The question as it appears in the 02/20 edition of Specs & Techs from GlobalSpec:
John and Tom went four wheeling in the desert. In the early afternoon, Tom notices his four wheeler has a radiator leak. To the southwest Tom spots some water. John says they should make sure it's not a mirage before heading off in that direction. Tom agrees and reaches into his pack for sunglasses. How will they determine whether or not the water is a mirage?
(Update 8:55 AM EST 02/27/07) And the Answer is....
Light reflecting off of water is linearly polarized. Light from mirages however are not polarized at all. Light from a mirage is bent from refraction, not by reflection. A layer of very hot air close to the ground is lower density then the air above, light is bent (refracted) away from the ground and toward the far away viewer. Since the light is merely sunlight that is bent, it is not polarized. If Tom were to hold his sunglasses between himself and the water and rotate them, the intensity of the image of the water should vary if it is real do to the polarizer on the sunglasses, if it is a mirage, the water will look the same no matter how the sunglasses are rotated.
In reply to #81
Find in discussion
