IHS ESDU Blog Blog
IHS ESDU Blog
IHS ESDU provides validated information, insight and tools for engineering design. ESDU analytical methods and tools and rigorously evaluated data collections are used to assist and improve fundamental design and analysis in safety-critical industries such as Aerospace & Defense, Oil & Gas, Chemicals and Nuclear, and in Academia and Research. ESDU provides guidance on more than 1500 specific topics in a variety of aerospace, mechanical, structural and process engineering areas such as aerodynamics, aircraft noise, aerospace structures, composites, fatigue, stress and strength, vibration, heat transfer and fluid mechanics. Click here to watch a video and learn more.
Previous in Blog: ESDU Challenge: Vertical Winglet   Next in Blog: ESDU Challenge: Acenaphthene
9 comments
ESDU Challenge: Parachute Decelerator
Posted August 29, 2014 12:00 AM by SavvyExacta
Pathfinder Tags: ESDU
In this series from IHS ESDU, challenge questions will be posted for the community. Some questions may require calculations and others are general knowledge questions.
Here's this week's question:
Which type of parachute would be suitable as an aerodynamics decelerator to reduce an aircraft's landing role?
a. Conical(solid fabric)
b. Hemispherical (solid fabric)
c. Conical (ribbon)
And the answer is:
c) conical (ribbon). Only designs with high levels of geometric porosity can deliver the stability requirements of this application. See ESDU 09012 for more information.
Visit the IHS ESDU website for more information about the validated design methods, or to request a trial subscription.
Re: ESDU Challenge: Parachute Decelerator
08/29/2014 12:30 AM
This one works pretty well.....so b.
08/29/2014 3:18 AM
Landing roll, not role.
08/29/2014 6:23 PM
Well, if the parachute is big enough, the plane won't have to land, so that reduces its landing role.
08/29/2014 3:30 AM
This is really a question about the role of grammar and proof reading in publishing, right?
For my money, anything that hangs off the back and catches wind will sloe the aircraft down.
08/29/2014 8:54 AM
I think the choice is the conical ribbon as it has the highest coefficient of drag (.5 to .55) over the other choices.
However, there is something called a ring-slot conical that has even a higher C/D, but I don't know why they are not as popular as the choices you mentioned. Maybe it has to do with size.
08/29/2014 12:03 PM
Well, as the drogue chute is deployed at a fairly high speed, a high cd isn't usually desirable. The 'chute is intended to burn off some of the speed so brakes can be applied.
I'm going with answer a.
08/29/2014 12:56 PM
You could be right, but the straight conical chute has a lower C/D for a given size.
Good Answers: 97
08/29/2014 4:15 PM
Whatever type is used, It is important that all seatbacks be returned to the upright position and seatbelts are securely fastened.
CRTL-Z
Good Answers: 114
08/31/2014 8:05 AM
They are all suitable! They are not equally effective though.
Perhaps you were attempting ask which is the most effective.
Anonymous Hero (2); Doorman (1); lyn (1); passingtongreen (1); Rixter (1); SolarEagle (1); Tornado (1); Unredundant (1)
