Medical Equipment Design Blog
The Medical Equipment Design Blog is the place for conversation and discussion about medical grade materials and products, electrical and electronic equipment, computers, imaging & software, and home healthcare & diagnostics as used in the medical industry. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: We Interrupt This Transmission...   Next in Blog: Rescued by the Phone
6 comments
A Call to Discard the Device Approval Process
Posted August 10, 2011 1:08 PM
In response to an apparent increase in medical device recalls due to failures and patient injuries, the Institute of Medicine recently released its long-awaited review of the 510(k) process. The report finds the device clearance process flawed and urges the agency to create a new integrated premarket and postmarket regulatory framework that is risk-based, grounded in sound science, and ensures safety throughout the device life cycle. Pushback from manufacturers has already been voiced. What's your reaction?
The preceding article is a "sneak peek" from Medical Equipment Design, a newsletter from GlobalSpec. To stay up-to-date and informed on industry trends, products, and technologies, subscribe to Medical Equipment Design today.
Re: A Call to Discard the Device Approval Process
08/11/2011 2:59 AM
The process certainly needs revising.
With any type of aproval you end up with over zealous types nit picking over trivia.
E.G.
On one pice of medical equipmant I once had a guy trying to reject it because an illuminated mains on/off switch with the O of the | symbol for on and off on it had the O symbol too oval.
The fact that the switch illuminated green when on was sufficient indication.
I told him that if he could tell it was supposed to be a O then it was obviously ok and wasn't too oval. Conversely if he couldn't tell that it was a O then it was obviously just a 'decorative feature' and thus not a failure as the illumiation was the thing providing indication.
You can immagine how many hours and phone calls the exchange took.
08/11/2011 4:33 AM
Just out of idle curiosity, what was the aspect ratio of the offending oval?
(If large enough to make it look like another I, that might be a problem.)
08/11/2011 5:08 AM
You are just teasing me now.
The bright green light was a good clue of when it was on.
It was a like a 0 not a O.
The only way it could possibly be a problem is if the symbols were raised and it was intended for use by someone blind, however the symbols were not raised and I expect there are special symbols for the blind.
Good Answers: 146
08/11/2011 4:37 PM
The trouble with the 510(k) process is that devices are approved on the basis of "substantial equivalency" to previously approved devices, without being tested.
It's not hard to see why this would lead to problems. Some other device was tested and the 'substantially equivalent' one approved afterwards does not have the same specs. Failures for medical devices can have injurious consequences, so by all means, testing should be rigorous.
In some cases, "substantially equivalent" products were approved on the basis of prior approved products which had not been tested in the first place! Yummy.
Obviously Del's example of the switch is the opposite of this! This is someone wanting a 'cosmetically' identical product in a way that has nothing to do with safety or effectiveness. Now, if the cosmetic nitpickers could be transferred to the 510(k) department where they belong, and put the happy rubber-stampers in charge of 'how oval can the O be' we'd all be better off...
incus opella
Good Answers: 97
08/12/2011 10:44 AM
Maybe artsmith or someone can help me out here
Some time I went in for a TURP, they used a GYRUS 744200.
At first " thought it was great , I was out of hospital on the third day , with no pain or discomfort.
But the improvement was not that spectacular.
I did a search and found
The Total Product Life Cycle 2007 - 2011 obtained from the MAUDE adverse effect reports to the FDA show 1 Death , 26 injuries , 232 malfunctions & 23 other. 2011 only show 2 incidents.
Some batches were withdrawn.
My questions are :
Did it improve over time or did they stop using it?
Are the failure rate low, high or medium?
Is the MAUDE reporting system trustworthy?
Good Answers: 146
08/12/2011 12:59 PM
Is the MAUDE system trustworthy?
From the FDA page:
"MAUDE data is not intended to be used either to evaluate rates of adverse events or to compare adverse event occurrence rates across devices."
No trustworthiness claims are made for the MAUDE system, on the contrary.....
There are only four results to a search for clinical studies on TURP GYRUS outcomes listed in PubMed to date. They indicate that GYRUS results are similar or better to monopolar, but that more studies may be called for. The simple search for TURP GYRUS returns 26 articles; 'TURP GYRUS device failure' and 'TURP GYRUS adverse events' returned no results, so there's nothing to indicate serious concerns about the device in medical practice. The MAUDE data may be the only available record of failures or malfunctions, at this point in time, except insofar as they may be reported in the individual studies under the search.
If some batches were withdrawn, it seems likely that a defect was identified and corrected. I would expect that the 2010 record would be your best gauge of the current state of affairs, since 2011 is only half through and it probably takes time for such reports to be made.
incus opella
artsmith (2); Hendrik (1); Tornado (1); user-deleted-1105 (2)
