Previous in Blog: When Will Renewables Win the Race?   Next in Blog: Is the U.S. Ready for New Nukes?
42 comments
Nuclear Batteries: Brilliant or Disastrous?
Posted June 08, 2011 11:47 AM
TIME Magazine recently unveiled a portable nuclear battery that produces 1/40th the power of a full-sized nuclear reactor. This could be a brilliant way to address energy needs, but it could also literally be a ticking time bomb. Should portable nuclear reactors be pursued? Or do the dangers outweigh the benefits?
The preceding article is a "sneak peek" from Power Generation & Distribution, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Power Generation & Distribution today.
Re: Nuclear Batteries: Brilliant or Disastrous?
06/08/2011 1:19 PM
Re: Should portable nuclear reactors be pursued?
Yes.
Re: Or do the dangers outweigh the benefits?
Nobody really knows, do they? But there are some interesting ideas out there for small nuclear reactors that have some failsafe type features. They need to be developed and tried out. Maybe first in Antartica or similar, but somewhere.
Also, they typically have smaller quantities of fissionables installed, so less of a risk from that point of view also.
Good Answers: 38
06/08/2011 3:12 PM
I wonder why they're terming it a battery. I heard talk/rumors in my days operating a nuke plant of companies/government creating small reactors that operated slightly different. The reactor would be operated below the point where any substantial heat is generated and the principal energy harvested was the radiation, not the heat. The thought was to use layers of PV cells in lieu of shielding that simply absorbed it.
I wonder if that is the case here or if "battery" is just a resemblance of its size and portability.
Good Answers: 204
06/08/2011 11:19 PM
I have a book (somewhere) that describes an "Atomic Battery"
I always thought it was a good use for nuclear waste.
chris
06/08/2011 4:16 PM
Here is a link to the TIME article.
From there: "...the nuclear battery - so called because it is cheap, small and easily transportable - is about the size of a refrigerator... It produces 25 megawatts of electricity... has been designed to power subdivisions or towns with fewer than 20,000 homes, as well as military bases, mining operations, desalination plants and even commercial ships, including cruise liners."
WHY are these not everywhere?
Oh, that ticking time bomb thing probably.
06/08/2011 4:38 PM
Thanks for the link. Something doesn't seem kosher. 25 megawatts and the size of a refrigerator??
I can't imagine that. Just imagine the size of wires, terminations, and such to handle that much power--imagine that they are producing single phase power, and imagine it is being generated at 25,000 volts--they'd need 1000 amps at that voltage. What's that, something like 4 1000mcm cables for each of the the phase and neutral? And the size of the insulators for 25 kv. Or, assume it's generated at 250 volts--now you've got smaller insulators, but you have to handle 100,000 amps..
Or, make it 3 phase, and (in the scenarios above) divide either the voltage or current by the squareroot of 3--now you've cut down either the copper or insulator size, but have 3 of each instead of for insulators, one of each, or, for current carrying conductors 1 1/2 times as many.
Or, is this just a steam creating device and on site you must provide a generator? Then saying it is refrigerator sized is a little misleading.
Then think about having 25 megawatts of "potential energy" (I know, wrong units) in a space the size of a refrigerator.
The article is not very forthcoming with details.
06/08/2011 6:26 PM
I agree, the article is not an information rich environment.
Size of a fridge, 25 MW, about 25 people to keep it running... How do you get 25 people in a fridge? I think you are on the right track: the core is the size of a fridge, and the ancillary stuff is aside that... but how portable does all of that become?
It is a TIME article intended for the masses, not mainstream engineering information.
Good Answers: 38
06/08/2011 6:35 PM
I'd agree this is just the core size.
The last I heard there were a couple designs that were trying to get licensed. Both were gas cooled, closed Brayton cycle, with the reactor taking the place of the combustors on a typical gas turbine (gt). The gt being coupled to a generator.
One core + 1 or 2 GT generators (25MW) + switchgear for $100 million seems reasonable...
06/09/2011 6:21 AM
I agree, 25 megawatts coming out of something the size of a refrigerator sounds a bit high, unless it is glowing white hot.
Good Answers: 38
06/09/2011 9:38 AM
It isn't really that high. Do a quick thermal calculation and you'll see it amounts to heating about 7 cubic meters of water 50C per minute. That's sounds far from white hot to me.
06/09/2011 10:32 AM
Ok, running through the calculations, I agree with you.
You are going to heat about 125,000 gallons of water per hour by 50 degrees C. An hours worth of water will occupy a little more space than a refrigerator. ;-)
So, where are you going to keep that much water, cool it, and how are you going to move it. You'd need a pump rated at about 125,000 GPH and a large source of water, or a large cooling tower.
And, if you don't have that much water, what color will the refrigerator sized unit glow at? ;-)
Aside: Confirming the calculation:
25 megawatts is 25,000 kilowatts
1 kilowatt is ~3414 BTU/hr.
So, 25 megawatts is ~ 85 million BTU/hr.
Assuming a 50 degree C rise (90 degrees F), that's about a million lbs. of water per hour. That's about 16,700 lbs. of water per minute. And, yes, that's about 7 cubic meter (because a cubic meter of water weighs about 1 kilogram, or 2200 lbs.)
So, I agree with you. Now, where are you going to keep that much water, cool it, and how are you going to move it. You'd need a pump rated at about 125,000 GPH and a large source of water, or a large cooling tower.
Good Answers: 38
06/09/2011 11:10 AM
It isn't that you have to have 125,000 gallons of water, it could simply be a closed circuit with say 1000 gallons that goes through a complete cycle twice a minute (and yes, reactor coolant pumps do pump alot of water, but typically at a low head). As for cooling it, that's where steam generators come in, remove heat from the coolant and provide input for a steam turbine.
Good Answers: 38
06/09/2011 11:48 AM
confirm a quick flow calc too... If we assume a 3 ft x 3 ft dimension (roughly a typical refrigerator), at a flow rate of 125,000 gal/hr, the water would be screaming through that reactor at... about 0.5 ft/s
Pretty crazy huh?
06/09/2011 12:04 PM
Maybe I'm still hung up on the "size of a refrigerator" thing. A pump capable of 125,000 gpm, a steam turbine and generator, a cooling tower, 1000 gallons of water maybe--probably a little bigger than a refrigerator.
Good Answers: 213
06/09/2011 12:12 PM
One of the things about the Toshiba system (and possibly the Hyperion system, but I am not sure) is that primary cooling is done with molten sulfur, not water...
06/09/2011 12:21 PM
Actually, the Toshiba system's primary cooling is done with liquid sodium.
The Hyperion system uses (presumably liquid / molten) Lead Bismuth (PbBi).
Good Answers: 213
06/09/2011 12:33 PM
I knew it began with an s, sorry I got the rest of the word wrong...
Good Answers: 38
06/09/2011 12:41 PM
If I'm reading the fact sheet from Hyperion correct, it is liquid metal cooled (lead and bismuth)
Disregard for being redundant...
Good Answers: 130
06/09/2011 7:29 PM
I do worry when metric and Imperial values are converted.
"(because a cubic meter of water weighs about 1 kilogram, or 2200 lbs.)"
(just kidding rh)
06/09/2011 10:22 PM
Oops, yeah--should have been 1000 kgs. Good catch!
06/08/2011 6:25 PM
Sounds good to me. One day they will find a way to extract every drop of energy from nuclear, ( I hope), whatever waste is left will be harmless, and they will power everything.
That would be nice.
Sounds like a good thread/blog title.................Is there a way, or is it possible to extract energy from nukes to the point that the waste is relatively harmless?
I don't know the answer and I can't start the thread..................I'll be gone for a while come Saturday..........................I'll be back though.
Good Answers: 213
06/08/2011 11:15 PM
Here is an article about the Toshiba 4S that is undergoing regulatory evaluation for installation in Galena, Alaska- a bit bigger than an refrigerator, but the closest "mini-nuke" to commercialization. More on the Toshiba 4S. Or, direct from Toshiba. A little bigger than a refrigerator...
Here is a fact sheet from Hyperion Power, a spin-off from Los Alamos National Laboratories in New Mexico, attempting to commercialize US Government sponsored technology.
Here is information about the Russian "floating Power Plant".
There are several other proposals for portable nuclear power supplies out there- all but the Russian concept are inherently safer than the conventional approach.
A major roadblock appears to be that these are generally smaller capacity units that don't fit well into the standard "distributed power" business plan...
Canada - Member - New Member
06/08/2011 11:16 PM
The dangers outweigh the benefits.
06/09/2011 3:18 AM
Why going the hard way creating even more waste?
NASA did solve the problem years/decades ago: http://gltrs.grc.nasa.gov/reports/2007/TM-2007-214806.pdf
Just store the used fuel in machines like this and used fuel brings energy in stead of consuming.
This way the highly radioactive content has an economical benefit, so our kids Will not forget what is inside, and it will not get lost.
Good Answers: 25
06/09/2011 7:51 AM
For more details and specs please go to following link:-
http://www.hyperionpowergeneration.com/product.html
06/09/2011 8:03 AM
OK, it is a big freezer.
Each 10 years you need to replace the complete unit, the old remains active for decades.
You can of coarse still use it to heat buildings for decades.
06/09/2011 10:38 AM
The only way to know if the dangers outweigh the benefits is to continue the research, searching for ways to make it safe. Pursuing the research is the way to go. Decide whether to use them after you know what is involved.
Good Answers: 204
06/09/2011 1:32 PM
ya!
whats a little radiation between friends...
I've seen my ex go radioactive at times.
chris
Good Answers: 204
06/09/2011 7:14 PM
OT?
what for? seriously... she would generate electricity if you put her in front of a pv panel.
chris
Good Answers: 25
06/10/2011 6:28 AM
And you got high voltage shock?.
06/09/2011 2:22 PM
Hey I'm For It But Then you Have The Problems With Some Would Be Terrorist Using It Against Us. If There Could Be Some Way To Implement Strict Control Safeguards As Well As Adequate Disposal Facilities And Guidelines Then It Would Be A Brilliant Idea?
The Prophet
06/27/2011 10:34 PM
When was the last time a terrorist used radioactive material as a weapon against us?
Where are all the safeguards on the things terrorists actually have used recently against us....like carpet cutters?
Those are widely available but we are told those were instrumental in the 9/11 attacks.
There is no way to eliminate the risk of terrorism. If someone is determined enough, they will find a way.
The idea that good technology should be repressed lest it provide targets for terrorists is fear mongering.
If you truly want to consider the terror that might occur related to nuclear power.....consider how many people would not have access to clean water or sufficient food if all nuclear power plants were forced to close immediately. Then consider the dramatic increase in background radiation if all nuclear power plants were replaced with coal fired plants....true terror.
Reply Good Answer (Score 4)
Good Answers: 39
06/09/2011 3:26 PM
You're kidding right?
I'm sure they are idiot proof ......... until we design a better idiot. And what about someone who WANTS to create a problem with these devices? I fI buy 40 of them can I create my own melt down in my basement.
Whats next very "small" nukes for pest control and home defence?
All that is required for evil to succeed is for good men to do nothing.
06/10/2011 3:28 AM
'...but it also could literally be a ticking time bomb...'
No, no it can't also literally be a ticking time bomb.
I'm not contesting the remark as sensationalism based on recent events. I'm not even contesting the Remark based on the fact that there are nuclear technologies that have about as much possibility of exploding as playdough has (chech out irradiated halfnium control rods used as a nuclear battery with microwave trigger). Those ideas are apparent to those who make up their own minds.
I'm contesting the comment because, it isn't true, and I suspect isn't even what the writer intended to convey.
Unless it is actually a time bomb (not figuratively speaking) that is actually ticking, then it cannot 'literally be a ticking time bomb'.
People who use the term 'literally', should literally know what it means.
Good Answers: 109
06/16/2011 10:38 AM
Sooner or later you will have leak in the containment and then you and your neighbours are irradiated at levels much above Fukushima and similar events.
Don't think that you will ever get permission by any authority.
Spent nuclear fuel should be stored until next generation reactors are ready (see AECL.ca) these can burn most of the stuff as having enough reactivity.
Then reprocess and burn the high activity waste. This will give cut-down of storage time from 500K years to 5K years!
RHABE
06/17/2011 3:19 PM
Even if nuclear batteries could fill every energy need around the world, you'd still have to get the public okay with the idea that their town was being powered by something "nuclear." For most people, "nuclear" means catastrophic failure and destruction. Nuclear is often only perceived as a weapon and little more.
Good Answers: 130
06/28/2011 12:36 AM
I think much can be learned about the resistance to the technology in US media reaction to the Japan events. Primary fear was clearly the gas cloud reaching US soil.
"comment" then turned to the competence of the plant management in dealing with the problem and 'not foreseeing' the tsunami.
This, to me, has echoes of three mile island. The outfall of that, being 'management' focused.
The dichotomy is, with respect to radiation, that in many places cellars have to be checked for radon gas levels - so if Americans are really afraid of radiation why do so many opt happily to live right on top of high level natural sources?
The second question is why are the French so happy with the technology in their very own back yards? They have quite a list of incidents, yet seem quite calm about it.
I would suggest the fear is not so much of the technology, but of how it's managed.
Which, as I see it, all the 'regulations' now making it "nearly impossible", are actually aimed at. I.e. 'properly managed' it is uneconomic against 'cheap fossil'.
2¢
06/28/2011 7:28 AM
Re: Which, as I see it, all the 'regulations' now making it "nearly impossible", are actually aimed at. I.e. 'properly managed' it is uneconomic against 'cheap fossil'
Sorry, I don't understand that sentence, or the point you're trying to make.
Trying to work it out:
  • yes, proper management may cost more (at least short term) than improper management (e.g., "deferred maintenance"--or, is deferred maintenance proper management under some circumstances? ;-)
Good Answers: 130
06/28/2011 8:32 AM
A fair bit of comment is on the cost of meeting regulation.
The price of power in the US is very low by world standards, and very competitive. The natural tendency is to 'service the shareholders' and/or the investors in new plant.
Fossil you can cut to the bone and nothing much happens.
Nuclear you can't. There is no "(at least short term)" or you risk 3 mile or Chernobyl.
If you can't 'cut overheads' then you can't compete. And you can't just switch it off and sell it for scrap.
All equals small profits = poor investment - until coal, or power, gets more expensive.
06/28/2011 12:39 PM
Thanks!
06/28/2011 6:29 PM
'Properly managed nuclear power' may indeed cost more than 'cheap fossil', but that is comparing apples to aardvarks.
If held to the same standards for maximum permissable release of radioactive material into the environment the dominant fossil power source, coal, would be completely prohibitively expensive. The average 1000MW coal fired plant releases several tons of uranium and many more tons of thorium annually into the environment. Thorium and Uranium alpha decay and are particularly bad to breath or ingest.
Nuclear power plants on average release the equivolent of a tiny fraction of that to the environment over the entire lifetime. Every decade or two there is a bad reactor accident that puts that reactor on par with a similar sized coal plant for equivolent release.
The question is, do you want a system with an occassional accidental release, or a system that never has accidental releases, because it never bothers containing the radioactive material and so is always spilling (but certainly not by accident, by standard operation).
Coal is the cheapest of fossil fuel power, but held to similar standards for cleanliness it is far far more expensive than well managed nuclear power.
Good Answers: 130
06/28/2011 11:24 PM
I don't disagree about the reality of coal one jot.
The public is unaware of (or deaf to) everything you list above, and more.
Principally as; if you tried to 'regulate coal' to the same standards as nuclear - it equals "the price of power" and "third world doom".
Secondly - if you did - you wouldn't get any power out of coal.
Why? because that would be "Clean Coal" and who in the 'masses' really grasps enthalpy when most of the scientific and academic community 'go blank' on the concept when it comes to fossil fuels?
It's all about 'perception' - and 'misguided self interest' - not facts.
So in Topic terms - the first two are the hurdles to nuclear and 'deafness' to anything touching 'self interest' is the far larger hurdle.
07/13/2011 1:32 AM
Eventually we will simply launch all no usable radioactive waste into the sun.
Reply to Blog Entry 42 comments
129CBRider (1); 34point5 (4); Anonymous Poster (1); Apothicus (1); ChaoticIntellect (6); chrisg288 (3); cwarner7_11 (3); Doorman (2); Easyway (1); Gwen.Stouthuysen (2); kramarat (1); QuadTech (1); RHABE (1); rhkramer (8); Rixter (1); suresh sharma (2); The Prophet (1); truth is not a compromise (3)
