Do you like warm beer? Drinkers in the U.K. and Germany may prefer
their beer at cellar temperature, but Europeans don't want a beer that's warm
like Kaffee or afternoon tea. Here in
Canada, Molson sells a brand called Cold Shots. In the U.S., Coors prides
itself on two-stage cold activation. Cold beer is what North American drinkers
want, even during hockey games.
Hockey,
Blood, and Beer
Keeping beer cold is important. Keeping blood cold is a necessity. Like the
beer coolers found in liquor stores, convenience stores, supermarkets, and at
NHL hockey rinks, blood bank refrigerators must keep liquids at the proper storage
temperature. The refrigerators and freezers used in hospitals, laboratories,
restaurants, and industrial kitchens also provide essential cooling.
Keeping
Contents Cold
Faulty or leaky door seals make it harder for refrigerators
and freezers to keep contents cold. Motors work overtime, running continuously
and increasing energy usage and wear. Increased costs (and warm beer) aren't the only problems with choosing the
wrong refrigerator and freezer door seals, however. Using the wrong hinge and
latch system can cause doors to buckle, air to escape, and items to spoil.
Seal
Design and Dimensions
Selecting the right door seals for refrigerators and freezers is an important task then.
That's why buyers and designers consider inner diameter (ID), outer diameter
(OD), cross-section, and gap. The first three dimensional specifications are
well-understood by engineers, but it's worth noting that the gap refers to when
a refrigerator door or freezer door is closed - not open.
Seal
Materials and Thermal Insulation
In addition to dimensional specifications and hinge type,
seal designers and technical buyers need to choose the right material compound. For industrial refrigerators and freezers, EPDM and
neoprene are common choices. Used in cold room doors, EPDM rubber provides good
thermal insulation. Neoprene rubber also offers excellent insulation against
cold and prevents unwanted heat transfers.
Hospitals
and Kitchens
In hospitals and kitchens, refrigerators and freezers must do
more than keep items cold. Often, silicone door seals are used because they're
inert, odorless, hygienic, long-lasting, and relatively easy-to-clean. Anti-bacterial
thermoplastic elastomers (TPE) are also a good choice for refrigerator
and freezer door seals. Flexible and pliable (but more expensive), TPE is also
less likely to break at colder temperatures.
Cheers!
Whether you like your beer ice cold or at cellar temperature,
I hope you've learned something by reading this CR4 blog entry. Do you have
questions about seal design or customer fabrication? How about service
temperatures and material selection? Please let me know by commenting below.
About the Author
Clyde
Sharpe is the President
of International Sales at Elasto Proxy (Boisbriand, Quebec, Canada), which provides high-quality,
low-volume, custom-fabricated sealing solutions to a variety of industries.
