Motorz Blog
Motorz
How many times have you watched automotive how-to shows on cable TV and wondered how they make it look so easy, and where did they get all those expensive tools? If you're like most automotive enthusiasts, you don't have any of those awesome tools, let alone a lift in your garage.
To Chris Duke, host of the web TV show, iTunes podcast, and TV program Motorz, keeping how-to installations real for enthusiasts became his calling. By showing the average Joe how to install products on his vehicle using common tools he has in his garage, anyone can walk away from an episode having the confidence to go out and buy that product they always wanted on their ride and install it themselves.
Previous in Blog: Spark Plugs   Next in Blog: Video: Brake Installation and Maintenance
DIY Jeep CJ5 Lift Kit
Posted October 23, 2010 9:00 AM by motorztv
In this episode, Chris Duke from Motorz shows you how to remove an old 2-inch lift kit from his 1968 Jeep CJ project vehicle, "Blue Dog", and install a new 2-inch suspension lift kit from Skyjacker. This change-out sets the stage for a future episode, when Chris completes a spring-over-axle conversion to provide additional height for a larger wheel and tire combination.
The new suspension lift kit includes leaf springs, shocks, a new Pitman arm, steering stabilizers, and all the necessary hardware. After jacking up the Jeep's axles and using platforms for some additional support, Chris explains how to remove the shocks, u-bolts, and springs. To do this work yourself, you'll need ratchets and extensions, sockets, diagonal cutters, a torque wrench, flat screwdrivers, white lithium grease, a 3-inch gear puller, and a pickle fork.
Watch the Episode
You might be interested in: Lift Tables, Lift Stations, Lifts
