Previous in Blog: Kenyan Air Force Tweets Somalis: We're About to Bomb You #Duck   Next in Blog: Mars Mission Makes Earth 'Return'
40 comments
Cold Fusion Experiment: Major Success or Big Hoax?
Posted November 03, 2011 1:00 PM
From Discovery News - Top Stories:
Theoretically, this type of power would provide radiation-free, cheap and virtually unlimited energy.
Re: Cold Fusion Experiment: Major Success or Big Hoax?
11/03/2011 2:15 PM
They are not sharing the data and experiment setup with anyone else, only customers, if I understand the article correctly.
So, no peer review = no science.
Good Answers: 299
11/03/2011 3:24 PM
Wilipedia article about the E-Cat device.
The whole thing sounds shakey. "Rossi states that the device probably works not due to "cold fusion", but due to weak interactions between nuclei, without actual fusion happening."
...probably works? Rossi is not certain how it works?
11/03/2011 5:06 PM
Complete and utter hogwash!!!!!!!!!
Let me support and present my reasons for my bold opinion.
As AH and Doorman have pointed out, these charlatans have not submitted their data for peer review so this is not real science.
These two claim that they have transmuted Nickel into Copper by cold fusing Nickel with Hydrogen. Well their proposed proton count is correct but they forget that there is a second particle that makes up the nucleus, the neutron. (Not the whole story, but I'm trying to keep this simple.) The most abundant isotope of Nickel (68%) is NI 58. Capturing a single proton (H) to the nucleus makes this CU 59 that has an 81.5 second half life that transmutes to NI 59 with a 76,000 year half life. Quickly this process returns to a reasonably stable form of NI. The next most abundant (26%) isotope, NI 60, becomes CU 61 with a three hour half life transmutes to stable NI 61. Two of the remaining stable isotopes NI 62 and NI 64 (4.5% combined) do become stable isotopes CU 63 and CU 65.
Unless they do an isotope refinement, only 4.5% of the nickel can possibly make this transmutation. I do not believe them.
Good Answers: 38
11/03/2011 5:58 PM
While I support your bold opinion, I would have to continue your reasoning... and come to a different conclusion (note I agree with your facts).
The unstable forms of copper you mention beta+ decay back down to stable forms of nickel (as you've said), but if those daughter isotopes continue on with the magical process these people claim, it will eventually become a stable form of copper.
11/03/2011 7:04 PM
No, on two counts.
First, the copper decays that I cited are electron captures and not beta + decays. There are subtle differences between these two decay processes but differences none the less.
Second, the short daughter isotope list I demonstrated are the only paths observed by the single proton transmutations I cited. You should notice that the far right column of the isotope decay list identifies that the sole decays have a 100% odd in the branching percentage because there's only one way out. The paths I cited stop at either a stable isotope or an isotope with a half life significantly greater than recorded human history.
Good Answers: 38
11/04/2011 10:24 AM
You're right on the decay modes. It is electron capture not beta+. Thanks for the correction. However, for the purposes of discussing the daughter nuclides, whether the process is B+ decay or electron capture doesn't make much difference... the daughter nuclide will end up with one less proton and one more neutron than the parent.
I think you missed my point, though. What is to stop their process from occurring on the daughter nuclides of the decayed particle?
For example we'll start with the first one you listed, Ni58. As you said Ni58 + p -> Cu59 (81.5s half-life) quickly decays to Ni59 (76,000yr HL). But you stop there. Why stop their magical cold fusion process from occurring with the new "stable" Ni59? ie, Ni59 + p -> Cu60 (23.7m HL) which will decay to Ni60 (stable).
I could list the whole chian here but to keep it short, if we continue on with this process we will eventually end up at a stable copper nuclide (Cu63).
11/04/2011 11:13 AM
So why should we stop at copper then. On an atomic time table the 81.5 second half life of CU59 is a long time to remain as a target for these magical tunneling(?) protons. This then leads to ZN60 with an even longer half life of 2.38 minutes to be a target of these nuclear bullets. Next comes GA61 with a brief half life of 0.15 seconds. I'll stop here.
My point is that if we choose to only consider the paths that agrees with these charlatan's boast then we are falling for their illusion.
I'm also highly skeptical of their power production boast. Are they really claiming that they produced 470kW of power and no body noticed. Where did this power go? If they dumped this power back into the power grid I'd expect some corroborating complaints from the local power producers that an unauthorized power was dumping onto the grid.
This type of bogus "research" with outrageous claims corrupts the scientific community as a whole.
11/04/2011 11:27 AM
Actually dumping 470 KWH worth of energy as heat is not hard at all and can easily go unnoticed by almost everyone in a commercial site.
Converting 470 KWH into BTU's gives around 1.6 million BTU's which is less than what a large 400+ Hp commercial truck or construction machines radiator systems dissipate at times.
To be honest my home built wood burning boiler system can easily pass 1.1 million BTU's imparted into the water jackets at peak burn during an extended warm up cycle with good dry wood and the fire box is only 2' square by just over 4' long!
11/04/2011 11:48 AM
Now you're grasping my point that these types of claims require a real outsider review and not just an internet magazine article that can only repeat the lies given to a reporter. If 470 KWH resided only as heat production and not the implied usable net output power then it can become difficult to isolate operations waste heat from actual heat production.
Good Answers: 38
11/04/2011 12:35 PM
I think we're coming to the same conclusion.
Thinking back, I seem to remember that nuclear reactions tend to move toward iron. I haven't taken the time to go through the calcs, but I would imagine that if one calculates the theoretical energy for it (Ni + H) and compares it to the energy released from the mass defect, one would find the reaction consumes more than it releases. I could be wrong, but that's my guess.
Good Answers: 299
11/04/2011 1:40 PM
This comment places redfred at 300 well deserved Good Answers. Congratulations.
CR4 members with 300 Good Answers or more:
Anonymous Hero at 401
Del the cat at 386
Tornado at 322
PWSlack at 315
redfred at 300
And number one, with a count of 429 Good Answer comments, lyn.
Exclusive company indeed. Congratulations to you all.
Note: This was not an exhaustive search on my part. There may be a member somewhere amongst the 52,983 that escaped my count. If so, please forgive the sleight, it is unintentional.
11/04/2011 1:50 PM
Aw gee, thanks. You shouldn't have...
I hope you gave Anonymous Hero an amusing, silly reward for his #400.
Good Answers: 299
11/04/2011 1:59 PM
I regret that I did not. I certainly would have, had I been by the switch. These are milestones in our memberships and should be acknowledged.
I have said this before, and this a heartfelt comment: Here at CR4 I walk in the shadows of giants. It is my privelege to associate with each and every one of the members, and it is a pleasure to interact with you all [disengage maudlin mode].
[edit] redfred, you got me to thinking (well done!): AH's #400 was in Chorete's thread about surviving a more or less instantaneous deceleration, 500 km/h to zero km/h, wrapped in some sort of a coccoon... I didn't watch the thread for very long, that's why I didn't catch his rather impressive milestone.
11/04/2011 2:50 PM
JRaef has 322, and an excellent percentage.
Good Answers: 299
11/04/2011 3:37 PM
Ooops. Good catch. I was bound to miss a few Sorry guys.
Agreed, an excellent percentage for JRaef: 322/2648≈12%
and tcmtech: 209/2028 ≈10%
and edweldon:197/1932 ≈10%
And James Dill: When I made this comment, he had a 100% Good Answer to Comment ratio! He has since dropped to 50%.
11/04/2011 4:43 PM
Msamad has about 25% GA's (~225 for ~900 posts).
Good Answers: 299
11/04/2011 5:59 PM
I've sort of taken the thread off the tracks... sorry guys. But I've already looked all this stuff up so I'm posting it anyway.
The blog titled Forums, Blogs and Community Sites has some interesting discussion about sites like CR4. One thing mentioned somewhere is the importance or value of member and guest participation and interaction on a site. This is sort of interesting:
WoodwardDL: 209 Comments/Member for 148 months ≈ 1.4 comments per month
BruceFlorida: 496/170 months ≈ 2.9 (I see Guruship in your near future!)
msamad: 897/140 months ≈ 6.4
ChaoticIntellect: 531/62 months ≈ 8.6
Milo: 4,396/271 months ≈ 16.2
tcmtech: 4,511/150 months ≈ 16.9
Anonymous Hero: 5,055/280 months ≈ 18.1
Doorman: 3,370/138 months ≈ 24.4
redfred: 4,511/150 months ≈ 30.1
Tornado: 9,323/139 months ≈ 67.1
lyn: 12,162/116 months ≈105
(I guess if you talk that much you are bound to get a bunch of GA's)
11/05/2011 10:43 AM
So what does 4,511/150 months mean ≈ 16.9?
Mainly referring to the "4,511/150 months" part.
The mathematical part of my brain does not work so well when I get out of bed.
11/05/2011 11:42 AM
I think it is total number of posts made by that member divided by the total number of months they have been a member of CR4, equals the average number of posts per month.
11/05/2011 2:26 PM
Okay then what math has he been using?
I only have 2035 posts as of this one and I have only been here since June 2nd of 2009 hence my curiosity as to what those numbers related to.
11/05/2011 2:40 PM
Those are redfred's numbers, which somehow got copied into the wrong line. I think the month counts are too high in all cases.
11/05/2011 4:39 PM
The post count number seems close enough to be him but his profile says December 2008.
How do you get 150 months from December 2008 to now?
(Okay my wife can but she is bad at math and very impatient about some things.)
Good Answers: 299
Doorman's Broken Figger Machine
11/06/2011 8:59 AM
Ooops!
All were intended to be weeks, as in 'Comments per Week". I see it is still incorrect. Perhaps best to disregard the whole comment as a misfire. At least the units weren't kg3!
11/04/2011 3:24 PM
Thanks. Could not have done it without you. ;-)
11/03/2011 6:21 PM
The way I see it is that if they are actually producing some 400+ KWH of heat for 5 and a half hours or more they either have developed one of the highest power to size batteries ever made or just maybe this thing does actually work.
More truthfully I too am waiting patiently for a considerably more solid scientific review of the process and design along with an explanation as to how it works based on what exactly they are using for the internal power source or fuel.
Good Answers: 145
11/03/2011 6:50 PM
If I invented workable cold fusion the only information I would share with others is how they can hook up to my grid and where they should send the check to at the END of the month. When a cold fusion inventor is only interested in these two things we should take him seriously.
Good Answers: 38
11/04/2011 10:27 AM
Good point! When they have it grid connected and want a check, I'll start to take them serious.
11/05/2011 1:47 AM
seriously
Get your grammar together man, or I'll have to sic Editor Crankshaft on you!
11/05/2011 2:29 AM
Agreed, but too busy undoing an angle trisector to get worked up much about grammar just now.
Good Answers: 38
11/07/2011 9:59 AM
Grammar was never my strength and I must admit that I don't see the error(s?) . I checked it with Word and GrammarCheck.net and came up with no errors. Also given grammar checks are notorious for only finding the glaring errors and Tornado confirmed your assessment of my error(s?), please feel free to pass along the knowledge of the language so that I won't stand out so much.
Good Answers: 299
11/07/2011 10:35 AM
I have something for you. From #12:
"...and want a check, I'll start to take them serious."
In the sentence, your word "serious" modifies or further describes how you will "take" them, the verb. Thus it is more correctly a comparative adverb: "seriously".
In the form "serious", the word is a comparative adjective.
Good Answers: 38
11/07/2011 10:40 AM
It seems so obvious now! Mikerho even gave me the superb hint that I obviously missed.
Thanks!!
Good Answers: 299
11/07/2011 10:47 AM
Shouldn't that be "... the superbly hint ..."
I for won are glad I am not gradeded on my speeling and gramur here at CR4.
11/03/2011 10:08 PM
I suspect delusion more than hoax, but it could be both.
One does not get genuine peer review by starting up one's own journal, as these guys have done.
I bet this eventually goes down in flames (or perhaps lack of flames, so to speak.)
[Moreover, peer review isn't always what it's cracked up to be. If a poor "scientist" is reviewed by peers, who would also be poor "scientists", the results are not likely to be promising....] A better concept would be "qualified critical review."
11/04/2011 12:20 AM
I believe that the E-CAT does generate more energy than has to be provided to keep it working. Cold Fusion (now called LENR) has been studied for 20 years since Fleishman and Ponds were driven out of the USA for daring to state that they had demonstrated cold fusion. In the USA alone, there have been 9,000 such experiments. At this point in time, 85 % of cold fusion experiments actually succeed in generating more energy than has to be supplied.
The US Navy is one of the major supporters of this technology, and is rumored to be the buyer of Rossi's 1 Mwatt plant which was accepted and paid for on 10/28/2011. It is also true that NASA has been discussing the E-CAT seriously with ROssi.
Even if the E-CAT fails, LENR will succeed eventually. The need for oil for heat and electrical power will go the way of the buggy whip eventually.
11/04/2011 8:05 AM
As long as "researchers" of cold fusion (or its euphemism LENER) continue to practice outside the realm of peer review science no one will be willing to give them any credibility - and for good cause!
This is just another example of pathological science, regardless of what the process really is.
When something is presented that can actually stand up to and pass the peer review process, the scientific world will take notice.
Until then, they do not deserve serious attention.
11/04/2011 5:06 PM
An equally controversial and allied subject is biological transmutation.
11/07/2011 11:46 AM
Thank you for that link. I found the subject of transmutation very interesting. The phenomena indicates to me that elements can "fuse" with out being exposed to the temperatures of the sun. The experiments lead us to (at least) believe that plants and animals have been harvesting this form of energy for a long time!
11/07/2011 12:13 PM
Really . You've bought into the occult particle ideas that Kervan proposed. This is precisely the type of phenomena that fits the description that extraordinary claims require extraordinary proof. In the case of the calcium deprived chickens that could now produce egg shells when potassium rich food was granted I ask if the birds were denied access to calcium rich stones for their gizzards. It just might be that these birds could not transfer the calcium from these stones/sand without the potassium in their diet.
Good Answers: 299
11/07/2011 1:50 PM
Selecting one item from the linked article about Biological Transmutations:
The article: O16 + O16 ® S32 explained as "Nature moves particles from one nucleus to another."
Doorman's recollection: 16O + 16O → 32S explained as "Requires a nuclear fusion reaction."
Doorman's observation: What organism requires the isotope 32S in such quantity that it will seek the isotope 16O and make the sulfur itself?
I remember hearing this quite a while ago. To refresh the old memory box I checked Wikipedia. Interesting article.
Reply to Blog Entry 40 comments
Anonymous Hero (4); Anonymous Poster (1); BruceFlorida (1); ChaoticIntellect (6); Doorman (9); Mikerho (1); redfred (6); tcmtech (5); Tornado (5); WoodwardDL (2)
