What Is It? Blog
What Is It?
What Is It? is a place for engineers to test their knowledge (and sense of humor). Each week (or month, or...) the CR4 team will post an unidentified picture of an object, tool, animal, something. We're looking for your best (or funniest) guesses at what it might be in the comments.
Yes, we take [appropriate] submissions. Send them to cr4admin@ieeeglobalspec.com.
Previous in Blog: We're Back! What Is It? (November 2018)   Next in Blog: New Year, New 'What Is It?' (January 2019)
26 comments
Well, What Is It? (December 2018)
Posted December 03, 2018 1:45 PM
Pathfinder Tags: what is it
Your job is to make educated [or uneducated] guesses at what this, ummm...thing, is.
So tell me CR4, what is it?
Re: Well, What Is It? (December 2018)
12/03/2018 2:01 PM
Cr4 staff attempt at cold fusion....haha
12/06/2018 8:57 AM
Like the drink? Kidding...good humor. +1
HUSH
Good Answers: 52
12/03/2018 2:42 PM
My guess is it is attempting to be some sort of engine (although I am probably completely wrong)
United States - Member - Popular Science - Weaponology - New Member
12/03/2018 3:56 PM
Mercury vapor rectifier :)
12/04/2018 12:30 AM
3 phase full wave Mercury pool rectifier
12/04/2018 2:14 AM
Close enough ;)
12/04/2018 2:23 AM
Really!!!!
12/06/2018 5:39 AM
Yes, close enough :p
https://en.wikipedia.org/wiki/Mercury-arc_valve
aka, mercury vapor rectifier :D
12/04/2018 6:41 AM
12/04/2018 8:28 AM
Impressive!
12/06/2018 8:56 AM
Indubitably. Johnny, tell 'em what's he's won...
HUSH
12/03/2018 4:19 PM
Cheech and Chong's patented multi-user E-hookah.
12/06/2018 8:59 AM
Well, it would make the colors that much more fun! +1
HUSH
12/03/2018 6:25 PM
Electric jellyfish.
12/03/2018 7:21 PM
Nitrogen lighting test with separate scatter chambers.
12/03/2018 7:25 PM
Most uninspiring Christmas decoration...
12/03/2018 9:58 PM
Tako vacuum tube...
12/03/2018 10:45 PM
12/04/2018 2:29 AM
Whoa! How does that work then?
12/04/2018 2:42 AM
I remember seeing something similar on a news program about the "Star Wars initiative" in POTUS Regan's time!!
Early 90's at a guess....
It certainly put the "wind up" the Russians at the time and allowed some nuclear agreements to be made, that might not have been accomplished.
(All from memory only!")
12/06/2018 7:00 PM
Well in the description it says it was used to raise voltage, nothing on how it works though...argon and mercury vapor both produce blue light in neon lights...so I'll say it's a mercury arc rectifier....
The particular one pictured by the OP is a Mercury rectifier on display in the Beromünster AM transmitter in Switzerland, before being decommissioned
...."A mercury-arc valve or mercury-vapor rectifier or (UK) mercury-arc rectifier[1][2] is a type of electrical rectifier used for converting high-voltage or high-current alternating current (AC) into direct current (DC). It is a type of cold cathode gas-filled tube, but is unusual in that the cathode, instead of being solid, is made from a pool of liquid mercury and is therefore self-restoring. As a result, mercury-arc valves were much more rugged and long-lasting, and could carry much higher currents than most other types of gas discharge tube.
Invented in 1902 by Peter Cooper Hewitt, mercury-arc rectifiers were used to provide power for industrial motors, electric railways, streetcars, and electric locomotives, as well as for radio transmitters and for high-voltage direct current (HVDC) power transmission. They were the primary method of high power rectification before the advent of semiconductor rectifiers, such as diodes, thyristors and gate turn-off thyristors (GTOs) in the 1970s. These solid state rectifiers have since completely replaced mercury-arc rectifiers thanks to their higher reliability, lower cost and maintenance and lower environmental risk.[3]"...
12/07/2018 3:00 AM
Thanks, I take it, it works a bit like a power tube then.
12/03/2018 11:52 PM
Emmett Brown's flux capacitor prototype ?
Good Answers: 29
12/04/2018 3:08 PM
I was thinking that it was a prototype Mr. Fusion.
12/04/2018 2:09 AM
High power laser?
12/06/2018 5:33 AM
Only ever seen one before at a mine site. The signs around the enclosure said something like "If you see blue, it can kill you."
Apparently when they are active they also give off radiation in "x" ray and gamma wavelengths.
The one shown to me was encased in an enclosure of dry stacked lead bricks when in operation. It had been "retired" when I saw it back in 1983.
Andy Germany (3); BestInShow (1); Brave Sir Robin (1); Doorman (1); frankd20 (1); HUSH (3); IdeaSmith (3); JPool (1); Just an Engineer (1); Lo_Volt (1); Nickjd (3); Phaddy (1); Rixter (1); SolarEagle (4); tonyhemet (1)
