Previous in Blog: Frozen Pond: Newsletter Challenge (November 2011)   Next in Blog: The Rain and the Sea: Newsletter Challenge (January 2012)
20 comments
Earth’s Atmosphere: Newsletter Challenge (December 2011)
Posted December 01, 2011 10:46 AM
Earth's Atmosphere
Unlike other planets with atmosphere (e.g., Jupiter), the Earth's atmosphere does not have appreciable amounts of hydrogen or helium. Why is this?
And the answer is:
This happens only if the other planet is heavier than Earth. This is the case of Jupiter with a mass about 320 times greater than the Earth. A smaller planet than Jupiter, Earth has a weaker gravitational attraction for these lighter molecules. A molecule must possess an escape velocity greater than 1.1 x 104 m/s to escape the Earth's gravitational field. Because the average speed of helium or hydrogen is considerably higher than that of nitrogen or oxygen, more helium and hydrogen escape the Earth's atmosphere into outer space. Consequently only tracers of helium (0.000524%) and hydrogen (0.000055%) are present in our atmosphere.
Re: Earth’s Atmosphere: Newsletter Challenge (December 2011)
12/01/2011 11:01 AM
Gravity.
The surface gravity of the larger planets is able to hold the lighter gases.
Good Answers: 114
12/01/2011 5:08 PM
I didn't know that!
12/01/2011 3:14 PM
Doorman is correct. To elaborate on his answer, it has to do with the mean free path of the molecules of the light gases being equal to the scale height. It is known as Jeans Escape. In the upper atmosphere the gases will have a broad spectrum of velocities mostly depending on their temperature. The molecules with the highest speeds will actually be moving faster than the escape velocity at that altitude. Thus, over a long time, most of the light gases have leaked away from the Earth. They are replenished at a very low rate by atomic fission releasing helium and by dissociation of water producing hydrogen.
Good Answers: 70
12/02/2011 1:01 PM
This is probably a partial restatement of your answer, but another factor is that the earth is a metallic rocky planet, with a higher percentage of heavier elements. As a result we have a higher percentage of heavy gasses in our atmosphere than say Jupiter or Saturn, and the lighter gasses naturally float to the top of the atmosphere where they are somewhat more exposed to the solar wind, which is of course much stronger nearer to the sun than in the outer reaches of the solar system where the gas giants live. I'd guess that the hydrogen and helium concentrations on Venus are lower still, even though it's atmosphere weighs several times as much as ours. Poor Mercury has been pretty much stripped naked.
01/31/2012 10:08 AM
Correct me if I'm wrong, but isn't helium produced by atomic fusion and not fission?
02/06/2012 12:21 AM
One of the 3 primary fission products is alpha particles, i.e., helium nuclei. Once they grab a couple electrons to become electrically neutral they are then helium atoms.
12/01/2011 11:48 PM
Surface gravity is partly the reason. The pressure of an atmospheric gas decreases with altitude. Atmospheres are not uniform in temperature, so the exact determination of the atmospheric pressure at any particular altitude is complex. The distance from the sun determines the energy available to heat atmospheric gas to the point where its molecules' thermal motion exceed the planet's escape velocity. When this happens, the gas molecules overcome a planet's gravity, and escape into space. Distant and cold 'planets' like Pluto are able to hold their atmospheres in spite of low gravity because of low energy from the sun.
Reply Good Answer (Score 4)
Good Answers: 102
12/02/2011 1:47 AM
GA from me even though Pluto is not a planet anymore. Planetary title decay....
12/02/2011 9:40 AM
How is it that in parts of the southwest of north america, there are wells with vast amounts of high purity CO2 and, I am told, of reserves of Helium. How did these gases get 'trapped' or 'generated' and does this phenomenon exist in other parts of the earth? Anyone know?
deanpavil
01/03/2012 3:20 PM
Earth Helium is found in natural gas. It is the result of the decay of Uranium and Thorium. Earth has insufficient gravity to keep it in the atmosphere. US SW has most of the worlds He. Don't know why we have it and Canada with its gas reserves doesn't.
Good Answers: 102
12/02/2011 10:52 AM
There's not much hydrogen in the earth's atmosphere because of the presence of oxygen.
A lot of the Earth's hydrogen is in the water.
Not sure about the helium.
Location: European Bermuda Triangle (Germany,Luxembourg,France)
12/05/2011 10:26 AM
Hydrogen and Helium are light gases. The more massive the molecules of a gas are, the lower the average velocity of molecules of that gas at a given temperature and the lower is the chance that any of them reach the so called escape velocity. Escape velocity out of earths atmosphere is lower as from f.e. Jupiters atmosphere. Earths atmosphere is warm enough and the escape velocity of Hydrogene and Helium is high enough to leave our planet and to give me (and my Kois in the frozen pond) a chance to breave...
pinball-wizzard
Pinball-Wizzard
Good Answers: 7
12/05/2011 11:47 AM
What about Ar? We have almost 1%, how is it in other planets?
12/06/2011 3:51 AM
Ar is the 3. common inert gas on earth. It has the atomic number 18 and is a heavy gas. The Isotope 40Ar on earth is mostly build by potassium 40K. In gasplanets like Jupiter and in the sun we´ll find the isotope 36Ar and 38Ar but not 40Ar. Planets and moons with their origin atmosphere and without gelogical activities (the reason for by 40K composed 40Ar to leak from potassum) have an Ar which is build up of around 80% by 36Ar and 20% 38Ar. A representative for it is the Venus which has 300 times less 40Ar as the earth. At Saturns moon Titan we´ll find only 40Ar. This is an indication that in Titans primary origin was no atmosphere and the primary existing 36Ar and 38Ar was lost.
Pinball-Wizzard
12/06/2011 11:47 AM
The earths atmosphere is too dense with heavier elements, eg nitrogen, oxygen etc. for the two lightest elements to remain in suspension.
12/06/2011 3:00 PM
Also, it's warmer on earth. Even at the coldest points on/in our planet and in our atmosphere, the light gasses are fully gasses. On the colder outer planets, there is probably equilibrium between liquid and vapor of those gasses, especially deep in the atmosphere where the pressure would be high. I can envision something like the water cycle on earth, with the light gasses or hydrocarbons on other planets.
12/07/2011 1:17 AM
the earth's gravitation is not hard enough to hold the light elements hydrogen and helium in its gravitational area is one reason (v>11210m/s). Is there ever been enough pure hydrogen or helium in the earth's matter to leave appreciable amounts of it in the earths atmosphere or did the jupiter (or maybe the sun) in their creation state fetch all the hydrogen and existing helium into their gravitational field?
12/10/2011 1:45 PM
It's all been used up in balloons and dirigibles...and for people to talk like chipmunk
12/13/2011 3:18 PM
Simpley the Earth does not have enough gravitational pull to hold all of the Hydrogen and Helium. They are lighter then air and escape the atmosphere.
12/20/2011 10:40 PM
The combination of the high volatility of the element and the scarcity (only naturally produced by the decay of thorium and uranium) may contribute to the low amount of helium in Earth's atmosphere.
deanpavil (1); Doorman (1); ebolton (1); JerryD2010 (1); johnfotl (1); johnny camaro (1); JWthetech (1); passingtongreen (1); pinball-wizzard (2); schaefer.don (1); Snel (1); SolarEagle (1); StandardsGuy (1); Usbport (2); Wal (2); WilhelmHKoen (1); willjack (1)
