Workbench Creations Blog
Workbench Creations
Previous in Blog: Whistling Walnut!   Next in Blog: Slo' Mo' Hat Cam
12 comments
To an Engineer Anything Can Be Building Materials
Posted January 06, 2014 3:15 PM by frankd20
Pathfinder Tags: igloo snow building
A fun few-hour project done on a whim, I will let the pictures speak for themselves.
Re: To an Engineer Anything can be Building Materials
01/06/2014 10:43 PM
There's an app for this; i-glue.
ξ
Anonymous Poster #2
01/07/2014 2:31 AM
I-glue; you-glue, we all glue!!
1
Good Answers: 146
01/07/2014 6:04 PM
i-glue, = hydrogen dioxide.
The last batch of snow I shovelled broke up into brick shapes spontaneously.... I must admit, I was tempted.....
aw, shovelit.
Nice igloo, Frank.
incus opella
07/29/2016 3:43 PM
"i-glue, = hydrogen dioxide."
HO2 is a very unstable compound, I think you meant Dihyrogen Monoxide.
Good Answers: 146
07/29/2016 6:20 PM
Whoops! Chemical dyslexia.
Thank god this never happens to mother nature.
incus opella
08/01/2016 9:28 AM
Things like that DO happen in nature, we call it 'random fluxuation' when dealing with inorganics, and 'mutation' when dealing with DNA/RNA.
Nature even tries to make HO2 at times, but due to the instability, it either breaks up into H and O2, grabs a nearby H to make H2O2 (Hydrogen peroxide), or kicks out an O and grabs another H, forming H2O.
This is why I tend to describe Engineering as 'stealing nature's patents;' everything we try to do in Engineering has already been tried and 'solved' in some way by Nature. You want to make a strong, light girder? Look at hollow bird bones, Trying to solve the Three-Body problem? Look up, The Solar System is an experiment in solving the TEN-Body problem (not counting moons and minor space objects) (Pluto is STILL a planet, by my reckoning) Need a filter so fine that it will work down to the molecular level? Look inside yourself. I'm not being Zen there, I'm talking about your own organs, your kidneys are better filters that man has been able to build. All of that designed by the simplest form of Engineering possible: Try random stuff, then take the ideas that kind of worked, make random tweaks and try again, rinse and repeat, until you run out of time.
Good Answers: 146
08/01/2016 10:13 AM
Yes but technically, mother nature's dyslexic production would never have lasted 2 and a half years without a challenge - unlike my hapless comment.
I agree that some of the most interesting engineering work being done now is biomimetic - and given our much greater capacity to perceive with technical means (including high resolution imaging) the designs in living things, the opportunity for a big leap from the simplicity of inorganic (I mean non living) design.
We could bicker about life being "the simplest" form of engineering. I would see it as beginning with something that 'worked' and then repeating, diversifying, and building increasingly complex self-replicating functional entities all made out of the basic 'thing that worked' (a cell with a functional level of awareness and the ability to replicate itself).
On the other hand, nothing wrong with the random trial, tweak, rinse, repeat approach, at least I tell myself that to explain the non-linear progress of my tomato breeding program.
incus opella
08/01/2016 10:44 AM
"On the other hand, nothing wrong with the random trial, tweak, rinse, repeat approach, at least I tell myself that to explain the non-linear progress of my tomato breeding program."
I never said it was the best method, the only advantage it has to 'human-centric' Engineering is that is is very low in energy expenditure over time. The downside of going that far into the 'cheap' and of the 'good-fast-cheap' triangle is that the time frames are stretched out to ridiculous lengths. Billions of years to slap together enough rock, iron and dirt to make a habitable planet? Millions of years after that to produce a life form that can effectively apply all six of the Simple Machines to alter the environment. A time table like that would be totally unacceptable, outside of government contracts and road repair.
Good Answers: 146
08/01/2016 12:07 PM
Road repair... indeed! A timeline as I understand it of 10-15 years of poorly patched and re-patched potholes, followed by six months minimum of completely destroyed pavement, followed by a one day job in which brand new paving is miraculously installed.
Many arguments about certain aspects of evolutionary theory have in fact pointed out that such a process is completely untenable for the emergence of new life forms, since the intermediate forms are impassible, I mean unviable.
In tomato breeding, there is a straight line process taking seven generations between the original cross and the final product, a stable self-replicating variety whose seeds are 'true'. However in order to make advantage of the shortest timeline, it is necessary to grow out very large numbers of the intermediate generations in order to select the very best combination of traits from the original parents. This requires a vast amount of tomato-habitable space, which is arguably more expensive than time (or more time consuming, if you wait for 'nature' to pound rocks into habitable dirt). Where the final combination of superior traits is the unequivocal goal, it may be possible to do so with far less space and only a moderate increase in time, by creating 'sister' lines which share some of the genome of the primary cross, and may be crossed back into the primary line to recover specific traits that were desired. Stirring the gene pot is then an efficiency of sorts, where habitable space is limiting.
For analogy in nature, take homo sapiens and neanderthal. Stir, shake, rinse, and voila. A mere hundred thousand years from nomadic hunter to six simple machines.
incus opella
01/07/2014 1:22 AM
When I was a kid on the farm we made HUGE forts in the hay barn while putting up hay and straw. We never had money for all of the other toys, but we WERE resourceful!!!
Re: To an Engineer Anything Can Be Building Materials
01/07/2014 9:30 AM
Since this is a fun topic about engineering creativity using unusual building material, please don't kill me for asking. I'm admitting up front that it is about my kid's project. Once again they are building a meter long spaghetti bridge that must be able to hold 1 kilo suspended from it. The one I "helped" engineer last year matched all design requirements and was able to withstand all weight tests etc with one small problem 10 year olds couldn't assemble in the 4 hrs they had in school. Does anyone have any tricks for bundeling spaghetti with glue or can point me to a site that might help? Unfortunately they are being asked to do this with absolutely no science and math (or guidance from their teachers) behind the project. I've been to several tech school sites that hold this competition but their bridges are works of art. Thanks in advance.
Good Answers: 21
01/07/2014 9:44 AM
There you go, you have the answer! Get to it Michelangelo...got to be easier than baking a cake. Send us a pic for our pleasure.
adreasler (3); Anonymous Poster (2); artsmith (4); evaluator (1); Hilton (1); KP21 (1)
