Previous in Blog: Set the Tone (July 2012)   Next in Blog: Sweet Preservative: Newsletter Challenge (September 2012)
Impossible Heights: Newsletter Challenge (August 2012)
Posted July 31, 2012 12:00 AM
This month's Challenge Question: Specs & Techs from GlobalSpec:"
Between 10 and 15 atm of pressure would be required to transport water to the top leaves of California's redwoods, which can reach heights of 120 meters. How could the water be transported upward such a distance?
And the answer is:
When two solutions are separated by a membrane, the solvent in the more dilute solution moves to the more concentrated solution. This process is well known and it is called osmosis. The movement of solvents produce pressure in the more concentrated solution. Eventually the process reaches equilibrium. The pressure at equilibrium (this is the pressure that stops the osmosis) is called osmotic pressure. Now, let's see how water can be transported up the tree. The leaves in trees continuously lose water to the air by a process called transpiration. By losing water the leaf fluid inside becomes more concentrated. Then the water (less concentrated) surrounding the leaves (from the trunk, the branches and the stems of the tree) moves inside by osmosis. Water is pushed up by osmotic pressure. It is not possible to move water up a big distance by a process called capillarity, because capillarity is very low pressure process.
Good Answers: 92
#96
In reply to #95
Find in discussion
Re: Impossible Heights: Newsletter Challenge (August 2012)
08/29/2012 11:24 AM
AHH... what thread are you on?????
#101
08/30/2012 3:14 AM
In reply to #90: The lift cannot be due merely to the physical prescence of capillary tubes or osmotic membranes, as dead trees do not lift water any substantial amount. Some life process must be involved.
...Wolfus
In reply to #101
08/30/2012 4:53 AM
Logical thinking, but misses a significant raft of possibilities and actualities: that the sieve of the osmotic membrane may only maintain its pore dimensions while the tree is alive, that the continuous path through the capillaries fails after the tree dies*, that the shape and dimensions of the capillaries changes when the tree dries^, that only the living sap in the trees is wet enough for capillary action to take place^; I've probably omitted a bundle...
* There is indirect evidence for this: some species dry out more rapidly in areas where there is more mineral uptake.
^ There is direct evidence for both of these: the physical structure of mature wood is different from that of sap, and sap is wet, whereas mature wood needs to be reasonably dry to avoid rotting.
09/04/2012 9:33 AM
Huh?
We all know the debate about whether a tree falling in the forest really makes a sound if nobody hears it, but that its very height is attributable to psychoacoustics? How come I never thought of that?
"And the answer is:
When a sound signal is received by a linear system (linear response) only the fundamental tones (the ones actually present in the sound) is sensed or transmitted. However, if the system exhibits non-linear responses, not only the fundamental tones are sensed and transmitted, but also the system reproduces the harmonics of each one of the tones present in the sound. This means that the non-linear system reproduces the sums and differences of the whole number multiples of the fundamental frequencies. It happens that the system formed by the ear and brain is actually a non-linear system, so we hear a low fundamental tone (like in human speech) and all the harmonics produced by the system, including the large wavelength of the bass tones."
Reply Off Topic (Score 6)
#105
In reply to #104
09/04/2012 11:05 AM
Oops! It looks like the answer to last month's question was posted by mistake. The correct answer is now available for August's challenge question. Sorry for the confusion.
In reply to #105
09/04/2012 11:11 AM
"The correct answer is now available for August's challenge question."
Where?
#108
In reply to #107
09/04/2012 11:12 AM
In reply to #108
09/04/2012 1:02 PM
That is certainly a decent explanation, and the mechanism I tend to believe is dominant.
However, if CR4 challenges are about anything, they are about developing a proper understanding. On this basis the explanation needs fleshing out, as there are apparent difficulties. The principal one relates to the way trees seep when injured. The difficulty is that there don't appear to be any membranes between the roots and the leaves - which implies that the osmosis would be supporting a continuous 100m column. This leaves (qv) us with a problem: how come that trees all leak slowly when punctured, and the rate is apparently independent of the height at which we make the hole? (We might expect the contribution from below to depend strongly on the position).
The other problem relates to the explanation that you reject: even though the tubes in the tree are too large to support capillary action, this does not in fact mean that capillary action cannot be responsible. For example, 20-nm wide slits would readily pull the water up the requisite distance, and there is no reason the meniscus could not vary in radius so that you have a different (and supportable) equilibrium at each height. The apparent issue with capillary action is that we would not expect the tree to leak at all. On the other hand, there could always be evaporation/condensation into a separate circulatory system that ran continuously from top to bottom of the tree.
So please - more meat to the explanation.
Thanks
1010T
Reply Off Topic (Score 4)
#110
In reply to #109
09/04/2012 1:12 PM
I'll contact the creator of the question and ask him to get back to you.
Good Answers: 26
#111
In reply to #109
09/04/2012 5:07 PM
AP#1 "The difficulty is that there don't appear to be any membranes between the roots and the leaves"
It is the cell's membrane. It's okay, I can't see them either.
In reply to #111
09/04/2012 5:26 PM
For me this still needs further fleshing out.
One of the comments made about capillary action was how viscosity would limit the flow rate. This would appear to be an even more stringent limitation if (as this requires) all the flow is through the interior of the cells - and especially with a molecular membrane at each cell wall.
So, how large (smaller lateral and vertical dimensions) are these cells? What is the flow rate through them?
Thanks
1010T
Good Answers: 26
#113
In reply to #112
09/04/2012 6:04 PM
Cell membrane permeability is a very effective and selective transport mechanism.
In reply to #113
09/05/2012 4:34 AM
Sure, but that doesn't negate viscosity effects. Without dimensions it is impossible to see if the numbers (osmotic pressure driving against viscosity) stack up - and the trivial expectation would be that - for this simplified model of pure cell-to-cell osmotic transfer - they won't.
In reply to #105
09/08/2012 6:48 AM
Ha !
It's continuing a grand tradition - the occasional 'are we awake, boys and girls ?' (intended or not) is hootingly funny. There have been a few bloops that lay dormant for weeks. Many a Challenge question has never had universal agreement (the 'bouncing balls' question still gives me nightmares - detailed explanation from Phys and I still don't get it . There would be no fun if I did).
In reply to #104
09/04/2012 11:06 AM
Is this an answer to some other thread?
If not, please explain how this relates to water transport up a tree...
alanidris (1); Anonymous Poster (28); Barchetta (2); Bazzer Englander (2); billbigrig (1); blackwing (1); Bob Wersen (1); cwarner7_11 (1); DaveUggla (1); devaxprem (1); dkwarner (14); Ethanolics Unanimous (1); ExPat (1); fsj (1); glynnc (1); HeadsUp (1); Hendrik (1); Jacob Klepatch (3); jfcayron (1); jimtarver (1); JNB (4); Jorrie (1); Kris (4); leveles (1); Mr Gee (1); ozzb (1); passingtongreen (1); Physicist? (1); pinball-wizzard (1); pnaban (2); reward54 (1); ronclarke (2); Roy Wagner (3); Sanjayvt (1); SavvyExacta (3); SolarEagle (2); Stuart21 (3); Ti QE (1); Usbport (2); Wal (6); WilhelmHKoen (7); Wolfus (1); yesyen (2)
