CanDU is a contraction of Canadian Deuterium Uranium and roughly describes the type of reactor. A CanDU reactor consists of a series of horizontal pressure vessels that contain the fissile material and coolant that, are in turn, surrounded by the moderating medium. Heavy water or D2O is used as both the moderator and cooling medium. The coolant is passed through the horizontal pressure vessels at high pressure and is used to transfer the energy to a heat exchanger and ultimately turbines to generate power. The pressure tubes are surrounded by more D2O but at low pressure that acts as the moderator for the process. The pressure tubes are arranged in a way which enables the fuel elements, in a single pressure tube, to be replaced without disturbing the other tubes. This allows the reactor to be refueled and the core rearranged without shutting down the reactor.
The CanDU reactor design has several advantages over its counterparts:
· On Line Refueling Due to the arrangement of the pressure tubes that contain the fuel elements, it is possible to refuel the reactor while it is operating. This is achieved by taking one of the pressure tubes off line and inserting new fuel elements at one end. The spent elements are then recovered as they are forced out the other end of the pressure tube.
· On Line Core Adjustment Due to natural and manufacturing inconsistencies, there will always be a variation in the concentration of fissile material in fuel elements. This resultant uneven fission throughout the core produces uneven heating and consumption of the fuel elements. As the CanDU system allows for the on line replacement and redistribution of the fuel elements, these variations can be greatly minimized and this extends the life of the fuel and increases overall efficiency.
· Greater Percentage of Theoretical Output Because CanDU reactors can be refueled on line they are not subject to the lengthy shutdown refueling procedures other reactor designs are. As a result the ratio of actual output to theoretical maximum output can be as high as 85%. This is a considerable improvement over other designs.
· More Flexible Fuel Requirements The use of D2O as the moderator enable the CanDU reactors to use un-enriched uranium rather than the enriched uranium other reactors require. They can actually use the enriched spent fuel elements from other reactors. CanDU reactors are not tied to the use of uranium fuel elements either, and with a certain amount of modification, in theory, could use thorium as a fuel. They can also be used to accelerate the decay of weapons grade core materials like plutonium.
The system looks fairly promising on the surface but like everything it does have its drawbacks. One of the primary negatives is the huge amounts of heavy water or D2O they require. This adds to the initial const of construction considerably. There have also been problems with both normal operations and refurbishment that have contributed to the extent and severity of wide scale power outages in Canada and the north east of the USA.
Whilst the waste quantity and level of contamination produced by CanDU reactors is less than other uranium fueled reactors, it is not zero. The waste, like that of other uranium fueled reactors, requires special attention and handling precautions after it is removed. You can read more about CanDU reactor design and technology by following these links:
It's over to you. Are the problems that Canada is experiencing due to a flawed design, or as some suggest, just poor management? Is the concept of the CanDU reactor one of the answers to our energy needs, or just more of the same, with a different name and appearance? In a time of potential disastrous global warming can we afford not to utilize the CanDU reactor technology operational?
