Engine-development company, Scuderi Group, recently announced
a new engine design that boasts a 50% increase in fuel economy compared to
conventional engines. The design is based on the standard split-cycle engines,
but with some slight changes and new features.
While standard engines employ a four-stroke cycle, the Scuderi
split-cycle divides engine functions between two neighboring cylinders. After
one cylinder draws in air and compresses it, the compressed air is moved
through a tube to the second cylinder. Once the air is moved, fuel is added and
combustion occurs.
In the new design, air intake is kept open at all times. Air
that is not needed for combustion is stored in an air tank. When the tank
becomes full, the piston stops compressing while the contained air is used to
power the engine.
Do you see an opportunity for split-cycle engines?
Source: Technology Review
