Automotive Technology Blog
Previous in Blog: Transport Sector's Carbon Footprint Grows   Next in Blog: A Motorcycle So Safe You Don't Need a Helmet
5 comments
Still Searching for Breakthrough Battery Technology
Posted September 19, 2016 12:00 AM by Engineering360 eNewsletter
Industry news sources continue to report proposed alternatives to the lithium-ion batteries that power everything from laptops to electric cars. The latest candidate, lithium-sulfur batteries (Li-S), can store 4x the energy per unit mass of the Li-ion variety and can work at high temperatures without catching fire. Nevertheless, Li-S batteries can suffer sulfur depletion after a relatively short life, and polysulfides can contaminate the electrolyte. IEEE Spectrum explains how researchers have alleviated such shortcomings using a coating technique to produce a stable battery up to 55° C.
Editor's Note: This news brief was brought to you by the Automotive Technology eNewsletter. Subscribe today to have content like this delivered to your inbox.
Re: Still Searching for Breakthrough Battery Technology
09/19/2016 4:30 PM
Whatever happened to the new rechargeable aluminum air batteries that Stanford University published only about a year ago. Even more voltage out per cell than any Lithium cells. Very fast recharging that makes Lithium tech look silly. High current draw possibilities....did someone with deep pockets pay them to go away and be quiet?
Good Answers: 61
09/19/2016 5:41 PM
Looks like only 2 volts for Al/Air battery:
“Millions of consumers use 1.5-volt AA and AAA batteries,” he said. “Our rechargeable aluminum battery generates about two volts of electricity. That’s higher than anyone has achieved with aluminum. But more improvements will be needed to match the voltage of lithium-ion batteries," Dai added.
Still, 2v. very useful in conjunction with very fast charge and discharge, safety and COST.
09/20/2016 10:35 AM
I did misspeak, and I seem to be doing more of that lately, and less fact checking. Sorry. At least I know Al cell produces more current per mole of aluminum than does Li+ ion per mole. Aluminum is always going to be trivalent.
Good Answers: 61
09/20/2016 11:48 AM
Actually it doesn't. Atomic weights of Li and Al are 6.941 and 26.98 so with +1 and +3 valencies, Li still gives more coulombs than Al per unit weight. The only elements that could beat Li are beryllium +2 (At.Wt.= 9.012) and hydrogen +1 (1.008). Beryllium unsuitable for several reasons. What a shame hydrogen is a gas. As soon as we use it in solid metal hydride form, as in Ni/metal hydride battery, we are lumbered with a chunk of something else (cadmium usually) that takes no part in the reaction.
Looks like Li and O2 would give us the best energy density and much work has been done to achieve that. But based on cost, Al and O2 would be a winner.
09/20/2016 12:34 PM
I said per mole, not per weight, slight and unimportant difference. Aluminum is still cheaper I think, at least when the technology reaches the inflection point on the learning curve it will be.
Other advantages: does not catch fire.
Other advantage: does not self-discharge that I am aware of.
Other advantage: many more cycles (deep ones) than Li+
Other advantage: many times faster charging rates achievable
