Pump Technology Blog Blog
The Pump Technology Blog is the place for conversation and discussion about industrial pumps including water and wastewater pumps; controls, operation, maintenance; pump applications. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Is a Shut Discharge Valve Counterproductive?   Next in Blog: Motors Matter: Understand the Differences Between Immersible and Submersible
3 comments
Treating a Treater's Chemical Dependency
Posted February 18, 2014 1:00 PM by Engineering360 eNewsletter
When a Washington state wastewater treatment plant replaced traditional tube-element peristaltic pumps with a new metering pump, its chemical costs dropped by 15-20%. As explained by the plant's operations manager, the pump's "barrel bar feature" triggers an alarm when a 250-gal. tote gets low - no waste from premature tote changes, and no fear of running dry.
Editor's Note: This news brief was brought to you by the Pump Technology News eNewsletter. Subscribe today to have content like this delivered to your inbox.
Re: Treating a Treater's Chemical Dependency
02/18/2014 4:56 PM
Treating a Treater's Chemical Dependency seems to be a duplicate blog.
Is this chemically induced?
"Contact blog admin" didn't work for me.
02/18/2014 7:53 PM
I'm not sure how that happened, but the duplicate post has been removed.
Hobbies - CNC - New Member
12/23/2014 10:03 AM
McCalib explained that Lakehaven installed the metering pumps in the Lakota location because the plant had problems pumping from a tote. Operators could not shut off the pumps mid-process, which made knowing when to change the tote difficult. Occasionally, totes would drain completely. At other times, an operator would change a tote that was 20 percent full. McCalib credits the metering pump barrel bar feature with a 15 to 20 percent reduction in chemical costs, giving operators the ability to meter properly without wasting chemicals or running dry.
It appears that the waste was more an operator issue than a pump issue. Even the most accurate pump will be wasteful if the operator is discarding any usable chemical. 20% full? Really? Poor supervision? Lack of care? Fiscal oversight?
We would take our excess chemical and transfer it to another tote of the same chemical or we would have 2 totes set up so we could drain one completely and then swap over to the other tote.
lyn (1); Original_Macgyver (1); SavvyExacta (1)
