IHS ESDU Blog Blog
IHS ESDU Blog
IHS ESDU provides validated information, insight and tools for engineering design. ESDU analytical methods and tools and rigorously evaluated data collections are used to assist and improve fundamental design and analysis in safety-critical industries such as Aerospace & Defense, Oil & Gas, Chemicals and Nuclear, and in Academia and Research. ESDU provides guidance on more than 1500 specific topics in a variety of aerospace, mechanical, structural and process engineering areas such as aerodynamics, aircraft noise, aerospace structures, composites, fatigue, stress and strength, vibration, heat transfer and fluid mechanics. Click here to watch a video and learn more.
Previous in Blog: ESDU Challenge: Acenaphthene   Next in Blog: Knowledge is Power! A Case Study
How to Predict In-flight Coaxial Jet Noise
Posted April 03, 2015 12:00 AM by SavvyExacta
Pathfinder Tags: aerospace ESDU
Did you know that there are regulations regarding aircraft noise? Software is a valuable tool for predicting what aircraft might sound like in certain scenarios.
ESDU software estimates the change in coaxial jet noise spectrum levels when moving from stationary to flight conditions. The method breaks up the coaxial jet mixing noise into three discrete single-stream jets:
  1. The secondary jet
  2. The mixed jet
  3. The interaction jet
Each of these discrete jets is characterized by different combinations of the coaxial jet parameters.
Considering velocity alone, the single-stream jet that represents the mixed jet has a velocity that is a function of the velocity ratio, the temperature ratio and the area ratio of the coaxial jet.
The velocity of the interaction jet is taken to be the same as that of the primary (core) flow of the coaxial jet, and the velocity of the secondary jet taken to be that of the secondary (fan) flow of the coaxial jet.
The other parameters of jet temperature, jet flow area and jet diameter are treated in similar but individual ways.
The noise from each source is predicted, modified, and summed to provide a static coaxial jet noise spectrum.
Read more about this topic in an IHS Engineering360 interview with Cyrus Chinoy, head of EDSU's Aircraft Noise & Structural Dynamics Group, and Willie Bryce, a member of the organization's Aircraft Noise Committee.
Re: How to Predict In-flight Coaxial Jet Noise
04/05/2015 3:21 PM
I'd say the larger problem is how to reduce the perceived noise at the listener's ears.
