Now that more states and communities are taking action
against hydraulic fracking, companies are scrambling to find alternatives that won't
result in water supply contamination. One such company is GASFRAC Energy Services
out of Canada whose liquefied petroleum gas (LPG) fracking process is being
billed as an eco-friendly solution to conventional fracking.
GasFrac's method uses propane gel instead of the combination
of water and chemical solutions currently used in natural gas extraction.
Without the reliance on water, there are no resulting waste streams or a need
for trucks to bring and remove the water from ponds, or other bodies of water.
Robert Lestz, Chief Technology Officer at GasFrac, says that
propane fracking is no different than what occurs naturally. "Everything
that we create when we frack is effective after the job, because propane goes
down as a liquid and comes back up as a gas," he said.
Do you see benefits in propane fracking?
Source: Central
NY YNN
