Building & Design Blog Blog
The Building & Design Blog is the place for conversation and discussion about building projects, tools and equipment, materials and hardware, and environment & energy. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Which Toilet Deserves Your Business?   Next in Blog: Sky City One: China's Prefab, Record-Setting Skyscraper
8 comments
Elevators--Perception Going Up
Posted December 05, 2012 6:56 AM by HUSH
Elevators have an unusual relationship with the macabre.
Really, stick with me here. Some of people's most irrational fears are exploited by an elevator: heights, enclosed spaces; decapitation; a terrifying free fall (see The Tower of Terror).
There's more. Have you ever seen The Shining? (Yes, of course you have.) Little Danny Torrance envisions elevators unleashing waves of blood to recolor the walls of a haunted hotel. In similar bloody remembrance, let's not forget The Departed's brutal homicides (graphic) . Heck, they made an entire B movie about a killer elevator.
In real life, many structures skip numbering the 13th floor or designating a 13th floor button in elevators.
I don't know about you, but elevators can be an inconvenience for me-at most. Ugh, I have to make boring small talk/listen to terrible elevator music. Elevators are an essential part of building design however and the likelihood of an elevator malfunction is rather low. Despite their customized prevalence throughout the world, and the idiosyncratic nature of their name (yes, Britons we know it's called a lift), elevator designs vary minimally and are cursed for their perceived shortcomings.
Remarkably, Italy has over 900,000 elevators installed within its buildings, meaning there is one elevator for every 67 of its citizens. By comparison, the USA has the second most, but with one elevator for every 445 of its people. It makes some sense that Italy has the most, if only because Roman scientist Vitruvius was reputed to have invented a vertical ascension mechanism in 236 B.C. Elevators appeared in variation through the rest of history until the early 19th century when hydraulic systems began appearing in Britain and the United States. Though modernized with better safety protocols, smaller parts, and worldwide popularity, elevators designs have remained largely unchanged since the traction design was invented shortly thereafter.
Elevators are essentially limited to four types:
  • traction hoists employ high strength cables, a counter weight, and an electric motor
  • hydraulic pistons and their associated pumps push hydraulic elevators skyward
  • a hybrid traction-hydraulic elevators has an attached counterweight, but still relies on the linear power of hydraulics
  • climbing elevators are self-powered and are reserved for towers, masts, and other exceptional structures
Structures with just a handful of stories are best served by traction-hydraulic elevators, while skyscrapers and other tall buildings tend to use traction designs.
Depending upon the traffic pattern and the demographic the elevator serves, some very intuitive functions are built into the devices. In halls where multiple elevators serve riders (also called an elevator bank), cars are concentrated at lower levels in the morning, and at higher levels in the afternoon to better accommodate the flow of traffic. In Jewish communities, elevators on the Sabbath may run automatically-opening at every floor, to accommodate those who observe electrical prohibition on that day. Emergency patterns are common in nearly every lift and allow firefighters, police, and medical personnel to select the elevator's actions.
Many peculiar structures incorporate specialty elevator designs. Notably, in skyscrapers extending dozens of stories, a skylobby will be built. Here high speed elevators directly take passengers to an intermediate floor providing riders with access to a new elevator bank. Another interesting case is the Gateway Arch in St. Louis that uses a tramway with enclosed, self-leveling cars to account for the structure's unique shape, and the elevators that serve the Eiffle Tower's concave legs function similarly.
Finally, those who perceive elevators as unsafe or dangerous need to have a look at the safety record of elevators. In 1852, Elisha Otis debuted the safety elevator which would not fall if the traction cable broke. Brake pads grasp the vertical running rails, slowing the elevator if it descends faster than which it was intended. In fact, until the 9/11 attacks, the only record of a traction elevator in absolute free fall was in 1945 when a plane struck the Empire State Building, severing the cables. Hydraulic elevators are much more likely to fail, but mostly because older designs excluded a failsafe and relied upon a single cylinder to support the elevator.
So it's 5:30 p.m. on Friday. You just packed your desk and are so ready to end your workweek. You arrive at the elevator bank and hit the call button so you can take your ride from the 67th floor to the lobby and get on your way home. Ugh, of course the elevator is going up. All the elevators are going up! Clearly there is a conspiracy to keep me here as long as possible!
A more common complaint is a bias against riders travelling downwards from high floors after work. Riders in high floors will complain that elevators servicing their floor will most often be travelling up, while riders in lower floors will receive the benefit of elevators already on their way down. The truth is that it's only the perception that some floors receive better service.
If someone were to observe an elevator's ascending and descending pattern for a long period of time, they would count an equal number of passes in each direction. However, it's more common for riders to approach elevators at need and be subjected to waiting. Assuming the elevator distributes its passengers evenly, the elevator will be more likely to be coming from the bottom of the building for riders on high floors simply because the elevator spends more time where there are more floors. The same is true for riders on low floors, who can expect to travel downwards on an elevators first pass, just because they are unlikely to encounter the elevator in the slim interval where it is below their floor and then ascends. It's called the elevator paradox. Make sense? Perhaps the graph on the above right helps.
So, not only have we debunked the ideas that elevators are unsafe, we've also eliminated the supposed rider bias the snobby executives often complain about.
What can I say? HUSH looks out for the little guys when it comes to elevators.
Resources
(Images credits: Wikipedia; Pseudo Paranormal; Time Marches On; P. Seale; Elevator Bob's; Unsuck DC Metro)
Wikipedia - Elevator; Elevator Paradox
Re: Elevators--Perception Going Up
12/05/2012 7:34 AM
I occasiionally get weird lift (elevator) dreams, where there is no door on the lift or it's a completely open platform and it carries on out the top of the building. Sort of scary, but I recognise its a dream and sort of enjoy 'em.
I'm sure I've seen lifts in some public building (university?) somewhere which just keep going in a sort ov loop (dunno how they change direction at the top or go up and over) They have no doors, looked rather fightening... but you just have to step off and on at the right time.
Or maybe they were just for cargo?
Maybe that's what inspired the weird dreams?
12/05/2012 8:44 AM
12/05/2012 11:27 AM
Stop it, that's scary.
I gotta go hide in my secretest most cat nest now and hold very very tight to the floor.
Daren't go to sleep though
Good Answers: 38
12/05/2012 7:44 PM
This article made me think of that LG flat screen prank
http://www.youtube.com/watch?feature=player_embedded&v=NeXMxuNNlE8
12/06/2012 4:02 AM
Whaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa!
12/07/2012 2:58 PM
In all my 78 years, I have never heard of an elevator falling. Do they fall free, or is the safety device so effective that it is never reported?
Mr.Ron from South Ms.
12/07/2012 3:42 PM
Elevator failures are extremely rare, but they are spectacular failures when they do occur.
This site lists their pick of top ten elevator tragedy stories.
12/08/2012 11:27 AM
I read the list of tragic elevator accidents, but aside from free falling elevators over 100 years ago, there have not been any free falls due to elevator malfunction. Planes crashing into buildings and cutting cables; yes, but malfunctions due to elevator design and safety standards; no. It appears to me that the elevator is truly the safest mode of transportation ever devised. My only concern was free fall; not malfunctioning doors or lack of telephones.
Doorman (1); Epke (1); PWSlack (1); ronseto (2); user-deleted-1105 (3)
