In last week's discussion on 235U fuelled fission reactors Cardio-2 mentioned the use of thorium, 232Th, as fuel rather than 235U. This week I would like to discuss 232Th reactors in detail.
A 232Th reactor uses fission like the 235U reactors but there is a subtle difference in the way the reaction is moderated. Unlike 235U, 232Th will not sustain the fission reaction by itself. 232Th needs to be forced to fissile by bombarding it with slow moving neutrons. A 232Th reactor uses a core of 232Th and a neutron source. The neutron source is used to bombard the core and causes the 232Th to fissile and release vast amounts of energy. The reaction is a little more complex than the 235U fission so I will not go into it in depth.
The important factor is 232Th will not fission unless it is bombarded with neutrons from an external source and this makes the process inherently stable. In the event of a problem, all you need to do is shut off the source of neutrons and the fission stops. This makes it impossible to have a runaway chain reaction that could result in an explosion or melt down.
Thorium 232Th reactors have several other advantages as well.
- They produce far less radioactive waste, about 3% compared to a 235U. The waste also remains radioactive for 500 years compared to the 250,000 to 20 million years for the 235U reactors.
- They can be used to burn Plutonium in the core as well as 232Th. This makes them a very effective way of getting rid of one of the most toxic substances known while reducing the amount of material available for the construction of nuclear weapons.
- 232Th is more abundant than 235U and requires considerably less processing to make it suitable for use in reactors.
It's not all good news however and one of the disadvantages of 232Th cores is that they need to be about twice the size of a conventional 235U core and this adds considerably to the cost of construction.
Currently, there are reactors under construction in Spain and India and considerable further research needs to be carried out before the technology is ready for wide-scale use.
The following link will give you some more background information on the concept.
Wise News Article
232Th reactors would appear to have the potential to play a major part in reducing our dependence on fossil fuels. We have however heard this before and the use of 235U reactors was once touted as the ultimate non polluting energy source.
What do you think? Are 232Th reactors the answer to our energy needs or are they just another form of nuclear power? Is the concept of storing the waste for 500 years acceptable or just as difficult to achieve as storing the waste for 250,000 years. Considering they can be used to destroy much of the waste from existing nuclear reactors and weapons, can we afford not to build and use them?
