Wire and Cable Technology Blog Blog
The Wire and Cable Technology Blog is the place for conversation and discussion about power cables; cable assemblies; cable manufacturing & testing; and cable ducts, trays and accessories. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Researchers Say They Can Double Fiber Optic Cable Range   Next in Blog: Snake-Like Charging Cable Slithers Towards Release
10 comments
Flexy Wires Stretch to 14x Their Length
Posted September 01, 2015 11:14 PM by Engineering360 eNewsletter
Wires that stretch to over 14x their length can increase their conductivity to over 200x when pulled to their limit. Researchers at the University of Texas at Dallas are using their wires as capacitors which, when elongated, boost their energy storage capability by 10x. Some day, the researchers predict, the wires - which are built by wrapping lighter-than air, conductive sheets of carbon nanotubes to form a jellyroll-like sheath around a long rubber core - might, for example, work as interconnects for super-elastic circuits or for failure-free pacemaker leads.
Editor's Note: This news brief was brought to you by the Wire & Cable Technology eNewsletter. Subscribe today to have content like this delivered to your inbox.
Re: Flexy Wires Stretch to 14x Their Length
09/02/2015 7:40 AM
This is misleading. The conductance (mhos end to end) stays constant when the cable is stretched. In a normal material, the end-to-end conductance would decrease (increased resistance) as the material was lengthened and became thinner with stretching.
The reason the resistance is constant is that the carbon sheets making up the cable are "scrunched up". They straighten out when the cable is stretched, so the conductive path is the same. Nothing magic about it.
Good Answers: 97
09/02/2015 4:32 PM
The use of the terms "Conductance" and "Capacitance" in this article, are confusing.
CRTL-Z
09/03/2015 3:48 PM
"This is misleading."That's an understatement!
"...using their wires as capacitors which, when elongated, boost their energy storage capability by 10x" There is definitely something missing here. Perhaps two layers of the stuff...
"lighter-than-air" Yeah, sure! At atomic weight of 12, the spacing of carbon atoms in the matrix would have to be more than 41% of the average spacing of air molecules (molecular weight≈29). Clearly, a one-atom thick sheet of anything is incredibly light, but it is essentially 2-dimensional. How many layers does it take to fill a cubic whatever?
09/11/2015 12:48 PM
Somehow, this whole article (not necessarily the University where the research was done) has the distinct aroma of B.S. (not meant as disparaging remark against Bevo, just saying). If the wires can be stretched and maintain the over all resistance as before that is good. If there is a capacitance (which I fail to see how), if that increases with stretching, it still cannot overcome conservation of charge, thus if capacitance increases, the ratio of charge to voltage must concomitantly change accordingly, thus either charge must go up, or voltage decrease. Where would any extra charge come from? The ether? Obviously, the voltage must decrease.
09/02/2015 3:45 PM
"which are built by wrapping lighter-than air, conductive sheets of carbon nanotubes..."
So, the wires should float, too.
09/02/2015 6:49 PM
That's the ground that's floating... :) -smileys not working!
Good Answers: 151
09/02/2015 4:34 PM
I would just like a wire (like the one that I just cut short)that could just stretch the extra 3 inches to reach the terminal in the panel that I am wiring.
Good Answers: 97
09/02/2015 4:46 PM
I did that once and when I went to the other end of the conduit, THE WIRE WAS GONE!
CRTL-Z
09/02/2015 5:30 PM
Should have invested in either a KrisDel or LynDoor patented wire stretcher!
Reply Off Topic (Score 4)
09/02/2015 6:54 PM
Ah yes, I remember the old Heath Kits. If they said cut a wire 2 1/4", 2 1/8" wouldn't reach!
Anonymous Hero (1); dkwarner (1); gringogreg (1); James Stewart (1); Kilowatt0 (1); Rixter (3); Unredundant (2)
