Electrical Components Blog
Previous in Blog: Grid Scale Power Storage Takes Many Forms   Next in Blog: ST Quits Digital IC Manufacturing Beyond 14 nm Node
3 comments
Combined Cycle Dominates New Power Generation
Posted June 04, 2015 12:00 AM by Engineering360 eNewsletter
In the U.S., most new power generation is based on natural gas fired combined cycle units. Combining a gas turbine and a steam plant can yield efficiencies in the range of 50% to 60% since much of the waste heat is recovered. Furthermore, these units can be started and stopped relatively quickly to offset fluctuating renewable power production (some installations can produce power within 10 minutes), and they have very favorable air emissions as compared to coal plants. Power Engineering discusses some of the major features of combined cycle gas turbine units, and surveys several 500 MW and larger modern power plant projects using the technology.
Editor's Note: This news brief was brought to you by the Electrical Components eNewsletter. Subscribe today to have content like this delivered to your inbox.
Re: Combined Cycle Dominates New Power Generation
06/04/2015 12:10 PM
They should put these in the cities and further extract heat out for space heating and domestic hot water. Buildings in the immediate vicinity could be plumbed to take the condenser heat. Still would need alternate heat rejection in warmer weather of course.
06/10/2015 3:36 PM
That is taking the cycle beyond combined cycle, and off into the vast region known as cogeneration, where there is some field experience, but not many applications in the field.
Another thing is that the typical combined cycle is not as fast start as people think, since one must build up the head of steam before the steam side of the cycle is operating, but the gas turbine ramp up is fairly quick, but also depends on the steaming ramp of the HRSG, how long the steam turbine needs to be rolled during its warm up, etc.
People have looked at using SCC (supercritical carbon dioxide), and the first plants are being built. Much higher simple cycle efficiency, and if fronted by an air separation plant, there is no emissions (within practical limits) as far as NOx, SOx, CO2, etc. The only by-products are condensed pure water, and food-grade carbon dioxide, and a bit of waste heat that could be utilized by district heating needs.
06/05/2015 1:37 AM
Combined cycle improve plant efficiency. It is also required to study the feasibility to use waste heat for HVAC purpose using VA technology as conventional AC equipment consumes substantial amount of energy.
Brave Sir Robin (1); James Stewart (1); mrswamy (1)
