How to Select Industrial Products Blog
This is the place for engineers to learn about and teach others how to select industrial products. The blog is maintained by the Editorial team at IEEE GlobalSpec, the company that powers CR4.
Previous in Blog: A Perfect Vacuum... Pump   Next in Blog: How to Select Electric Brakes
4 comments
Selecting a Heat Exchanger
Posted August 27, 2012 12:00 AM by cheme_wordsmithy
User-tagged by 2 users
The heat exchanger is one of the most fundamental pieces of equipment used in thermal systems. At the same time, though, it's also one of the most widespread and varied, taking on many forms depending on the application or system it's used for.
At its core, a heat exchanger is simply a device that allows for the transfer of heat from one medium to another. In many cases, the two mediums are two different liquids, although gases are sometimes utilized as well. Basic heat exchanger applications include controlling temperature, capturing waste heat from a process, and producing steam to run a turbine.
Classifying heat exchangers can be a daunting task when considering all their characteristics. For instance, they can be distinguished based on the number of fluids used, their flow arrangements, or the heat transfer mechanism. But luckily, these details are often more important for the designer or manufacturer to focus on. For you (the engineer looking to source a heat exchanger), the first step to consider is the type, or how it is constructed.
Types
There are three basic types of heat exchangers: shell & tube, plated, and air-cooled.
The aptly named shell & tube heat exchanger (pictured right) uses (you guessed it) tubes encased in a shell. One fluid enters through the tubes and another flows around them in the shell, with heat transfer taking place through the tube wall. Flow and performance will vary based on the design of the shell and the arrangement of the tubes and baffles inside of it. Shell and tube exchangers are the most standard heat exchanger design, favored for their familiarity, versatility, wide operating ranges, and rugged construction. Unfortunately these designs are typically the most thermally efficient and in some cases are subject to a variety of flow problems such as vibration and mal-distribution.
Next up we have plated heat exchangers, which use plates (see the trend, yet?) instead of tubes as the heat transfer boundary. Typically the two fluids are directed by baffles to flow on alternating sides of a number of plates (as pictured left), usually contained in a casing. Performance varies based on the type of plate design and how the plates are connected (welded, semi-welded, gasketed). The corrugation and larger surface areas of plates make them more thermally efficient than tubes, and the overall design lends itself better to temperature cross conditions. However, plated heat exchangers can be difficult to seal reliably, often limiting them to lower capacity operations. They also have a narrower range of operating conditions (temperatures and pressures).
Lastly, air-cooled heat exchangers (pictured right) reject heat directly by (surprise surprise) air flow. Instead of pumping water or another liquid, these devices are designed specifically to use fans to push air over the heat transfer surface (tube bundles or plates) to remove heat. Induced draft designs, which pull air through the equipment, are more thermally efficient but have higher power consumption than forced draft designs which instead push the air. In cooling systems where water is in short supply or is too costly, these types of exchangers are a lower-cost alternative. They are easy to operate and maintain, and are well suited for high temperature process streams.
Performance
If only it were enough to throw all heat exchangers into three broad categories and be done with it. Unfortunately, it's not quite that simple. Heat exchanger designs and applications vary widely in scope, and a complete classification would be exhaustive, if not nearly impossible, and not much fun to read.
In the end, what should be most important to you is that the exchanger fits the needs of the system and gets the job done right. The primary performance factor is heat transfer rate (heat load), which defines how much heat energy the unit can transfer over time. Other key system specifications are designated for each fluid; they include flow rate, allowable pressure drop, and the design temperature and pressure. When consulting a manufacturer, these are the specifications required for proper custom heat exchanger design.
And So Much More…
Other things you might want to consider for your heat exchanger include materials of construction, proper connections and fittings, standards, and much more. But if you haven't heard enough about heat exchangers yet, check out GlobalSpec's How to Select Heat Exchangers page, where you can get a more detailed look at what heat exchanger selection is all about. And while you're at it, share a comment here about your own endeavors with these essential pieces of equipment.
Image Sources
EngineeringSpec.com
Diversified Heat Transfer
Heat Exchanger Manufacturers
Re: Selecting a Heat Exchanger
08/28/2012 7:59 AM
I had a thread recently about this very subject Heat Exchanger Problem, where the problem was a temperature cross over. Actually it wasn't really a problem, just a poor decision
Having designed Shell and tube heat exchangers, and wrote sizing programs, I believe there is a misunderstanding of thermal efficiencies.
I think the understanding what is that each HX thermal efficiencies is interchangeable where in fact are diffidently not.
One of the efficiencies about the plate over a shell and tube is that with thinner plate material, over tube, there is less thermal resistance, but they can't handle high Viscous material.
And something of a shell and tube is the Double Tube and less used Triple tube heat exchangers.
Good generalized thread and direction about HX.
Good Answers: 114
09/01/2012 9:50 AM
The early part of my working life was on oil refinery design so I came across most variations of heat exchangers, but the most interesting showed up when I started designing structures for power plants. I refer to the rotating tube type that, in rotating, alternates between carrying hot flue gas and cold combustion air, taking heat from the flue gas into the tubes and then giving it to the combustion air.
Unfortunately, when we retrofitted older plants with SO2 and particulate removal systems and taller chimneys, we had to re-heat the flue gas with steam supplied heat using another heat exchanger.
This is OT, but I think I enjoyed the problems of the retrofits more than anything except for the early learning part of my career; that part was exciting and enjoyable.
Some oil refinery structures supported only heat exchanges, on several levels and piped up so they worked in series. These were tube bundle type, we had hoist beams and pull beams so the bundles could be pulled and taken to the shop.
09/01/2012 11:19 AM
Dairy industry we called that regeneration, I believe the correct term is reclaim, where we take the exhaust or return to preheat the incoming product.
Good Answers: 114
09/01/2012 1:51 PM
I remembered that they were labelled as "Air Preheaters" so I looked at Wiki. These are the "Rotating plate" type. As described to me, they had tubes instead of plates, but that looks to be wrong.
