This week I would like to look at high temperature nuclear fusion. Now before everybody jumps in with "what about cold fusion", I would ask you to be patient. Next week I will start a thread on cold fusion. I just thought it would be better, if we first looked at a process that most people agree on the science that is behind it.
Nuclear fusion is the opposite of nuclear fission and put simply it is the combining of two smaller nuclei to form a single larger nucleus.
The nucleus of an atom consists of at least one proton and with the exception of hydrogen-1 1H, a number of neutrons. The whole thing boils down to the balance between two fundamental forces, the electromagnetic force which is trying to tear the nucleus apart and the strong nucleic force which holds it together. The two forces reduce with distance except that the strong nucleic force reduces fare more rapidly and is only affective at an extremely short distance. Without going into too much detail, the interaction of these two forces means that atoms that are less massive than nickel and iron will give off energy during fusion while more massive ones will absorb energy.
Unfortunately it is not easy to force the nuclei of two atoms together. The electrostatic repulsion of the positively charged protons increases exponentially as the distance reduces and the strong nucleic force dose not take over until the two nuclei are extremely close together. The result is that you need to expend large amounts of energy pushing the nuclei together before you can get fusion to occur. The important factor is the amount of energy that is released when the fission takes place. Compared to a chemical process nuclear fusion can release as much as 106 times as much energy.
It is not a simple as just heating a substance either,. temperature is really an average measurement of the speed of all the particles and there will be a spread of actual speeds within any sample. As a result some of the faster particles may have enough energy to cause two nuclei to fuse at considerably lower temperatures. The problem is that unless the temperatures and pressures are both extremely high the number of nuclei that fuse becomes too low to yield any sort of useful energy. Even at the core of the Sun the chances of fusion occurring is so low that the energy output is only about 100 mw m-3. For comparison, this is around 0.1% of the energy density of a person relaxing in a comfortable chair.
There are numerous ways to trigger a nuclear fusion reaction but to date the only way to get anyway near a return of the trigger energy and workable output to volume ratio is to use extremely high temperature and pressure simultaneously. Attaining the conditions to trigger the reaction is hard enough but you need to contain it as well and this makes it even harder. No physical container could ever come close to containing the temperatures and pressures required so the only solution is to turn the fuel into plasma and contain it within a magnetic field.
Fusion is also not completely clean and while the process is taking place it emits high energy gamma radiation that needs to be contained within some sort of containment vessel. Over time this containment vessel will be damaged by the radiation coming from the fusion process and ultimately becomes radioactive itself. Whilst it doesn't end up being as dangerous as the core of fission reactors or remain dangerous for anywhere near as long, it still requires long term special handling precautions.
Fusion also has its detractors. Some believe that the money currently being spent on fusion, a technology they point out may ultimately prove to be impractical, would be better spent on developing renewable energy sources. Some even joke that nuclear fusion has been a decade away for several decades now.
You can read more about nuclear fusion by following these links:
How do you see nuclear fusion? Is it the solution to our energy needs, can a workable fusion reactor be built within a useful time frame or would the money and effort be better spent developing other technologies?
