Previous in Blog: Magnetized Rods: CR4 Challenge (12/15/09)   Next in Blog: Wild Rocket: Newsletter Challenge (01/05/10)
58 comments
Speeding Box: CR4 Challenge (12/22/09)
Posted December 20, 2009 5:01 PM
A small box of mass 500 grams is moving at a speed of 60 cm/s across a horizontal frictionless surface. At a certain point it hits a spring located in the same surface. If the spring constant is 650 N/m, by what distance the spring is compressed at the moment when the box stops?
And the Answer is....
This is a simple problem of a spring being compressed. The box initial energy of the box is given by
And its final energy is Ef = 0 (the box stops). So the total work done by the box on the spring is given by
[[I
Now, the total work by the spring on the box is given by applying Hooke's Law
Where d is the length (distance) that the spring has been compressed at the moment the box stops.
Equating Wb and Ws, and then solving for the distance d, we get
5
Re: Speeding Box: CR4 Challenge (12/22/09)
12/21/2009 10:25 AM
First, we have to assume that the trajectory of the box center of mass is aligned with the spring axis, and that the box surface in the colliding point is normal to that line (if not, the box will never stop).
Second, we need two further assumptions: that the mass of the spring is negligible, and the box is perfectly rigid and incompressible. Otherwise when the box stops we'll have some energy under the form of a compression wave traveling along the spring, or vibration/heat in the box.
Third, we have to assume that the spring is an ideal one (that is, its spring constant is actually a constant).
Finally, we have to make an extra assumption: that a run-of-the-mill problem on mechanics is actually a challenge.
If all these assumptions are correct, when the box stops all its kinetic energy will have been converted into potential energy. In fact, the first assumption is not necessary if we take for granted that the box will eventually stop, because its kinetic energy will be zero, no matter how the collision could have taken place. The remaining assumptions are still necessary. If, additionally, we neglect relativistic and quantum effects:
mV2/2=k l2/2
l=V √(m/k)
l=0.6 m/s √((0.5 kg)/(650N/m))
l= 0.016641006 m
If we are to play the role of devil's advocate, we have to include an additional assumption: that the spring is initially at rest, and its length is equal or greater than the computed value for l.
Reply Good Answer (Score 5)
12/21/2009 10:37 AM
And the other end of the spring must be rigidly mounted, and the spring must be undamped, and the box must hit the spring head-on and there must be no air resistance, and...
12/23/2009 9:37 PM
No quarrel with your reasoning and solution -- didn't even check the working. However, I can suggest one more necessary assumption.
Since any given spring constant can be achieved with an arbitrary combination of dimensional parameters, we need to ensure that a long and slender spring doesn't buckle while it gets compressed to its final length as demanded by the problem. Or else it must be provided with an internal or external frictionless guide, which can be a tricky practical design problem in itself!
I don't think anyone has visualised the spring to be anything other than the common helical coiled round wire metallic compression type with squared and ground ends. One could exercise the imagination and conceive of other kinds of springs having a constant 'rate', which is all that the question calls for. Some appropriate changes in the assumptions may be required.
But let me leave all that to come up in the discussion, if folk wish to take time off from their Christmas and New Year festivities.
Season's Greetings all round, =TeeSquare=
12/21/2009 10:52 AM
That didn't take Fernando long...
So an extension:
What are the constraints for the length and mass of the spring for the box to stop and to stay stopped if:
. the system is lossless
. the spring is unconstrained horizontally and is uniform
. the box is rigid
. the spring and box are lined up so the collision is effectively unidimensional
Reply Off Topic (Score 6)
Good Answers: 137
12/22/2009 9:14 AM
With all the usual assumptions, I make it 3.33 cm
Codey
12/22/2009 9:18 AM
Explain?
Good Answers: 137
12/22/2009 9:25 AM
I can't, I dropped a cod! At a quick look I assumed the 500 gm was used as it cancels with the 1/2 in 1/2*m*v2, but of course that's the wrong way round. So I'm a factor 2 out. I believe Fernandotasso's answer is correct.
Cheers.......Codey
Good Answers: 266
12/22/2009 11:37 AM
All other conditions mentioned aside the question says the spring is in the surface.
It doesn't compress if the spring is in the same surface. The leading edge of the spring in the surface would act as a stop if embedded. If not embedded would depend on how far into the surface it is. The back edge acting as pivot would cause the spring to roll up decreasing the compression of the spring as it redirected the force applied.
12/22/2009 1:48 PM
Before we get into Newton's 3 laws of motion maybe the "frictionless" surface should be scrutinized eh? As far as I know there isn't a surface on earth that is "frictionless". Using the Electron microscope one can see space/air between any two objects and as we all know air creates friction. Therefore since man cannot create the "perfect" vacuum one would have to go into space for a hands on demonstration but what do I know....
12/22/2009 4:38 PM
For all you know the experiment is performed inside a UHV chamber, the box contains a magnet and the horizontal surface is superconducting. With a small enough box and cold enough surfaces we might even get to the point of zero friction between the two (for the duration of the experiment).
Good Answers: 143
12/22/2009 6:26 PM
Since it's now been way over 1276 seconds since I was last pedantic (and because I want to steal a march on LynLynch), I must point out the box does not stop. It's velocity reverses and goes through zero, but at no time is there a discontinuous function in that motion.
12/23/2009 6:10 AM
Surely stop is ambiguous rather than incorrect? Perhaps you would prefer "stop instantaneously"?
Good Answers: 143
12/23/2009 7:24 AM
No. "Stop" is incorrect, or perhaps deliberately misleading. Fernandotasso has the right answer of course, so I'm just piddling with this to see how else you could look at it. When you think about the box not stopping, you realize this can be modeled as a simple harmonic oscillator and that gives another solution (same answer, different solution). To see the meaning of my statement, watch the pendulum on a grandfather clock. It doesn't stop; it just reverses. Well, it could stop if the clock spring ran down.
12/23/2009 7:47 AM
You should perhaps try post #3. It's a much more interesting problem, and one that conforms to your interpretation without in any way conflicting with the challenge as posed.
It should really be marked "on topic".
Good Answers: 143
12/23/2009 8:22 AM
My "interpretation" does not conflict with the challenge as posed. It seems obvious that the challenge was not clearly written (note the spring "in the same surface") but that doesn't mean it's wrong. But, in the absence of a nonconservative force(s), or some rather unexpected external forces, the mass does not stop and remain stopped. Now, you could make this a more interesting problem if you were to pin the mass when it reaches zero velocity and then ask what happens?
12/23/2009 9:38 AM
If you are allowing a second solution in the opposite direction don't you have to add the postulate that the box adheres to the spring?
Surely pinning the mass is a trivial addition if the spring is massless and lossless as assumed in the existing solution.
No comment on post #3, though?
Good Answers: 143
12/23/2009 1:07 PM
Only if you want to repeat.
Pinning the mass is not trivial. Somthing very unexpected happens.
I did comment on number 3. The mass will not come to a full stop unless you come up with something extra.
12/23/2009 1:30 PM
I agree that the mass will never come to a stop but for a different reason. Unless the center of mass of the box is moving directly in line with the direction of action of the spring, there will be some component of the box's motion that will not be stopped. This could be a linear component and there would still be some motion when the spring was compressed its maximum amount. There could also be some rotational motion imparted to the box.
Thanks,
Jim
01/04/2010 12:45 PM
I'm not certain what you mean here - unless you are referring to a "single-point" pinning of the mass, in which case any equilibrium will of course be unstable (unless the pinned point of the box falls within the spring).
Good Answers: 143
01/04/2010 1:27 PM
It refers to the problem of saying the box is "stopped" at the end of travel. It is not since only the velocity, not the derivatives of velocity, is zero. Pinning would show that dramatically.
01/04/2010 3:05 PM
Yes, pinning would reduce the acceleration instantaneously to zero (from its maximum value). But that is not at all unexpected.
Good Answers: 143
01/04/2010 6:37 PM
Perhaps to you. Care to place a wager on how many responders would find that unexpected? That is the difference between stopping and reversing without stopping.
12/22/2009 7:07 PM
The box never stops. It's a FRCTIONLESS surface!
12/22/2009 7:12 PM
Think outside the box
12/24/2009 7:52 AM
0,138461538461538461538461538461538mm or
0,00138461538461538461538461538461538m
12/24/2009 9:40 AM
12/25/2009 3:59 AM
OK!
0,000138461538461538461538461538461538m
12/25/2009 4:03 AM
the root of this = 0,0191715976331360946745562130177515m = 19,1715976331360946745562130177515mm
01/04/2010 12:52 PM
In my unhumble opinion, an answer without explanation is valueless at this stage (even if it were correct)
01/05/2010 12:19 AM
if you want to know the exact value - couldn't you calculate it?0,013867504905630728050458543336425m=13,867504905630728050458543336425mm
01/05/2010 6:30 AM
Your answer is different from post #1, which appears correct to me.
You suggest I calculate - but what would my calculation be based on, as you give no method or formula. (In any case, I'm not interested in more significant figures, only in having something meaningful).)
However, I note that your "corrected" answer is different from #1 by a factor of 1.2. This suggests to me that you misread the initial speed of the box. However, in the absence of supporting data there's no way we can be certain.
01/06/2010 1:35 AM
the spring constant is different from 650N/m to 660N/m in the answer is; maybe there's a problem with the windows calculator?
01/06/2010 10:14 AM
That's true - but it only results in a 0.8% error - nothing like the 20% difference proposed above.
01/07/2010 12:02 AM
recalculated with windows calculator: 0,01664100588675687366055025200371m = 16,64100588675687366055025200371mm
01/07/2010 6:25 AM
Finally the numerical answer is approximately right (more digits on an irrational number doesn't change that). But a late "correct" numeric following loads of wrong ones still looks silly - particularly when no explanation is forthcoming.
01/08/2010 1:11 AM
9 eleven?
12/25/2009 4:08 PM
In order for the box to reverse directions, at some point there is neither forward nor reverse velocity . . . i.e. there is, in point of fact both 0 forward velocity and 0 reverse velocity. Would that not be an alternate definition of the term "stopped". In which case, the problem is simply stated in a manner that requires one to understand the term "stopped" in reference to forward and reverse velocities.
Good Answers: 143
12/26/2009 9:24 AM
And, an interesting complexity is what we do with momentum. I don't know of any way to just assume conservation of momentum out of the way.
01/04/2010 12:48 PM
Won't the standard simplifying assumption of an effectively infinitely-massive constraint do the business?
01/05/2010 12:21 AM
it's a box, not a ball
Good Answers: 143
01/05/2010 6:54 AM
So? Anyway, if it helps, it's a spherical box.
Good Answers: 137
01/05/2010 3:59 AM
Hello TVP45
I don't see a problem with momentum. The spring puts a force on the box for a certain time and integral of force x time = change of box momentum. The other end of the spring causes an equal and opposite change of momentum of the Earth (which doesn't change Earth's velocity much!). The same thing happened the other way round when the box was accelerated in the first place.
Cheers...........Codey
Good Answers: 143
01/05/2010 7:00 AM
There's not a problem, but there is the consideration. In the harmonic motion solution without damping, the average momentum remains constant. I don't mean to be pedantic (except when I'm needling - and here I'm not), but it is never OK to just assume away conservation of momentum; that one is the gold standard of mechanics.
01/06/2010 11:57 PM
moving transversal?
Good Answers: 143
01/07/2010 6:31 AM
Since it's on a spring, it moves transversal...reversal...transversal...reversal...tra
01/07/2010 9:42 AM
A transversal of the American language?
Transversal: a line that intersects a system of lines
Transverse 1: acting, lying or being across; set crosswise
Transverse 2: made at right angles to the long axis of the body
Transversely: orthogonally
From Latin "transversus" = turned
Good Answers: 143
01/07/2010 5:52 PM
How did it turn out that you guys speak American so well? Sometimes you sound like it's your first language.
01/08/2010 6:19 AM
When I first arrived in California, I was 'warned' about asking to borrow a rubber (naturally, I took every opportunity thereafter...). I also bought my trusty English-to-American dictionary (now sadly neglected due to the Americanizzzation of the web).
Good Answers: 143
01/08/2010 7:36 AM
Just don't get excited if you come here to Pittsburgh and we talk about all our slag.
01/08/2010 7:44 AM
We too have slag heaps around our pits (= underground mines).
01/08/2010 7:57 AM
If only
01/08/2010 8:09 AM
Did I imply they were still functioning?
(signed) Mr. T (the other other one)
01/08/2010 9:17 AM
Thanking you grateful, Sir, ever so 'umble....
Uriah
01/08/2010 9:27 AM
3.14159...
Ebenezer
01/08/2010 9:40 AM
I've sort of dug my own grave here... (well, I will have done, if I get around to mentioning 'last turkey in the shop'). Never read the book, so blame Alastair Sim' for that
01/08/2010 9:46 AM
... was definitely not my thing
But would you by any chance be expecting non-existent relevance?
01/08/2010 9:53 AM
My verbal linkage is a bit tenuous, even at the best of times.
01/08/2010 1:09 AM
box or ball
Reply to Blog Entry 58 comments
Anonymous Poster (16); Big T (1); Codemaster (3); fernandotasso (1); jim35848 (1); Kris (4); ozzb (1); Physicist? (11); TeeSquare (1); TVP45 (12); WilhelmHKoen (7)
