HVAC Blog Blog
HVAC Blog
Previous in Blog: Let Diversity Dictate HVAC Use   Next in Blog: The Costs of Going Green
2 comments
Holistic HVAC?
Posted January 27, 2011 8:30 AM by Steve Melito
Central plant chilled-water systems are expensive to operate. Depending on the climate and HVAC configuration, these air and equipment cooling systems can consume over 30% of the energy needed to run a building. Traditionally, plant and facilities managers considered HVAC systems in terms of component capabilities, especially in terms of operating costs. Today, most managers also consider an HVAC system's environmental impact. But what about the environment in which HVAC components operate?
Some HVAC suppliers, such as Johnson Controls, are encouraging their customers to take a "holistic approach". That mindset, explains Joseph Walicki, vice president and general manager of Johnson Controls in North America, applies not only to "plant design and operations," but to return on investment (ROI). Operating costs and environmental impact are still important to consider, too, but central plan optimization (CPO) is more than the sum of its parts.
According to the company's website, new system-level automation software will enable customers to achieve "persistent peak performance and energy savings in central plants in both new construction and existing building. The new Johnson Controls product, CPO 10, is designed to select the "most efficient" combination of chillers, cooling towers, and pumps to meet the building cooling load. Energy savings can reach as high as 15%.
Do you plan to take a more "holistic approach" when you purchase HVAC products?
Source: Johnson Controls
Re: Holistic HVAC?
01/28/2011 5:28 AM
This is an advertisement and does not belong on this thread.If you want to push sales, build a better mousetrap, yours isn't the best way to catch a mouse. Your products aren't terrible but I wouldn't recruit your people. That's the reason for the constant battle for market share in markets like Manhattan.
Re: Holistic HVAC?
01/31/2011 6:24 AM
This as Moose observes just a sales 'flyer'. Johnson are just one of a bevvy pushing HVAC stuff. The only thing you can be sure of is that the latest product does not sit comfortably alongside previous kit and because of a lack of an industry standard their stuff will not work with others.
When you add in early obsolescence the life cycle costs of this type of equipment looks very unrewarding. the HVAC industry should take a leave out of the Process industry's portfolio and give longterm guarantees of performance and product support.
Skarne
You might be interested in: HVAC Chillers, HVAC Services, HVAC Ductwork
