Motorz Blog
Motorz
How many times have you watched automotive how-to shows on cable TV and wondered how they make it look so easy, and where did they get all those expensive tools? If you're like most automotive enthusiasts, you don't have any of those awesome tools, let alone a lift in your garage.
To Chris Duke, host of the web TV show, iTunes podcast, and TV program Motorz, keeping how-to installations real for enthusiasts became his calling. By showing the average Joe how to install products on his vehicle using common tools he has in his garage, anyone can walk away from an episode having the confidence to go out and buy that product they always wanted on their ride and install it themselves.
Previous in Blog: DIY Ford F-150 Gear Swap   Next in Blog: DIY Jeep CJ5 Lift Kit
3 comments
Spark Plugs
Posted July 08, 2010 12:01 AM by motorztv
In this episode, Motorz TV shows you to properly remove, inspect, clean and re-install spark plugs. Host Chris Duke also examines high-performance spark plugs and explains why they're so much better. This episode also includes a special segment from E3 Spark Plugs in which Stacey David from Gearz TV at Michigan Technological University discusses spark plug technology with engineers.
Watch the Video
Re: Spark Plugs
07/09/2010 12:20 PM
Oh puleeze. High performance spark plugs are the high-performance way to separate a driver and their hard-earned money. A bunch of pseudo-scientific fluff and super-high advertising costs. (Think Monster Cable) I can understand spending the money on a quality longer-life plug using platinum or other precious metals because it will save you the pain of changing the plugs as often.
I used to fall for that crap back in my impressionable youth, but today's vehicles will not achieve ANY performance benefit from anything more than the stock plug. The demise of leaded gasolines mean you can easily get 100,000 miles or more out of a set of quality plugs. And when you consider how deep some manufacturers bury the plugs, that is a significant benefit.
Most of these "gearhead" TV shows are little more than thinly disguised infomercials. They do have some good tid-bits here and there, but they are primarily used to showcase a sponsor's product. I challenge anyone to take a modern engine with the stock plugs, put it on the dyno and take a reading. Then change out the plugs for a "performance" set and run it again. I'd wager a month's salary there won't be any differences greater than the uncertainty of the measurement equipment.
Don't waste your money.
Good Answers: 97
Re: Spark Plugs
07/10/2010 12:42 AM
I remember a "gimmicky" plug I believe was developed for Mercury outboards and later used in the Kawasaki Mach series. It was termed a "surface gap" plug. This plug worked well with the early CD ignition systems, in two strokes before synthetic oils were common.
Come to think of it, the key might have been the major increase in voltage.
CRTL-Z
Re: Spark Plugs
07/10/2010 10:37 PM
...Sir P.T. Barnum would be proud!
...I've heard the Africa elephants work better with platinum plugs, while the Asian elephants work better with iridium plugs. And, the native-American elephants work better with surface-gap plugs (wink,wink).
70AARCuda (1); Brave Sir Robin (1); Unredundant (1)
You might be interested in: Power Plugs, Plugs, Stoppers and Inserts, Bus Plugs
