Previous in Blog: This Is China's Secret Stealth Strike Fighter   Next in Blog: Nissan Has Turned Real-Life Driving Into an Environmentally-Friendly Game
3 comments
Splitting Water with Sun Power Means Cheap and Easy Hydrogen Fuel
Posted December 28, 2010 10:20 AM
From DVICE:
Electric cars are great for the environment, but if you want to drive more than a hundred miles or so, your best option is still gasoline. Hydrogen fuel is an ideal compromise, and a new type of solar power plant could suck it straight out of water.
Re: Splitting Water with Sun Power Means Cheap and Easy Hydrogen Fuel
12/29/2010 2:17 PM
Any time someone says that something is cheap and easy, it's NEITHER.
Ugh. I get so tired of this inane crap but to the under-informed "public" it has an air of believability that creates a false sense of feasibility. If the ROI was there, someone would be doing it already and you would see these solar concentrators popping up all over the place.
Rant over.
Good Answers: 130
12/29/2010 3:23 PM
I don't see why you're so "ranty".
All you need is;
a tracking solar furnace ("Stay-Kleen" model, obviously)
with a high temperature vacuum/pressure flask,
a chunk of purified sintered cerium,
a triple distiller,
a metered injector
an oxygen inert vacuum pump,
a hydrogen vacuum pump/compressor,
suitable hydrogen leak-proof storage,
a temperature cycling system,
appropriate sensors, programing, servos and motor drives
And with that you get 1% efficient, hopefully 20 times more, conversion at source - the latter of which might get enough hydrogen to run all the above stuff.
United States - Member - Member in Good Standing
Good Answers: 61
12/29/2010 3:30 PM
While I tend to agree with you on the ROI, I also think that "solar H2"is a good idea. We had a rather long discussion on hydrogen as a fuel back in October 2008 which is worth reviewing. http://cr4.globalspec.com/blogentry/7032/Where-Are-All-The-Hydrogen-Cars
DrMoose
34point5 (1); Brave Sir Robin (1); DrMoose (1)
You might be interested in: Fuel Cells, Fuel Testers, Fuel Dispensing Equipment
