The Engineer's Notebook Blog
Previous in Blog: The Most Interesting Scientific Breakthroughs of 2013   Next in Blog: Gifts for Engineers
13 comments
Two Sleeping: Healthy Alternative or Productivity Killer?
Posted December 10, 2013 2:43 PM by Hannes
Pathfinder Tags: sleep research two sleeping
Recently, I had a conversation with a friend about a sleep pattern of his that he felt was abnormal. Starting in about November, when the days shorten drastically and darkness sets in at around 5 pm, he would go to bed exhausted right after dinner, wake up and futz around for a few hours around 1 in the morning, then return to bed until he had to get up for work. He maintained that he didn't feel a whole lot more rested than simply sleeping for eight continuous hours, but it worked for him when darkness was plentiful.
Turns out that, historically, this pattern is less than unusual and was actually the norm for centuries. "Two sleeping," as it's commonly known, was first profiled by US historian Roger Ekirch and more recently by the BBC, a couple blogs, and a book by Craig Koslofsky. Ekirch, in particular, was the first to compile loads of evidence from medical materials, diaries, and artwork that points to the common practice of sleeping for two four- or five-hour blocks each night.
Two sleeping was common for several reasons. During the Medieval period, nighttime activity was dominated by shady characters; if you were roaming the streets after dark, chances are you were a prostitute, criminal, or other reprobate who preferred to work in darkness. Upper classes could burn candles in order to work or read after dusk, but this was seen as a colossal waste of money. The period between sleeps was used for relaxing activities such as reading, praying, and quiet socializing. (Contrary to this, though, several contemporary doctors' manuals recommended this as the peak time for "good" sexual activity and optimized conception.)
According to researchers, two sleeping began to decline after the Reformation, when both Catholics and Protestants began staying up later for secret, persecution-free services. By the time the Industrial Revolution came around, improvements in indoor lighting and a new focus on efficiency and productivity began to reverse attitudes on two sleeping. By the early 19th-century, most people had taken to sleeping in a single eight-hour block.
Two sleeping still has its adherents, though, including some scientists and researchers. These folks - including Ekirch himself - purport that forcing ourselves to sleep in a single block has negative effects on our psychological and physical health. Psychologist Gregg Jacobs believes that forcing ourselves to relax and meditate between two periods of sleep had enormous positive ramifications on health, a point which is difficult to disagree with. Jacobs and other researchers point to problems with natural sleep as a possible cause for the astounding uptick in cases of anxiety, depression, stress, and drug abuse in the modern world.
Most people panic when they awaken suddenly in the middle of the night, but next time it happens to you, consider that it may just be your body attempting to return to two sleeping. Heck, if you're intrepid enough, get up and read or meditate for a few hours and see how you feel the next day. Just be prepared to go to bed at 7 the following night…
Image credit: Bookjam Blog
Re: Two Sleeping: Healthy Alternative or Productivity Killer?
12/11/2013 7:26 AM
I think that as long as someone is able to complete the REM cycle, it shouldn't matter if they sleep in one continuous sleep, two, or five.
12/11/2013 7:48 AM
Interesting! I have done this in the past. It usually happens when I have a lot on my mind or a lot of things to do. It doesn't tend to be as effective for me as a full night's sleep. I usually sleep 8-10 hours.
12/11/2013 8:13 AM
I need 8 solid hours now, or I don't feel right.
Both, back when I worked night shift, and in my Navy days, with crazy hours and rotating shifts, I was fine with several short sleeps.
I'd rather not, but I could probably get my brain programmed to go back to it. Right now I'm still attempting to adjust to the time change. I'm out at around 8:30 PM, and up around 4 AM, which is not ideal.
My neighbor spent a good part of his life sleeping for 8 hours a night, but getting the equivalent of zero sleep, due to sleep apnea. His REM cycle was constantly being interrupted and he had no idea what was wrong with him.
I like my 8, but it's the cycles that are important.
http://www.lifehack.org/articles/lifehack/90-minutes-sleep-cycle.html
12/11/2013 8:33 AM
Wow, I envy both of you - I'm lucky to get 7. Not sure whether to blame the fact that I have young kids or that I'm just a poor sleeper in general. Maybe both.
12/11/2013 8:52 AM
The older I get, the more sleep is my friend.
I spent years running on 3-4 hours a day. No more.
12/11/2013 6:18 PM
Occasionally I wake up and don't quickly reenter sleep, so I read or blog. In the long run, it works out just as well for me as eight straight hours.
12/11/2013 8:36 PM
I function better on continuous sleep regardless of the quantity.
Like SE, if I've got deadlines, or unfinished work, I don't sleep well.
12/15/2013 4:37 PM
Or if something is bothering you?
Good Answers: 67
05/16/2014 12:20 AM
"I function better on continuous sleep regardless of the quantity. Like SE, if I've got deadlines, or unfinished work, I don't sleep well."
"Doc! Ya gotta help me! I sleep well enough at night, and mornings aren't bad, but I toss and turn all afternoon!"
12/11/2013 11:12 PM
I do the two sleep thing fairly often as well. I rather like it. I get up for a hour or two and go online or read then go back to sleep.
It works for me!
Good Answers: 102
12/12/2013 4:13 AM
I think I'll try it.
A bit of loud music, hammering, grinding and concrete drilling at 1AM will make me popular in the village too.
Sounds good.
12/12/2013 7:27 AM
I do have to admit that when the night weather is nice going out to the shop in the middle of the night and working is rather nice.
I get to see some rather interesting insects the shop lights draw in too! Granted getting hit by a moth the size of a mans hand while welding is a bit unnerving though!
Good Answers: 102
12/15/2013 5:06 AM
A luxury I can't indulge in the urban/inner city area where i live.
During the day you can make as much noise as you want except lunch time.
Anonymous Poster (1); europium mkII (1); Hannes (1); kramarat (3); lyn (1); SavvyExacta (1); tcmtech (2); Tornado (1); Wal (2)
