Electrical Components Blog
Previous in Blog: Ever Had a Good Boss?   Next in Blog: Opening the Next Windows
17 comments
Is Simpler Better for Fail-safe?
Posted April 29, 2011 7:00 AM
In a world of hyper-automated everything, a fair question is what happens to our perceived "reliability" when the power goes out, a wire breaks, a computer chip overheats or a sensor sticks. Multiple redundancy can reduce the chance of failure at great additional expense, but sometimes less is more. Do you have some favorite examples of simple, elegant, and extremely fail-safe engineering designs?
The preceding article is a "sneak peek" from Electrical Components, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Electrical Components today.
Re: Is Simpler Better for Fail-safe?
04/29/2011 8:06 AM
The manual hand crank to raise and lower automotive windows.
Having replaced electric window motors, this is one of my favorites. They will work without problems for decades.
04/29/2011 8:36 AM
A manual hand crank to raise and lower control rods in a nuclear power plant. Unfortunately they don't employ them. Sucks doesn't it?
04/29/2011 8:47 AM
Personally, I prefer something mechanical to get something done as opposed to something electronic almost every time. Not only can I look at it and understand how it works, but I can usually fix it if it breaks.
05/02/2011 11:59 AM
I don't know why but the first thing that came to my mind when I read that you prefer mechanical to electric, was the old brace & bit drill. Do you prefer one of those? I think I have one that my Dad had, but never used it much. My Dad had a lumber yard. I do remember in my teenage years, I would work during the summer as a carpenter's helper. One of them seemed to like to use a brace/bit for installing door knobs and keepers. And electric drills were certainly available.
05/02/2011 1:50 PM
Didn't mean to confuse you. I said mechanical to electronic, not electric. I was referring more to controllers, etc.............I also said, almost always.
04/29/2011 9:00 AM
Or take advantage of gravity--design something that holds the control rods up using power--on loss of power, have them lower automatically (I mean, by gravity) (presumably with something to keep them from simply falling and possibly damaging themselves or some part of the reactor).
I would hope by now most designs are like that, but I sort of doubt it. ;-)
04/29/2011 11:58 AM
One of my favorites is the 'Space Pen', developed for astronauts to use in zero gravity. Regular ink pens rely on gravity, and will not work in space. Millions of US dollars invested, just to write a note. Meanwhile, the Soviet space program solved the problem for their cosmonauts with a different tack: they used pencils.
This is an urban legend, but has some value as an illustration of too much engineering. Sometimes, simple can be better.
An interesting aside, nobody I have given this example to has ever questioned it as being factual or not... but I always come clean in the end.
04/29/2011 1:12 PM
Do FMEA. ( Failure Effect Mode Analysis ).
We may need to proactively think & eliminate the causes for failures.
Regards,
04/29/2011 1:15 PM
Sucks syntax, doesn't it?
04/29/2011 11:42 PM
That's what FEMA did (or not)!
04/30/2011 12:47 PM
One that sticks out in my mind is the modern gas stoves that have electric ignitionsand saftey interlocks on them.
Back years ago if the power went out for an extended time you could still keep your house above freezing, in most cases, by running the old gas stove as a back up heat source.
Now that doesn't work being that if the power goes out the stupid electronic igntion and saftey related circuitry goes dead and the stoves are unuseable without it.
05/02/2011 12:20 AM
Gas stoves don't have a gas cutoff valve that operates in the event of a loss of power to the electric ignition (do they?), so what about a good old fashioned match?
05/02/2011 6:50 AM
Re: Gas stoves don't have a gas cutoff valve that operates in the event of a loss of power to the electric ignition (do they?), so what about a good old fashioned match?
I should wait for somebody else who really knows to confirm this, but I'd bet they do (modern gas stoves, at least), or maybe the inverse, the gas valves won't open without electricity. (I don't like speculating, but I do it at times... ;-)
Of course, if you have a (modern) gas stove, you can turn off the electricity and try to light a burner and find out for sure. ;-)
05/02/2011 6:58 AM
Mine is a newer model. The stove top burners work, I just have to light them manually. The oven won't.
05/02/2011 7:10 AM
Thanks!
05/03/2011 5:47 AM
A gorgeous view in your blog comment ..
Thanks,
Drug Test
05/03/2011 11:12 PM
Tell that to the people making consumer products like dryers. Currently some have 3 temp senors and 2 breakers that can reset or show as good on ohm meter but not handel watts.
$800 for a dryer ? I have to repair or putting up a clothes line.
Anonymous Poster (1); dadw5boys (1); Doorman (2); drugtest (1); jack of all trades (1); kramarat (4); rhkramer (3); Sganesh (1); tcmtech (1); Tornado (1); ZenZeddmore (1)
