Previous in Blog: Infrasound Inquiry: Newsletter Challenge (November 2018)   Next in Blog: The Ol' Bulb Drop: Newsletter Challenge (January 2019)
7 comments
Superluminal Surprise: Newsletter Challenge (December 2018)
Posted November 30, 2018 5:01 PM
This month's IEEE GlobalSpec Newsletter Challenge is:
A jet of charged particles generated when two neutron stars collide and subsequently collapse into a black hole appears to be traveling faster than the speed of light when viewed from Earth. How is this possible?
And the answer is:
Einstein’s theory of special relativity states that nothing can travel faster than the speed of light. So the apparent superluminal velocity of the jet of charged particles is simply an illusion and arises as a result of a trick of perspective. The effect depends on the jet traveling at relativistic speeds (a significant percentage of the speed of light) and is magnified for relatively small angles between the observer’s line of sight and the astronomical event that generated the jet.
Since the light emitted by the jet at each point along its path of travel does not travel much faster than the jet itself, the distance between light emissions at each point appears to be shorter than it would be for a slow jet. From the perspective of Earth, the oldest light emitted by the jet arrives only shortly before the newest light emitted by the jet. Thus, the jet seems to have moved faster than light on its trip to Earth.
For example, consider a distant jet traveling at nearly the speed of light at an angle to Earth so that it has moved about 12 light-years directly toward our planet and about 9 light-years in the transverse direction across the sky. Using trigonometry, the jet has travelled a total distance of around 15 light-years on its path at an angle to Earth.
Consider an emission of light from the jet at the start of its trip. After 15 years, the light has moved 15 light-years. But during that time, the jet has moved 12 light-years toward Earth. So an additional light emission from the jet at the end of its trip lags the original light emission by only 3 light-years.
Consequently, an observer on Earth sees the jet’s entire trip taking place within 3 years. During this time, however, the jet appears to have moved 9 light-years across the sky. This apparent motion of 9 light years happening in the span of 3 years makes it appear that the jet is moving superluminally.
Re: Superluminal Surprise: Newsletter Challenge (December 2018)
11/30/2018 5:22 PM
They were calculating the speed based on STD's generated by Ralphis....who used moving angles to confuse everybody....
11/30/2018 5:48 PM
From the article:
“We measured an apparent motion that is four times faster than light. That illusion, called superluminal motion, results when the jet is pointed nearly toward Earth and the material in the jet is moving close to the speed of light,” said Kunal Mooley, of the National Radio Astronomy Observatory (NRAO) and Caltech.
The astronomers observed the object 75 days after the merger, then again 230 days after.
“Based on our analysis, this jet most likely is very narrow, at most 5 degrees wide, and was pointed only 20 degrees away from the Earth’s direction,” said Adam Deller, of the Swinburne University of Technology and formerly of the NRAO. “But to match our observations, the material in the jet also has to be blasting outwards at over 97 percent of the speed of light,” he added.
The scenario that emerged is that the initial merger of the two superdense neutron stars caused an explosion that propelled a spherical shell of debris outward. The neutron stars collapsed into a black hole whose powerful gravity began pulling material toward it. That material formed a rapidly-spinning disk that generated a pair of jets moving outward from its poles.
As the event unfolded, the question became whether the jets would break out of the shell of debris from the original explosion. Data from observations indicated that a jet had interacted with the debris, forming a broad “cocoon” of material expanding outward. Such a cocoon would expand more slowly than a jet.
“Our interpretation is that the cocoon dominated the radio emission until about 60 days after the merger, and at later times the emission was jet dominated,” said Ore Gottlieb, of the Tel Aviv University, a leading theorist on the study."
In other words, we are not seeing an object moving faster than light, but two separate objects, the cacoon and then the jet.
https://public.nrao.edu/news/superfast-jet-neutron-star-merger/
11/30/2018 6:25 PM
Ralphis sez...."That's not a proper STD!"
Now that's a STD one can be proud of....
12/01/2018 9:04 AM
I'd say Rixter has the proper answer.
Another example of 'superluminal' motion is the apparent motion of glowing gas due to UV radiation. A point source of UV radiation can cause neutral gas to glow, just as the gas around the Pleiades star cluster glows blue due to the UV emissions from the young stars in the cluster. If the UV source is a moving point source, then the glowing spot within the gas also will appear to be moving. The 'movement' of the glowing spot within the gas cloud can be superluminal, even though the gas itself is stationary or moving slowly, and even though the UV point source is moving much slower than the speed of light.
12/04/2018 11:48 AM
I could also see a wavefront crossing a filament of matter with illumination occurring as the wavefront touches the filament. In that case, depending on the geometry, the illumination point could appear to move faster than light or even in several locations at once.
12/04/2018 3:33 PM
Simplistically, if the (conjoined ?) stars were moving away from earth fast enough, and the jet-spue was angled away from Earth at a great enough angle, then it could (seem to) happen...
12/27/2018 9:35 AM
Apologies for the delay -- the answer is now posted.
Hannes (1); Jpfalt (1); MR. Guest (1); Rixter (1); SolarEagle (2); Usbport (1)
