The Engineer's Notebook Blog
Previous in Blog: Why Bother With Chairs?   Next in Blog: Bananapocalypse?
7 comments
Do We Need Better Hurricane Ratings?
Posted November 14, 2016 12:00 AM by Hannes
It’s no secret that the mass media relies on hype to stay in business, and disasters often provide ideal opportunities to broadcast on the edge of panic. For example, news outlets portrayed Hurricane Matthew as a superstorm destined to wreak havoc on the US coast, but instead the storm quickly weakened to Category 2 and peak wind gusts generally stayed below 100 mph after it made landfall. Still, Matthew destroyed 7,000 homes in North Carolina and killed 49 people in the US alone.
Disaster rating systems should provide a reasonable indication of potential damage, and Matthew’s mild ratings were something of an anomaly. As its name implies, the Saffir-Simpson hurricane wind scale (SSHWS) used to classify hurricanes takes only wind speed into account. Matthew’s damage was primarily caused by record flooding due to intense rainfall. Similarly, Hurricane Sandy registered as Category 1 but was the second-costliest hurricane the US has ever seen. These discrepancies beg the classic engineering question: is there a problem with the Saffir-Simpson scale, and if so can scientists design a better one?
For sure, wind speed is the most important metric relating to hurricanes. As shown in the video below, the difference between a Category 1 and a Category 2 storm can determine whether your trees lose their leaves or your house loses its shingles. But critics of the SSHWS say that rating storms without taking the storm’s sheer size and rainfall into account is potentially dangerous. Many favor developing an alternative rating system based on the Richter scale, which describes earthquake magnitude as a continuous logarithmic function. But while the Richter scale is much more accurate in its ability to describe earthquakes, the Saffir-Simpson scale’s neatly quantized categories are easier for the public to digest, even if they’re sometimes inaccurate.
It’s tempting to compare the SSHWS with the enhanced Fujita scale introduced in 2007 to classify tornadoes. The Fujita scale assigns ratings from EF0-EF5 based on the correlation between damage and wind speed. The original scale developed in 1971 attempted to smoothly join the Beaufort wind speed scale and the Mach scale for velocity, as seen here in the graph. Because it’s heavily based on years of observational damage, the EF scale provides fairly reliable expectations for tornado damage. However, factoring observational damage into hurricane ratings would be difficult because storms spend so much time at sea, where terrestrial damage data means very little. The Fujita scale was designed to be applicable to hurricane damage anyway, and hurricane engineers often describe damage using EF numbers.
One recent attempt to reform hurricane ratings is the Hurricane Severity Index, formulated by ImpactWeather. Private development of the HSI began shortly following the 2005 Atlantic hurricane season that caused record damage of over $159 billion. HSI uses a 50-point scale, with 25 points assigned to size—determined by the total coverage of several wind field levels—and intensity determined by wind speed. While the HSI has the potential to more accurately describe a storm, its broader numerical scale would probably be less intuitive to the public.
The HSI competes with a few other newer hurricane metrics, including the US National Weather Service’s accumulated cyclone energy (ACE) metric. ACE is the sum of the squares—taken at six-hour intervals—of the maximum estimated sustained velocity of a tropical storm. ACE effectively describes the most intense winds in a storm’s center, so it’s still a poor metric for understanding the potential for damage and destruction over a large area.
The recent metric with the most potential for describing damage might be NOAA’s integrated kinetic energy (IKE). Like the Fujita scale, IKE is heavily based on observational data collected from Hurricanes Andrew, Hugo, and Opal. It uses a five-point scale similar to the Saffir-Simpson, but it allows for continuous decimal gradations. A NOAA paper (pdf here) by Mark Powell and Timothy Reinhold describes how IKE is more relevant to damage caused by not just wind but also storm surge and waves. And unlike ACE, IKE takes the entire size of the storm into account, as shown in this calculator.
All rating scales are imperfect, and the Saffir-Simpson scale provides a simple means for warning those in a hurricane’s path. That said, incorporating new data and a few new metrics doesn’t hurt either.
Image credit: T.T. Fujita / Rugby471
Re: Do We Need Better Hurricane Ratings?
11/14/2016 11:24 AM
You have to have something to measure. The most damage occurs from flooding which depends mainly on the path of the storm and cannot be assessed before the fact. Floods from Matthew in North Carolina were especially bad because the ground was already saturated and the plateau regions by their very nature do not drain quickly.
11/14/2016 1:15 PM
Rixter's comment made me think about the different pieces of information different people need about a storm and the different ways these folks use the information. Emergency personnel need to know wind speed/direction/potential duration, plus likelihood of a storm surge and where that could happen. This in turn allows utilities to estimate how many customers will lose power, how many repair crews will be needed, and so forth. We can get reasonable data for these questions.
But is it possible to predict the likelihood and intensity of flooding? And to estimate the resources needed for repairs/relocation and so forth? Just thinking about it, flooding depends on the amount of water coming down, how saturated the ground is, how much pavement prevents water from soaking into the ground, the kinds of channels available to carry water off (including storm drains) and what they can carry ... I know we can develop much more complicated equations than this but if you can't know some piece of the information the equation does you no good. Can we measure soil saturation and predict how much rain the soil can absorb?
11/14/2016 1:29 PM
Rainfall and flooding are definitely more difficult to predict and measure.
I remember when our locale was predicted to suffer a more or less direct hit from Irene as a Category 1 hurricane. It was downgraded to "only" a tropical storm before coming too far inland but we still lost power (and our sump pump) for a day and had three feet of water in our cellar from the constant rain. And a number of towns in valleys or in the mountains were completely washed out.
11/14/2016 4:46 PM
Whatever system improvement is recommended, I hope they remember the K.I.S.S. method, maybe where the top of the scale is called - pack up your sh** and run!
11/15/2016 1:49 AM
Nice one, buddy!
11/16/2016 8:31 AM
Although it's a rather nice chart, what's needed is smarter people, a hurricane is a hurricane. Category this and category that doesn't mean a thing.
You would be hard pressed to find the average Joe q public with a wind speed scale stuck on the side of his refrigerator.
It's not like your going skiing, just because you mastered the bunny slope, doesn't mean your ready to run the extreme down hill slope.
11/16/2016 3:31 PM
Clearly, the (verbology) of the Categories must be rendered more (user-useable).
Heretofore, therein after, as it were, I recommend the following improved Category names:
1 - ''Piddling''
2 - ''Middling, fair to''
3 - ''Bodacious, dude''
4 - ''Humongous''
5 - ''Horribonius''...
BestInShow (1); gutmonarch (1); Hannes (1); James Stewart (1); MR. Guest (1); Rixter (1); tonyhemet (1)
