Previous in Blog: Does Science Need the "Big Challenge?"   Next in Blog: Video: Brush Research and the Flex-Hone Tool
9 comments
What is Plasma?
Posted March 30, 2010 9:55 AM by Hypertherm
One common description of plasma is to describe it as the fourth state of matter. We normally think of the three states of matter as solid, liquid and gas.
For a common element, water, these three states are ice, water and steam. The difference between these states relates to their energy levels.
When we add energy in the form of heat to ice, the ice melts and forms water. When we add more energy, the water vaporizes into hydrogen and oxygen, in the form of steam. By adding more energy to steam these gases become ionized. This ionization process causes the gas to become electrically conductive. This electrically conductive, ionized gas is called a plasma
How Plasma Cuts Through Metal
The plasma cutting process, as used in the cutting of electrically conductive metals, utilizes this electrically conductive gas to transfer energy from an electrical power source through a plasma cutting torch to the material being cut.
The basic plasma arc cutting system consists of a power supply, an arc starting circuit and a torch. These system components provide the electrical energy, ionization capability and process control that is necessary to produce high quality, highly productive cuts on a variety of different materials.
The power supply is a constant current DC power source. The open circuit voltage is typically in the range of 240 to 400 VDC. The output current (amperage) of the power supply determines the speed and cut thickness capability of the system. The main function of the power supply is to provide the correct energy to maintain the plasma arc after ionization.
The arc starting circuit is a high frequency generator circuit that produces an AC voltage of 5,000 to 10,000 volts at approximately 2 megahertz. This voltage is used to create a high intensity arc inside the torch to ionize the gas, thereby producing the plasma.
The Torch serves as the holder for the consumable nozzle and electrode, and provides cooling (either gas or water) to these parts. The nozzle and electrode constrict and maintain the plasma jet.
Read the Whole Article
Good Answers: 42
Re: What is Plasma?
03/31/2010 9:49 AM
Very useful information on fundamentals of Plasma. Thanks are due to Hypertherm for the valuable psot.
Nature is so graceful and naked. Human possession is ridiculous.
Re: What is Plasma?
03/31/2010 1:38 PM
When we add more energy, the water vaporizes into hydrogen and oxygen, in the form of steam. NOPE, NOPE, NOPE.
United States - Member - Member in Good Standing
Good Answers: 61
Re: What is Plasma?
03/31/2010 4:51 PM
Not quite true. Water goes through several disassociations as you increase it's energy levels. Obviously, we go from ice to liquid, and then from liquid to vapor or steam, depending upon how hot and dense it is. Remember though that water vapor is supported by the air itself, whereas steam relies upon it's energy level to maintain it's gaseous state.
Now however, if enough energy is pumped into the steam, the molecular bonds will be broken and you will be left with H2 and O2 gas. Given enough energy, the gasses will ionize, and yes, you will have a plasma. But it will take on hell of a lot of energy. And of course as the plasma loses energy it will tend to reform into water vapor once again.
DrMoose
Good Answers: 74
Re: What is Plasma?
04/01/2010 6:53 PM
DrMoose
"Now however, if enough energy is pumped into the steam, the molecular bonds will be broken and you will be left with H2 and O2 gas."
I seem to have the same understanding as
Rebuilt
and then thought that the statement must be a typo in an otherwise well written and informative post.
"Given enough energy, the gasses will ionize,"
Would that energy not be equivalent to the energy required in an electrolytic process? Do you have any formulas regarding this. I can't find any information about the direct relation between the, by then critical heat of the steam and the energy needed to go that extra step.
My question is really: could not hydraulic pressure cause this heat and create this "true" phase change of water to H2+O2. What is a hell of lot of energy? I will try a few other searches on this but would appreciate if you could supply me with a link or published study. I would really like to follow this up and expand my knowledge and I think Rebuilt could rebuilt his understanding as well.
Thanks for the hint, Ky.
The Twain Has Met
Good Answers: 74
Re: What is Plasma?
04/01/2010 7:37 PM
Sorry if I have taken up any of your time to find a link. I have found this (slaps his fore head the lazy bastard)
Hydrogen Evolution by Plasma Electrolysis in Aqueous Solution pdf
I will have a bit of reading to do. Very interesting, what a serendipitous world we live in, Ky.
The Twain Has Met
Re: What is Plasma?
04/01/2010 11:34 PM
Ky, can you post that as a link, or somehow provide a path to the file? It doesn't come out linked in my browser, or even as a valid file name (for one thing, no period before the "pdf"). I'd like to track that down and read it. (I know, slap MY forehead for being lazy, but you DID look it up. I presume you WANT us to benefit from your labor. Just say no, and I'll go find it.)
Thanks
Good Answers: 74
Re: What is Plasma?
04/02/2010 2:05 AM
Sorry Mica I just found it accidentally and cant remember from were. Here is a bit more info directly from the pdf
Hydrogen Evolution by Plasma Electrolysis in Aqueous SolutionTadahiko MIZUNO, Tadashi AKIMOTO, Kazuhisa AZUMI1, Tadayoshi OHMORI2,Yoshiaki AOKI3 and Akito TAKAHASHI4Division of Quantum Energy Engineering, Graduate School of Engineering, Hokkaido University, Kita 13 Nishi 8, Kita-ku, Sapporo 060-8628, Japan1Division of Molecular Science, Graduate School of Engineering, Hokkaido University, Kita 13 Nishi 8, Kita-ku, Sapporo 060-8628, Japan2Catalysis Research Center, Hokkaido University, Kita 11 Nishi 10, Kita-ku, Sapporo 060, Japan3Center for Advanced Research of Energy Technology of Hokkaido University, Kita 13 Nishi 8, Kita-ku, Sapporo 060-8628, Japan4Department of Nuclear Engineering, Graduate School of Engineering, Osaka University, 2-1 Yamadaoka, Suita, Osaka 565-0871, Japan
(Received January 26, 2004; accepted October 4, 2004; published January 11, 2005)
Hope this helps, Ky.
The Twain Has Met
Re: What is Plasma?
04/02/2010 3:37 PM
Thanks, Ky. From that I think I can find it.
Re: What is Plasma?
04/01/2010 8:50 PM
To be fair, I should say I liked all of Hypertherm's blog except for that one line I disagreed with. Thanks for the info. By the way, I didn't know how you could start the darn thing up.
DrMoose (1); ky (3); micahd02 (2); Rebuilt (2); s.udhayamarthandan (1)
