of rules. If a circle is drawn around the triangle ABC, from point O at the centre of AB, such that it touches all points, and a line CE extended to intersect the circle at D, and D used to form a triangle ABD, the triangle ABD is a simular triangle to CEF, and if a rectangle EGDJ is drawn within the triangle ABD, then the triangle EDG is a simular triangle to ABC. Also if line CD is taken as the base line, then the heights of points F and G are the same, both equal (h = 2.4). And lastly if lines AB, FK and GJ are extended, they all intersect at L, the position of L varying with length AB.
Note: The following solution holds true for any rectangle who's side measure any where between 1 and 10. And angle CEA is equal to or greater than 90 deg.
With the above concept rules in mind we construct the triangle ABD on a base line equal to the chosen length of A,B, in STEP ONE the chosen length A,B = 11, A,D = 8.8, B,D = 6.6, D,W = 5.28 and B,W = 3.96. We then solve by a number of feed back loops, to locate point C. this is done by establishing a number of POINTS, the location of a POINT is referenced by X, the horizontal distance from B, and Y, the vertical distance from B.
Step 2. Draw line B,N, being a tangent of the small circle of radius 2.4, then draw a second line parallel to B,N off set by 2.4 to intersect line A,B at P1. With compass set to Radius 3, from centre P1 intersect line B,N at Q1. With compass set to radius 4, from centre Q1 intersect the circle at point T1, draw a line from B to T1, and a line from P1 to Q1 which is extend it to intersect line B,T1 at POINT2.
MATHS
POINT1 X1 = 0. Y1 = 0
Angle D,B,N = Sine 2.4/6.6 = 21.323686 deg.
Angle N,B,P1 = 53.1301 - 21.32369 = 31.806416 deg. B,P1 = 2.4/Sine 31.80642 = 4.553639.
By Cosine rule ( 3, 4.553639, Cos 21.323686 ) .B,Q1 = 2.069836.
By Cosine rule ( 5.5, 2.069836, Cos 31.806416 ) .Q1,O = 3.896799.
(Q1,M)^2 = 4^2 - (5.5-x)^2 and (Q1,M)^2 = 3.896798^2 - x^2 therefore x = 2.67591.
Using x, angle Q1,O,M = 46.6309 deg.
By Cosine rule (5.5,3.896798, Cos O = 2.0669836) Cos O = 16.25724 deg.
Therefore angle O,B,T1 = (180 - (16.25724+46.6309) )/2 = 58.55593 deg.
By Sine rule (Point2,B,P1) B,POINT2 = 1.68204.
X2 = 1.68204 * Cos 58.55594 = 0.87746, and Y2 = 1.68204 * Sine 58.55594 = 1.43503
POINT2 X2 = 0.87746, Y2 = 1.43503
Step 3. Draw a line B1,N1, being a tangent at N of the small circle of radius 2.4 and passing through POINT2, draw a second line parallel to B1,N1 off set by 2.4 to intersect line AB at P2.
MATHS
POINT2,G = 3.96 - X2 = 3.08236. D,G = 5.28 - Y2 = 3.84497.
Distance between POINT2 and D = square root of ( 3.08236^2 + 3.84497^2) = 4.927955.
Angle D,POINT2,G = Cos 3.08236/4.927955 = 51.282232 deg
Angle D,POINT2,N = Sine 2.4/4.92795 = 29.144736 deg
Angle G,POINT2,N and angle POINT2,L,P2 = 51.282188 - 29.144766 = 22.137496 deg
Angle B,POINT2,L = 180-((180-58.55592)+22.137496) = 36.418424 deg
Distance between L,P2 = 2.4/Sine22.137496 = 6.36891.
By Sine rule (1.68204/Sine 22.137496 = L,B,/Sine 36.418424) L,B = 2.64997.
Therefore B,P2 = 6.36891 - 2.64997 = 3.718941.
Step 4. With compass set to Radius 3, from centre P2 intersect line B1,N1 at Q2. With compass set to radius 4, from centre Q2 intersect the circle at point T2, draw line B,T2, and line P2 to Q2 which is extend it to intersect line B,T2 at POINT3.
MATHS
Angle B,P2,Q2 = 90 - ( 22.137496 + 36.8699 ) = 30.992606 deg.
O,Q2 By Cosine rule(3,(5.5 - 3.718941),Cos(180-30.992606)) = 4.618752.
(Q2,M)^2 = 4^2 - (5.5-x)^2 and (Q2,M)^2 = 4.618752^2 - x^2 therefore x = 3.234807.
Using x, Q2,O,M = 45.543799 deg.
By sine rule [ Sine B,O,Q2/3 = Sine((180-30.992606)/4.618752) B,O,Q2 = 19.539633 deg.
Therefore angle B,O,T2 = 19.539633+45.543799 = 65.083432 deg.
Angle T2,B,P2 = (180 - 65.083432)/2 = 57.458284 deg.
Angle B,POINT3,P2 = 180 - ( 57.458284 + 30.992606) = 88.450891.
By Sine rule ( B,POINT3/Sine30.992606 = 3.718941/Sine 88.450891) B,POINT3 = 1.915685.
X2 = 1.915207 * Cos57.458284 = 1.030473, and Y2 = 1.915685 * Sine57.458284 = 1.61492.
POINT3 X3 = 1.030473, Y3 = 1.61492.
Step 5. With compass set to Radius 3, from centre POINT3 intersect line A,B at P3, with compass set to radius 5 (rectangle diagonal, CE ), from centre P3 intersect the circle at C. The lengths A,C and B,C will form a right angle triangle how's hypotenuse will touch a 3 by 4 rectangle at E.
MATHS
O,P3 =5.5-[ Square root(3^2 - Y3^2) + X3] = 1.94128.
By Cosine rule (5,5.5,Cos C ,(O,P3)) Cos C = 20.605454 deg
By Sine rule (SineO/5 = SineC/1.94128) SineO = 65.017921 deg
Therefore angle C,A,B = 65.017921/2 = 32.508961 deg.
CAB = 32.508961 deg, therefore by formula AB = 11.000.
SOLUTION 2:
With compass set at the selected hypotenuse length scribe an ark from point P1 to Q1, to dissect a vertical line extended from the rectangle, draw a line from Q1 to the corner of the rectangle at E, and extend it to dissect a point P2 on a line extended horizontally from the rectangle. With compass still at the selected hypotenuse length scribe an ark from point P2 to dissect the vertical line at Q2, draw a line from Q2 to the corner of the rectangle at E, and extend it to dissect the horizontal line at P3, repeat this a number of times that is practical, then transfer the final lengths C,Q and C,P and draw up triangle ABC.
MATHS
Base = Rectangle width
Start of Loop
Triangle height = square root ( Hypotenuse^2 - Base^2) .
Short height = Triangle height - rectangle height.
Top length = square root ( Short heigth^2 + rectangle width^2).
Bottom length = (rectangular height/short length) * Top length.
Length PQ = Top length + Bottom length.
Base = square root( Length PQ^2 - Triangle height^2).
With new Base size return to Start of loop four times,
Sine of angle CAB = Base/length PQ.
Hypotenuses check = (rectangle width/ Sine A) + ( rectangle height/ Cos A).
Examples
Width 4, height 3, length 11, CAB = 32.50575 deg. AB = 11.000.
Width 4.6, height 3.9, length 17, CAB = 21.024 deg. AB = 17.000
Width 8, height 3, length 33, CAB = 15.5263 deg. AB = 33.000
Width 5.8, height 9.2, length 30, CAB = 16.5144 deg. AB = 30.000
#108
In reply to #100
Find in discussion
Re: Triangle With Rectangle Insert: CR4 Challenge (08/25/09)
09/06/2009 12:42 PM
Do your triplets mean the lengths of the sides and the rectangle's hypotenuse? If so isn't 'play' an overstatement? The length of the "perpendicular hypotenuse" for a 3x4 rectangle is 53/3/4=125/12 (~10.417) and for the other case is 853/13/84/10 = 122825/2184 (~56.239)
Good Answers: 114
#113
In reply to #108
09/07/2009 11:48 AM
I do mean the sides and the hypotenuse of the rectangle, but, while I suspected that such a formula existed, I had no idea what it was, or what to call it if I did want to look for it. I draw the diagrams and work with slopes, similar triangles and Mr. Pythagoras, they all work together and help me to understand thoroughly and to see all of the ramifications; the formula seems disembodied to me. I suspect TeeSquare will understand this preference.
My point though, was that in the original question, we needed to know the length of the perpendicular hypotenuse in order to select one that was longer, but we were not equipped with a measuring stick.
#114
In reply to #113
09/07/2009 12:27 PM
The formula is derived from Pharaoh Pythagoras, similar triangles, and a bit of simplification. Apart from the compactness, it has (for my money) the elegance of maintaining the diagram's symmetry between the CF and EF in the mathematics.
For CE perpendicular to AB, we have:
CE2 =CF2+ EF2
AE = EF.(CE/CF)
EB = CF.(CE/EF)
AB = EF.(CE/CF) + CF.(CE/EF) = (EF2.CE+CF2.CE)/EF/CF = (EF2 + CF2).CE/EF/CF
As EF2 + CF2 = CE2, we have
AB = CE3/EF/CF
I hope you agree that this is not just embodied, but positively mummified
Good Answers: 143
#109
In reply to #97
Find in discussion
09/06/2009 8:06 PM
Very good. Thank you. It is easy of course to construct a line (an arc radius) of 11. The problem is locating the point on line CA where the arc would have to be centered in order to have line AB pass through point E. It is obvious that there is no exact solution without measurement. The question then turns to the best iteration process. I can see several, but they don't appear any better than some others proposed. The accuracy question is answerable, however.
In constructing an arc radius of 11, it is necessary to make three arc swings, each involving a line thickness. We generally accept that the thinnest pencil line we can make is around 0.005" (We could use an engraving scribe on metal, but I'll stick with paper for now). We can estimate that we will need perhaps a minimum of 6 swings at best and, even using something like √6 x 0.005" x 0.5 (to allow for "calibrated" eyeballs), we still end up with a resolution of 0.006" as the closest we can get. So, no, we would not get an error of +/- 0.0005". I actually think I would need 10 or 12 swings to do this, but I'm allowing for someone smarter than I to do it in much fewer.
I'll have to think a lot more about the best iteration. I don't know much about that sort of thing.
#110
In reply to #109
09/07/2009 5:22 AM
I suspect that this was a conceptual (limiting) accuracy.
Although I think you are being pessimistic about the eyes ability to estimate the middle of a line, I fear that our ability to position the compass point would have a similar effect. However, successive approximation only works if each stage reduces the error, so the errors in this case would not accumulative as you suggest.
In addition, I don't think we know the measure was inches. I suppose that the ideal unit (given the absolute size of our expected error) would be decimetres? Which would require a rather large sheet of paper...
Finally for now on this topic, the difference between systematic and random errors could be important. If the objective were to use drawing methods to find an angle or a length, we could in principle repeat the process as often as is required to reduce the random part of the error however far we wish - but using a fixed process the systematic constructional error would be the same on each occasion.
BTW, using my originally proposed method, I think I would be inclined to ascertain the "worst case" of rectangle dimensions and hypotenuse length as follows:
Set up a spread-sheet calculation that uses a fixed rectangle* shape and has a different outer hypotenuse length in each row. I would then work out a single iteration in each column, and use the sheet to discover the number of iterations needed for the worst-length outer hypotenuse. Then I would search (using multiple spreadsheets) in the region of the worst allowable shape. It should be possible to constrain the problem into at most 20 sheets - not too bad as the only one that will take significant time is the first; I might even get around to it later this week.
*The longer side would always be 10 units long
Good Answers: 143
#111
In reply to #110
09/07/2009 8:41 AM
I am not so pessimistic as you might think about the eye's ability to estimate the middle of a line. I have worked as a draftsman, and have taught it, and have a good feel for what is possible. The 0.5 factor in my estimate was just that estimate.
There is a legitimate question as to whether successive approximations decrease or increase (stacking) line width errors. Without some sort of error correction scheme (which I am not capable of devising), I think the errors will stack, the only question being how to do that. I thought I was optimistic in taking the quare root, but...
Do we get to use spread sheets? If I can have one of those, I can easily do this to 0.001 (whatever). I was assuming I could only do such math as can be done graphically.
As to units, I made the assumption we would be doing this on a somewhat ordinary piece of paper. Thus, the dimensions would be something close to inches. If we use paper like what we call "D" (or your A1), things get much better.
#112
In reply to #111
09/07/2009 10:59 AM
I'll consider the random errors first:
50% of line width corresponds to the edge of the line being used instead of the centre - to my mind this would correspond to my visual resolution being much appreciably worse than the line width allows (true in my case, but that's what spectacles are for...). However, positioning the compass point in two dimensions is another matter, so I'm content to accept your +/- 0.002" (say 0.0012" RMS) for a single construction.
Consider successive approximation without any random errors. It can only tend towards zero error if the each preceding error is divided by some number greater than unity; that same division must also apply to random error. If we now consider the case where it takes 12 steps to reduce the error from 0.1 to 0.005 you can see that this corresponds approximately to dividing by 1.5 each time. The RMS addition then gives:
√(0.000122.(1+1/1.52+1/1.54+1/1.54+...)) = 0.002" RMS. Of course, (depending on the error probability that you accept, this could still correspond to a peak error of about 0.006" - as you wrote. But my checks so far (see belowThis either requires that we use the average of previous constructions, a larger unit, or scribing on metal.
Returning to the purely theoretical requirements - i.e your question: are we allowed to use a spread-sheet to determine whether successive approximation will be adequate?
Once we use successive approximation, we require some means of knowing whether it has converged to the required limit. The challenge forbids measurement on the diagram, so we need to find a way of proving that our method will give answers that are accurate to the required level regardless of the dimensions of the rectangle (within the permitted range) or the chosen length of the diagonal. We can't do this using drawing, which means we have to use arithmetic or algebra. The spread-sheet does nothing that we couldn't do by hand - it merely speeds it up a bit, so I'd say it was a valid method of proving the technique. However, I'd have to emphasize that we have show that we have covered the worst case, as (in the absence of measurements/estimation) we have no way of selecting different procedures (or numbers of iterations) for different case.
08/30/2009 11:30 PM
This is one of the better challenges that we should have more than a week to look at.
As nobody has even attempted the trivial cases I have shown a sketch below of the two simplest constructs I can find, maybe they will trigger others more complex.
A1B1 is a hypotenuse constructed by simply setting the compass point at E and pencil at C and drawing circle C1. I believe this is the smallest hypotenuse achievable and is equal to twice the length of CE.
The second right-angled hypotenuse to CE is achieved by drawing circle C1, with centre at E and radius CE. Then extend the line CE cutting through C1 at X. Draw two identical circles C2 and C3, centered at C and x respectively, their radius arbitrary but greater than CE. A line drawn through their overlaps bisects the line CX at E and forms the hypotenuse A2B2.
Still thinking about more complex ones...
08/31/2009 4:45 PM
Agreed* that 2.CE is the shortest possible length for AB. But JD constrains the length as greater than CE3/FE/EK, which can be much longer. I'm not certain of the reason...
I don't believe that an exact method exists (Oh, to be shown to be wrong here).
The successive approximation method that has been proposed would of course work (eventually) for any valid length.
*And can prove it - the easiest method to follow uses calculus - strictly post-Euclidean, of course...
09/01/2009 10:04 AM
Quick note! I have written to amichelen to ask if he can delay the answer to this challenge.
United States - Member - Engineering Fields - Mechanical Engineering - Hobbies - Fishing - Hobbies - Musician -
Good Answers: 19
09/01/2009 10:58 AM
Perhaps he can delay it as long as for the "Car Brakes" challenge, which still doesn't have an answer after 8 weeks.
09/01/2009 5:02 PM
The first method is .... frightening. It'll be a few weeks before I have time to address it seriously - but I will try to understand it, and also to look at the tolerancing of the second method in more detail.
09/01/2009 7:23 PM
In the answer I used the sizes 2.4, 3 and 4 this may cause some confusion, these are not universal sizes, but sizes taken from the sample rectangle that I used for the maths.
In STEP ONE the rectangle CFKE measures 3 units vertically, and 4 units horizontally and the chosen length A,B = 11, therefore A,D = 8.8, B,D = 6.6, D,W = 5.28 and B,W = 3.96, and the rectangle diagonal height h = 2.4.
Regards JD.
#107
09/06/2009 12:32 PM
For a square, the problem reduces to second order, and can therefore be solved exactly (albeit tediously) by geometric construction.
For a general rectangle and hypotenuse the problem can be reduced to third order (sillke, for example, gives a substitution that does this). But even with rectangular boxes there will be specific values for the lengths where the solution reduces to second order; however, you have to know the exact values for the lengths before you can use anything like this (which I think contravenes the spirit of the exercise?).
Good Answers: 114
#115
09/09/2009 11:24 PM
I have a solution, but it is a little difficult to present.
I drew the diagram shown in post #97. I constructed the hypotenuse, perpendicular to the diagonal of the rectangle, mark A1 at the side and B1 at the base. I extended the hypotenuse below the baseline. I used the compass to measure 11" up the side and then to measure 11" down the hypotenuse from A1. A short length of it hangs below the base, call that the "tail". Use the compass to carry the tail and plot it above mark A1 to mark A2. draw a line from A2 through the corner of the rectangle, E. Measured the new tail and repeated this process from A2 to An when the length of the tail became insignificant.
The length of the tail diminishes rapidly so that the lines overlap and obscure each other; it would require a scale several multiples above full size for accurate measurement. I used a spreadsheet to calculate where the lines would land, if this protocol were executed perfectly.
FA : Tail
5.33 : 0.583
5.917 : 0.237
6.154 : 0.083
6.236 : 0.027
6.272 : 0.003
6.275 : 0.001
The final position of A is 9.276" above the base. B is 5.912" to the left of C.
I don't see any point in doing more calculation, the angle is defined by the lengths of the sides, so it would be circular to then use the angle to find the length of the sides.
In reply to #115
09/10/2009 3:07 AM
Regards JD.
#117
In reply to #115
09/10/2009 7:50 AM
This does work, but it requires two compass stages for each step, compared with one for the method of post#19. The convergence is also slower than in post#19 - a limiting factor of 1/3.12 per step compared with 1/5.15. I also noticed that you omitted a step during copying (easily done).
For the 4x3 rectangle, theoretical errors at each stage should be as follows:
Post#115 . Post#19
0.5833 . . . 0.5833
0.2368 . . . 0.1496
0.0826 . . . 0.0308
0.0272 . . . 0.0606
0.0088 . . . 0.0012
0.0028 . . . 0.0002
0.0009
If we interchange the sides (a 3x4 rectangle), the step factors are 1/8.21 and 1/15.37 respectively.
#118
09/10/2009 9:02 AM
If the rectangle dimensions are constrained only so that the maximum side length is 10 units and the minimum is 1 unit, and the outer diagonal AB can be any integral combination of lengths derived from the rectangle, then for the worst-case theoretical situation we would need 46 successive approximation steps using the method of post #19. The 46 steps are needed whenever the required construction for the eventual length of the diagonal is
AB = 2xCE + N.(CF - CE), where N is 2 or more.
All other constructions of AB will require fewer steps (most of them much fewer); the required number may be calculated on a case-by-case basis.
Note that the fact that we are not allowed to measure any lengths means that we cannot use observations of the size or the shape of the rectangle to reduce the number of steps (length comparison using the compass and estimation by eye both counting as the use of measuring instruments).
We should also note that the error is only reduced by a factor of about 1.05 for each stage, which means that the cumulative error due to inaccuracies in the physical construction will be about 10x the single-stage error.
As expected, things are worst when the rectangle is nearly square and the desired length is close to the length of the hypotenuse. For the specified "error < 0.001 units" the worst situation seems to be for a rectangle with provided dimensions CF=10, EF=10-(0.0033)/N and where the specified construction for the external diagonal is
AB = 2.CE + N(CF - EF) .
The accuracy gets worse as N is increased, but the number of required steps reaches its maximum of 46 when N=2. For N=1 the required number of steps is 45.
Interestingly (?) the error multiplier takes a long time to improve close to its final value. Even at the 45th step has only reached 1/1.045, compared with its eventual value of 1.054
Anonymous Poster (6); argh1984 (2); dac1267 (2); Doorman (2); jdretired (20); jim35848 (10); Kris (9); Maths_Physics_Maniac (5); passingtongreen (7); Physicist? (32); Randall (2); TeeSquare (5); TVP45 (15); user-deleted-1105 (1)
You might be interested in: Line-shaft Spools, Power Line Network Components
