Electrical Components Blog
Previous in Blog: Storage Remains the Missing Link for Renewables   Next in Blog: Combined Cycle Dominates New Power Generation
Grid Scale Power Storage Takes Many Forms
Posted May 18, 2015 12:00 AM by Engineering360 eNewsletter
Grid scale storage technology will be a crucial piece of the electrical grid in coming years. Not only can megawatt-hour size batteries help smooth out demand fluctuations, thus reducing the need for gas fired "peaker" plants, but they may also be called on to bank up renewable power when it is available and pay it out when it is needed. The Economist looks at the state of technology for several flavors of batteries, including exotic molten metal types. But batteries are not the only answer, as they compete with other technologies surveyed in the article including underground pumped storage and heat storage.
Editor's Note: This news brief was brought to you by the Electrical Components eNewsletter. Subscribe today to have content like this delivered to your inbox.
Re: Grid Scale Power Storage Takes Many Forms
05/19/2015 10:59 AM
The newest class of aluminum-carbon batteries will out-pace all other forms of electrochemical energy storage, as to cost, simplicity, design flexibility, actual flexibility, scale-up, fire safety (no fire hazards known on this one, compare to lithium or sodium ion cells that can catch fire when overheated during charging). Redox storage batteries are good, but cannot match the energy density of the aluminum system. Very extremely fast charging, even compared to Li+ or Na+ cells. Many thousands of charging cycles, long life. No brainer.
Another (almost Roman tech) is the use of coal mine type elevators moving "stones". The stones need only be moved from bottom of hill, canyon, or escarpment to the top in order to store energy, and reverse motor is generator on these during downhill run. Efficiency is up there. Stored heat in the form of hot gravel beds under pressure also works. Compressor set runs either way to either store energy or produce electric power. Not rocket science, not site selective (compared to pumped hydroelectric, or the stone conveyor trick). Even the stone conveyor trick can be made non-site specific by introducing a vertical shaft, but the storage capactiy would be very small compared to the scale projected in the 1000's MWH for large projects on an escarpment, or mountain. No water tied up in projects either.
