IHS ESDU Blog Blog
IHS ESDU Blog
IHS ESDU provides validated information, insight and tools for engineering design. ESDU analytical methods and tools and rigorously evaluated data collections are used to assist and improve fundamental design and analysis in safety-critical industries such as Aerospace & Defense, Oil & Gas, Chemicals and Nuclear, and in Academia and Research. ESDU provides guidance on more than 1500 specific topics in a variety of aerospace, mechanical, structural and process engineering areas such as aerodynamics, aircraft noise, aerospace structures, composites, fatigue, stress and strength, vibration, heat transfer and fluid mechanics. Click here to watch a video and learn more.
Previous in Blog: ESDU Challenge: Shock Wave   Next in Blog: ESDU Challenge: Geopotential Height
2 comments
Validated Materials Properties
Posted August 11, 2014 12:00 AM by SavvyExacta
Pathfinder Tags: ESDU
Design engineers can spend a great deal of time rigorously developing models, analyzing structures, and simulating product performance. Good, reliable design data is critical to the design process.
The design engineer faces an ever-increasing demand for products with a performance that must be substantiated under stringent conditions of cost and environment. If invalid material property data are utilized, then valuable engineering time will be wasted.
If the error is detected early during development or testing, then the design and structures will have to be reanalyzed with validated data and new prototypes built and tested. In the worst case, field failures could result in costly corrective actions such as scrapping of raw materials, alternative materials selection, new supplier identification and approval, product redesign, or retooling of production lines.
How do you find--and verify--that you're using accurate information?
Read the full article, Validated Aerospace Metallic Materials Properties.
Good Answers: 94
Re: Validated Materials Properties
08/11/2014 9:42 AM
I've always found Matweb to be accurate, & free.
08/12/2014 7:09 AM
As far as I know, I have always received the material I have ordered for a design. And the materials properties for ASTM verified materials are all over the web and in hard copies.
However, I learned a good lesson one time about material properties in an expensive way: Especially true for round stock, the material properties are only valid for a certain depth toward the central axis, that is to say for example that the properties are valid only for something like 2/3 of the radius of the round stock. So if you have a 6" diameter of 1144 SP for example the properties are only good until you turn it down to 2" then all bets are off and no one knows what the material properties are at that point without further testing.
