IHS ESDU Blog Blog
IHS ESDU Blog
IHS ESDU provides validated information, insight and tools for engineering design. ESDU analytical methods and tools and rigorously evaluated data collections are used to assist and improve fundamental design and analysis in safety-critical industries such as Aerospace & Defense, Oil & Gas, Chemicals and Nuclear, and in Academia and Research. ESDU provides guidance on more than 1500 specific topics in a variety of aerospace, mechanical, structural and process engineering areas such as aerodynamics, aircraft noise, aerospace structures, composites, fatigue, stress and strength, vibration, heat transfer and fluid mechanics. Click here to watch a video and learn more.
Previous in Blog: ESDU Challenge: Parachute Decelerator   Next in Blog: How to Predict In-flight Coaxial Jet Noise
7 comments
ESDU Challenge: Acenaphthene
Posted March 13, 2015 12:00 AM by SavvyExacta
Pathfinder Tags: ESDU esdu challenge
In this series from IHS ESDU, challenge questions will be posted for the community. Some questions may require calculations and others are general knowledge questions.
Here's this week's question:
The use of oil flow visualisation as a means of identifying flow features can be a valuable tool to aid the analysis of the aerodynamic characteristics of a configuration. In this process, acenaphthene is used to:
a) show boundary layer transition in low-speed tests by evaporation
b) show boundary layer transition in high-speed tests by sublimation
c) show flow direction near the model surface by streaking
Check back soon for the solution to this question! Visit the IHS ESDU website for more information about the validated design methods, or to request a trial subscription.
Re: ESDU Challenge: Acenaphthene
03/13/2015 7:58 AM
If there were a question in there, I'd say that the answer was b) - sublimation.
03/13/2015 11:51 AM
"Acenapthene sublimation is a standard visualisation technique used in the ARA Transonic Wind Tunnel (TWT) to detect the position of transition from laminar to turbulent flow on the model surface"
Source: http://www.ara.co.uk/services/experimental-aerodynamics/optical-systems/acenaphthene-sublimation/
Good Answers: 92
03/13/2015 11:42 AM
C)- Flow visualisation by streaking.
03/13/2015 12:18 PM
"Acenaphthene is a hydrocarbon component of tar. An acenaphthene film spread over the wing has the property of being "ripped off" (we say that it is sublimated) when the flow is turbulent, which helps to differentiate the laminar areas (white) from the turbulent areas (black), with the boundary characterizing the transition."
03/13/2015 5:01 PM
Acenaphthene should only be taken under the close supervision of a psychiatrist.
03/13/2015 11:38 PM
should be a "Like" button,,, had a good laugh, thanks
and these truthes shall be held self evident that all men are created equall
03/13/2015 11:40 PM
Maybe an "irreverent" button?
JNB (1); JohnDG (2); lyn (2); SolarEagle (1); UsernameJUDGE (1)
