Previous in Blog: Inspiration Mars Ship Using Human Waste as a Radiation Shield   Next in Blog: Brown University Creates First Wireless, Implanted Brain-Computer Interface
9 comments
Project Skyflash: Is It Possible to Build a DIY Jet Pack?
Posted March 04, 2013 11:04 AM
From ExtremeTech:
Tired of waiting for others to build his dream machine for him, German engineer Fritz Unger has constructed and tested a prototype jet-powered wingsuit. Other pioneers, like Yves "Jetman" Rossy, have long held media attention for their liberating solo flights, but they have no immediate plans to attempt take-off or landing from level ground. In fact the Jetman seems to be taking his designs in the opposite direction - instead of longer, more buoyant wings, friendlier for parachute-free landings, his latest craft use stubbier wings for greater stability at higher airspeeds. If powered wingsuits are ever going to get into the air for sustained flight, what kinds of design might they have?
Unger's contraption, called Project Skyflash, has wings 11 feet (3.4m) wide and weighs just under 300 pounds (136kg) with pilot included. It uses two diesel-fueled microturbines made by Jetcraft, which together deliver around 80lbs of thrust. Microturbines may have a simple design with only a few moving parts, but to actually get one running properly a fair amount of support equipment is needed. To keep it running, and squeeze everything you can out of it, you also want to monitor several system variables like RPM, exhaust gas temperature, inlet airspeed, and fuel flow rate and use. Unger has told us he has already made small hops and is planning to achieve a first flight later this summer after some upgrades are made.
While the initial video footage may not be all that impressive yet, I think we need to give him some credit, and more importantly, some encouragement. This guy, working with just wood and shrink wrap is not jumping out of an already airborne plane, or base jumping from 1000 feet, but rather is starting from the ground up, taking the approach I think we need at this time - small, light, simple,and cheap.
Read the whole article and watch the video
Re: Project Skyflash: Is It Possible to Build a DIY Jet Pack?
03/04/2013 11:17 AM
"... but rather is starting from the ground up, taking the approach I think we need at this time - small, light, simple,and cheap."
I am very sorry, but the thought of an average citizen of the world having this sort of thing available is frightening.
Fewer injuries would result from the free distribution of adult tigers as house pets.
03/04/2013 2:53 PM
No, lets not be too quick on that judgement, I would have to say that depends........ it may be a good thing when the laws of natural evolution come to play.
An example, ever learn how to operate an RC airplane? The first flight is usually quick and quite devastating.
03/05/2013 4:54 AM
Sadly, there aren't enough tigers left to do this.
03/05/2013 5:44 AM
Adult tiger? Where do I sign up?
03/04/2013 12:28 PM
I have thought about designing a similar aircraft for years. Unfortunately I am a larger built person so for me I had to do my calculations to fit around a 6'3" 260# person.
From that my rough estimate suggested I would need around 16 - 18+ feet of wing span plus a tail rudder and rear wing stabilization which I would control with my feet once strapped in.
My thoughts were more towards a fully enclosed mini airplane design where I lay inside of it rather than just strap it on. Still the base design suggested it would be around 8 feet long and push 500+ pounds base weight with me in it.
For power I had considered a dual ducted fan system driven by good old fashioned screaming 2 stroke engine power derived from a pair of stripped down 175 - 250 CC motor cycle engines or similar.
Just a rough draft concept though.
03/04/2013 1:51 PM
Sounds like a great Youtube video in the making.....You should have a snazzy uniform too....
03/04/2013 2:19 PM
Unfortunately I am married and I barely get to play with anything she feels is dangerous any more.
(Well at least not until I have a $2 million life insurance policy on myself any way. Then I can go nuts.)
03/04/2013 4:08 PM
Sounds like you 'both' have your priorities determined....
03/05/2013 8:02 PM
looks like fun in the fast lane is about to take on a whole new meaning...Are the local constabulary ready :
Doorman (1); martywolf (1); phoenix911 (1); PWSlack (1); SolarEagle (2); tcmtech (2); user-deleted-1105 (1)
