HVAC Blog Blog
HVAC Blog
Previous in Blog: Geo-sensible Alternative to Traditional HVAC   Next in Blog: Lean Green War Machine
7 comments
Does HVAC Affect Our Sense of Well Being?
Posted December 06, 2009 8:27 AM
We all have good days and bad. But how often are our moods affected by the air we're breathing inside the workplace? Just like the weather outside can have a profound affect on one's overall sense of well being, the weather inside your work place can do the same thing. As a business owner or facility manager, have you taken steps to ensure your building's HVAC system is properly managed? As an engineer or architect, do you attempt to design air and ventilation systems that will provide the best IAQ possible? Or are the costs of superlative IAQ sometimes prohibitive? Do you know how much the air we breathe inside the workplace affects our sense of well being?
Re: Does HVAC Affect Our Sense of Well Being?
12/07/2009 9:44 AM
Yes , HVAC systems DO, in fact, affect our well being. Adversely, in my case!
It is a nice 66 degrees outside, yet that doesn't mean a THING to the gal who sets the thermostat here. Whether it is 105° or 35° outside, the a/c is always cranking full-tilt! My office gets absolutely bone-chilling / teeth-chattering cold, while the other areas of the building get only moderately cooled.
I spend half of each day either in the men's room or the break area just to "warm-up"!
Does anybody have a manager who has successfully dealt with the issue, pleasing everybody in the office...?
Good Answers: 213
12/07/2009 10:03 AM
Air conditioning causes me serious issues with my sinuses. I avoid it with a passion. Living in the Tropics, this can be difficult, but, interestingly, many older buildings (built prior to the advent of air conditioning) were properly designed for the climate and can be quite comfortable without air conditioning. Newer construction (sealed glass towers, for example, with no benefit of natural shading from direct sunlight) are uninhabitable without some form of climate control...
12/07/2009 4:53 PM
In addition to the above issues there is a thing called "sick building syndrome". Lots of info from google.
Also metal fan blade remove ions from the air. Remember that fresh air smell outdoors after a lightening storm. Metal fan blades remove it. there was a thread recently about negitive ions. many building have none left internally. I am sure you can google more on this.
12/07/2009 11:54 PM
Closed-cell minds are even worse! One set of biases is impervious to other sets of contrary biases; sort of like schizophrenia or multiple personality disorder.
12/16/2009 10:17 AM
It is well known in Europe since many decades that HVAC causes health problems. Positive ion generation seriously affects your immune system. The HVAc is a extremely efficient positive ion generator. If combined with en equal amount of negtive ions it would at least be neutral.
Get about and do it, if you have the knowledge!
Good Luck!!
12/17/2009 7:29 PM
Yea,
air systems apparently make positive ions. Probably true. Some negative ion generators i've heard make the air molecules too big so they don't absorb into your lungs. They can clean the air but don't do your body to much good. Beeswax candles on the other hand do generate small negative ions. Good for you and they smell nice. They are just pretty expensive. I get my beeswax from a beekeeper for cheap and make my own candles. The air does seem easier to breath around them I think.
amos
01/06/2010 7:18 PM
First let's remember the basics, HVAC is not just about heating and cooling, but also about air movement and IAQ. A well balanced system that is well maintained will affect everyone in the building. Many companies are cutting down on maintenance as money gets tight, resulting in a greater incidence of sick buildings syndrome and more employee sick days.
Another factor often overlooked in maintenance is background noise, a system that is not running correctly can produce a verity of background sound that can have the occupants getting aggressive.
With the easy to fit modern control systems we can easy control temperature, humidity and prevent excessive employee sick days. So why don't we?
Anonymous Poster (4); cwarner7_11 (1); silvCrow (1); Tornado (1)
You might be interested in: HVAC Services, HVAC Controllers, HVAC Ductwork
