Previous in Blog: Lamps and Switches: CR4 Challenge (12/01/09)   Next in Blog: Speeding Box: CR4 Challenge (12/22/09)
61 comments
Magnetized Rods: CR4 Challenge (12/15/09)
Posted December 15, 2009 9:15 AM
You are given two identical iron rods and told that one is magnetized and the other is not. You are then locked naked in a cell (with non-metallic bars and fixtures) and told that you will be released when you can correctly identify which rod is magnetized and which is not. How do you earn your freedom?
And the answer is...
Form a "T" with the rods. If the top of the "T" is the plain iron bar and the vertical is the magnet, the two rods will stick together. If the top of the "T" is the magnetized rod and the vertical is the plain iron bar, they will not stick together because the centre of a bar magnet is of neutral polarity.
Re: Magnetized Rods: CR4 Challenge (12/15/09)
12/15/2009 9:33 AM
Havn't we had this Q before?
I won't spoil it for anyone else by giving the A
12/15/2009 12:45 PM
Yes! But the real question is; has the answer changed?
Good Answers: 266
12/15/2009 10:29 AM
By making a compass the one that is magnetized would turn pointing to the poles in the same direction every time.
United States - Member - Engineering Fields - Mechanical Engineering - Hobbies - Fishing - Hobbies - Musician -
Good Answers: 19
12/15/2009 11:14 AM
Touch the tip of each rod to the center section of the other rod. The magnet has magnetic fields at the ends but not in the center, so the non-magnetic rod will not be attracted to the center section of the magnet. The true magnet will be the one for which the end is attracted to the center section of the other rod.
Reply Good Answer (Score 7)
Good Answers: 7
12/15/2009 11:06 PM
My thoughts exactly. Rated a GA for getting there first.
Cheers,
Pete.
Having a farm is great provided you don't have to depend on it for a living.
12/16/2009 12:08 AM
Great answer, Dac I was thinking the exact same thing. True logic reigns supreme!!
Surprise your skeptics, do what they told you couldn't be done!!
12/16/2009 10:26 AM
Me too.
Isn't the french fry the most COMMENTATOR ?
12/15/2009 1:43 PM
Place both rods carelessly on any surface (it doesn't matter how clean the surface looks). When you pick up the iron rods you will find that somehow you placed the magnetised rod on a small pile of sharp metallic grit which is now stuck to the rod.
Surprisingly this actually works in real life! Who says you cannot use Murphy's law to your advantage!
12/15/2009 11:24 PM
Bring one of the rod's end to another rod and move it along its length. If the attraction being felt is same through out the rod the rod in your hand is magnetised.
Logic: For a magnet the magnetic filed of attraction is more in the poles than at the center. Hence when the end of a rod is moved towards the other rods length will have equal attraction if the rod is magnetised. Else the other rod is magnetised.
12/16/2009 1:08 AM
y be naked??
Popular Science - Biology - life lover Hobbies - Musician - music lover Safety - Hazmat - better safe than sorry United Arab Emirates - Member - desert trek Technical Fields - Procurement - procurement
Good Answers: 58
12/16/2009 2:58 AM
"y be naked??"
exactly. this is one of the conditions of the problem that needs to be explained. all answers presented above is unrelated to this.
or is "naked" just a figure of speech?
Now the darkness only stays the night-time, in the morning it will fade away. -- George Harrison (All Things Must Pass)
Good Answers: 22
12/16/2009 3:34 AM
The main reason is that it's always more fun to do this kind of thing naked. The second reason is that it is pretty easy to make a compass out of a bar magnet and some thread torn from your clothes (just hang the bar from a thread).
It is (or so I have heard) much harder to make a compass using some part of your body as the fulcrum.
Good Answers: 58
12/16/2009 4:38 AM
"it's always more fun to do this kind of thing naked"
<LOL>
however, methinks you just introduced another degree of difficulty to the problem.
"some thread torn from your clothes"
they put you in the jail without your clothes!
but really, it is quite easy to determine which of the rods is magnetic just by feel. just can't make anything out of why you have to be naked to do this.
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
12/16/2009 5:02 AM
Those who still have hair don't need a thread to make a compass, or are the prisoners shaved as well?
12/16/2009 12:27 PM
I too thought of touching one rod end to centre of other one. But I am not the first.
some thread torn from your clothes : I pull one of my hair and use it as a thread and make a compass! (But for this also, i need not be naked)
12/16/2009 5:39 AM
Come on guys! It's simple. A fully dressed person could simply touch the bars to their belt buckle or ear rings or whatever other metal snaps etc. might be on their clothes. By stating that you are locked naked simply removes these avenues of testing which makes the problem more difficult. I have spoken. The Digital Man
Good Answers: 58
12/16/2009 5:52 AM
so maybe the problem should've been reworded to say: "using only the 2 rods in your hands, and unaided by any other object or material, such as metallic objects in clothing, or the jail bars, or iron filings, etc., determine which rod is magnetic, and which is not."
the whole thing about nakedness was just to throw you off....???
Good Answers: 22
12/16/2009 6:46 AM
Look, if you have the resources and audacity to kidnap someone, lock them in a padded cell and then screw with their mind by telling them they won't be released until they pick which is the magnetised one of two otherwise identical rods, then you may as well go all the way and make them do it naked. It's just common sense.
12/16/2009 7:05 AM
What / where is commonsense here????
12/16/2009 12:13 PM
You're not thinking like a criminal.
12/16/2009 8:12 AM
Why not be naked?
"Obviously you're not a golfer." - The Dude
12/17/2009 10:55 AM
So that the effect of the magnetised rod near my iron hip joint will be more sensitively felt. (Although I suppose I could have done this with my hat on)
duikerbok
12/16/2009 2:29 AM
If I can break each of the two rods into halves and then observe the attraction / repulsion or no effect of the related broken halves on each other, I guess I should be able to see the sunshine and breathe the fresh air.
12/16/2009 3:22 AM
I place one bar horizontally on another bar exactly at the center point to balance. If the top bar does not rotate horizontally, it is non-magnetic. To confirm, I interchange the position of upper and lower bars to see that the upper bar rotates horizontally towards the geo. N & S poles.
12/16/2009 3:43 AM
If you place rod (a) at right angles to rod (b) and exactly half way along its length it will attract the rod to it if it is the magnitised one. If it is not it will try to move to either end of the other rod.
Good Answers: 137
12/16/2009 4:22 AM
Take one rod and apply the end to the middle of the other rod. If there is attraction, you're holding the magnetised rod. If not, you're holding the unmagnetised rod.
Cheers.......Codey
12/16/2009 5:56 AM
Pick one of the rods, it does not matter which one.
Stick this up your rear end far enough so that it won't fall out.
Get in the shower and balance on a wet cake of soap with only one foot.
Spin around. Note in which direction you point each time you stop revolving.
Do this with the other bar as well.
The one that is magnetized will cause you to stop more often in an aproximate North/South alignment!
Take that silly grin off your face!!!!
Good Answers: 143
12/16/2009 6:28 AM
I'll give you a GA for that, but I'll be damnned if I ever want to be your cell-mate.
Good Answers: 11
12/16/2009 9:13 AM
I laughed so hard I had to give a GA. Thanks for waking me up.
12/16/2009 1:07 PM
There is only one problem, and that is in the end.
When you stand on one leg, on the bar of soap- it is slippery isn't it, in the bath? You are most likely to fall down, and as per Murphy's law, on your butt,
Then what happens to the carefully positioned magnet?
I like the #32 better- where magneto therapy is used. In fact I have heard of some cures where the magnetised water is used for curing all and any illness (H1N1 and HIV excluded). So treat yourself with the water for sufficient time, if you are cured, that is the magnet. If you aren't, it does not matter.
The best is #31 - hold them in yoyr hand. The one pulls is the magnet, the one pulls is the iron rod.
Why not make electricity in the rod with rotating magnet and light a bulb? rotating Iron can not do it.
Popular Science - Cosmology - New Member United States - Member - New Member
12/16/2009 7:52 PM
Beautiful Andy.
The whole exercise is just an exercise in futility.
The answer is simple. The rod with magnetic properities will immediately jump to the cast iron fillings in my teeth. Problem solved.
All worthwhile programmers know that constants always vary.
12/16/2009 8:43 PM
Welcome back JJ. We thought you were dead!
12/16/2009 9:20 PM
I was, but I'm reincarnated now thanks to you.
-John
12/16/2009 8:42 PM
Wow, Andy, you are have my kind of A$$ho!!e. Tell me, why does it feel so much better to pull the rods out than to put them in? Is this the voice of experience?
12/17/2009 4:43 AM
LOL
Never had your Prostate checked???
12/17/2009 4:01 AM
So what you are suggesting is that every prisoner that is released should be issued with a magnetized bar and pointed in the right direction. Rehabilitation at the highest level.
Regards JD.
12/16/2009 7:00 AM
I don't believe it, two GAs for using my rear end instead of my head!!!!
Many thanks Guys!!
Good Answers: 11
12/16/2009 9:12 AM
Call the guard over and hit him with the rod. Then try both rods on the guards keys to see which one is magnetic. Use the magnetic rods to get the keys and earn your freedom.
12/16/2009 9:18 AM
I would take one of the iron rods and touch the other with it, noting the strength of the magnetic attraction. I would then with the rod I initially grasped, keeping one end upward strike it very hard the cell floor about 20 times (making a note which end I was striking with). I would then with the my "striked" rod, touch the other rod on both ends making a note any change in magnetic force. If it repelled the other rod when touching either end, I would know that the other rod was the one that was initially magnetized. If the magnetism increased or decreased I would know that the "striked" rod was the initially magnetized rod. This method works because the striking force in one direction tends to allign the molecules in a single direction thus creating magnetic poles (north and south) like poles repel, unlike poles attract.
APIX Pilot Plant Design Project - Member - New Member
12/16/2009 10:14 AM
suspend both bars at the midpoint. the bar that aligns itself in a north-south direction is magnetized. So now, unlock the cell, I have things more important to do.
chtank
12/16/2009 10:44 AM
If you have no clothing then I'm assuming you have no watch, i.e. metal with which to assist with the experiment, therefore you can only use the rods to answer the question. One rod is a magnetized iron rod and the other rod is simply an iron rod. Take one rod (Rod A) and while holding it at one end slowly run the end of Rod A down rod B from one end to the other and see if there is a "pull", i.e. the magnetic pull. Then switch rods. Whichever rod is pulled towards the other rod is simply the iron rod; the rod doing the 'pulling' is the magnet.
12/16/2009 11:27 AM
I would use the metal plate in my head, but if I were not in a hurry, I would first develop arthritis in similar joints, such as my wrists or ankles, then hold the rods to my joints. The one that hurts less and is cured fastest is the one that is exposed to magnetism. Would I be provided with water during my incarceration? If so, I would break the rods into length that would fit on the surface of the cup and gently place the rod fragment on the surface tension. One of the rods would orientate itself north and south no matter how I oriented the cup. The other would just sit there. Because of my breakage I now have several smaller magnets, which I could offer to my jailor in exchange for my freedom.
12/16/2009 12:12 PM
Hold the rods perpendicular,then move the end of one along the length of the other. The rod that is magnietized will have North and South poles, one at each end, and in the center will have NO magnetic force. If the moving rod has uniform attraction to the static one, it is magnetized, and one pole is attracting the non-magnetized static rod.
If, on the other hand, the magnetic attraction varies , decreasing as the moving rod nears the center of the static one, then the static one is magnetized.
Keith E Bowers, PMP
12/16/2009 1:02 PM
One other way. Not as practical, but I think it would still work. Slap one rod on a surface several times, enough to displace the fixed magnetism of the metal. If the rod you've been slapping has a reduced or no magnetic effect on the other rod, then it was the magnet.
Depending on where you've been keeping the rod as in the previous scenarios, you may be busy slapping another rod.
"No, you pick up the soap!"
12/16/2009 1:41 PM
Crap! BOBCO came up with this one before me. My apologies, the soap is yours.
12/16/2009 1:41 PM
Stand one rod on its end on the floor. Balance the other rod at its midpoint on top and if it rotates to point N S you know it is the magnet etc.
Peter Jensen
12/16/2009 4:44 PM
Why over complicate it? All you have to do is lay one on the floor and bring one end of the other one very close to the exact center of the one on the floor. If they are attracted to each other then the one in your hand is the magnetised one. If not reverse positions and see if the one in your hand atracts the middle of the other one. Once you find the one that sticks to the middle of the other one, that is your magnetised one. It's not rocket science.
12/16/2009 3:45 PM
I would carefully balance one rod on the non-metallic bars and place the other rod as far away as possible to reduce the magnetic attraction between the rods. If the rod on the non-magnetic bars align itself North and South, then this is the magnetized rod. If not, I would exchange rods and repeat the procedure. The magnetized rod will attempt to align itself in the North/South direction.
12/16/2009 6:12 PM
"...you will be released when you can correctly identify which rod is magnetized and which is not."
Pick a rod at random. Tell the jailer that you think it is the magnetised one. If you are set free, then it was magnetised. If you are not, then you know the other rod is the magnetised one. Since you can now identify which bar is magnetic you will be released.
12/16/2009 9:01 PM
You make a string from your hair and tie it in the middle of a bar. Mark one end of the bar by spiting or some other means. one bar will point to magnetic north. Alternately for the bald professor, balance the bar on your fingernail if possible or the end of the other bar.(excreate something slippery if nessecary) what if gravity was caused by superspeed particals coming from all directions? How big would they be?
Good Answers: 58
12/17/2009 1:23 AM
I therefore conclude, from the postulations above, that a poorly-worded problem statement results in ambiguity, and elicits answers that are poorly-worded and ambiguous.
Good Answers: 143
12/17/2009 10:17 AM
Well, since that one went so fast, how about a twist? Suppose you had a mobius strip of iron that had been well annealed so it was isotropic after joining. Could you magnetize it so that one side is a north pole and one side a south pole?
12/17/2009 9:22 PM
Take a hair from your body, tie it around the centre of a rod, etc. if your hair is short you might wait for it to grow or tie several hairs together.
12/17/2009 9:30 PM
Bite yourself, dry the blood, grind it to fine powder, since blood contains iron it should cling a little to the magnetised rod.
12/17/2009 9:44 PM
Bite me!!
12/17/2009 10:34 PM
Bite him.
12/18/2009 1:00 AM
I assume this is a room on Earth. Balance each rod on your finger separately and away from one another (to prevent magnetizing the one not yet magnetized) and observe if one or the other seems to act as a compass to track magnetic north. You would need to probably run a few tests with different starting orientations possibly using the one not being tested as the "mark" where the tested bar points to. The one that consistently turns to track in the same orientation is the magnetized one.
12/18/2009 8:55 AM
Except a few posts and AG to be specific, nobody has concentrated on the most important information.
Why naked? What the hell one wants to do with three rods? one ferrimagnetic, one ferromagnetic and one paramagnetic?
12/18/2009 10:00 AM
what one should do is hang each rod marked in any direction. if the rod is magnetic it will align in the direction of the magnetic north. and this will give exactly get me out. it should be proved over and over changing the direction.
12/18/2009 1:08 PM
it can be checked by the tounge of the person which can identify the magnetization in between the rods
12/24/2009 2:15 AM
statistically every second answer will be correct!
So i have two tries to find out which box is magnetized; first answer is box A, if it is not correct the second Box (B) has to be it!
Reply to Blog Entry 61 comments
Andy Germany (3); Anonymous Hero (1); Anonymous Poster (11); BigPete (1); bobco (1); Chankley (1); chtank (1); cingold (2); Codemaster (1); dac1267 (1); dhgrant (1); duikerbok (1); gsuhas (1); guitarhunter (2); HiredGun (1); jack of all trades (1); javelinman (3); jdretired (1); Johnjohn (2); Keith E Bowers (1); langyaw (4); m()lly Mae (1); Mohamedrafi (1); ozzb (1); pauls_14 (1); Philliro (1); Pj3ns3n (1); RobertOz (2); rubiolio (3); sciguy (1); StandardsGuy (2); subir kumar ghosh (1); TheDigitalMan (1); TVP45 (2); user-deleted-1105 (1); WilhelmHKoen (1)
