Mechanical Power Transmission Blog
The Mechanical Power Transmission Blog is the place for conversation and discussion about Gears & Gearbox Assemblies; Belts, Pulleys, Chains & Sprockets; Brakes, Clutches & Couplings; Design & Analysis. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Innovation Revelation
ACME Lead Screw Systems Lead to Low Friction, High Efficiency
Posted May 20, 2018 12:01 AM by erathburn
Pathfinder Tags: acme lead screw igus screw drive
Lead screws are a common technology used to convert rotary motion into linear motion, and are often used to provide actuation to a set of linear bearings. Lead screws and plastic nuts are excellent lower-cost alternatives to ball screws and metallic nuts when used in applications where extreme precision (micron level) is not required. One of the most common lead screw geometries in North American manufacturing is the ACME lead screw system.
ACME lead screws were developed in America in the mid-1800s and have been routinely utilized since. Designed with a trapezoidal shape, a flank angle of 29 degrees and a higher pitch than fastening screws, they were made for applications requiring frequent positioning, including power transmission applications moving high axial loads.
High-performance plastic ACME nuts are ideal to use in an ACME system. igus® triboplastic iglide® ACME nuts from the drylin® product line are made of composite plastic materials, which offer lower friction and wear values than many other materials across a wide range of applications. The triboplastics operate free from oil and grease, and they do not require maintenance. They are also able to operate on traditional ferrous lead screws, as well as light-weight aluminum lead screws. Furthermore, they can handle high axial loads, they are insensitive to dirt and dust, they are corrosion-resistant, they have lower wear than other plastics, and they handle vibrations and impact loading better than bronze nuts do.
Speeds and Loads
Due to the tight pitch geometry of ACME systems, they are best suited for low-speed positioning applications. For designs requiring a high linear feed rate, we recommend higher helix lead screws such as dryspin® technology.
The maximum RPM typically recommended for an ACME lead screw is dependent on the radial and axial support from the radial bearings or bushings. For applications exceeding 100 RPM, it is highly recommended that the lead screw be supported by ball bearings. Many radial ball bearings are also capable of carrying the axial load generated by many applications. For those applications under 100 RPM, plastic bushings like iglide® bearings may be used, which do not require lubrication and are ideal for many industries.
For more information, visit www.igus.com/leadscrews.
Figure 1: In the igus® ACME screw system, there are (1) screw support blocks, (2) lead screw supports with ball bearing, and (3) lead screw supports with plain bearing. (Source: igus)
To learn more about the ACME lead screw system from igus®, visit www.igus.com/leadscrews.
This is a sponsored blog post by igus® inc.
